  #1
Old 07-04-2009, 12:34 PM
03 D-max's Avatar
03 D-max 03 D-max is offline
Honorary "Tosser"
Default Hard Shifts
Lately my truck has been shifting hard. It seems to only be the lower gears that do it. No clunking noise it just shifts like my TH350 in my camaro does, which is pretty hard. It started doing it when i loaded a new tune, so after one drive of shifting hard i loaded my previous tune in it and it still shifts hard. I have even put the stock tune in and it still shifts hard.
So is my trans finally puking or what?
__________________
JACOB
Post Whore want to be#1
Easter Whore Member#2
Team Borrowed Time Member#23
Quote:
Originally Posted by The Neens View Post
I don't spray much...Usually only after Mexican food
03 2500hd Efi Live, SD, PPE, FASS, MBRP, K&N
  #2
Old 07-04-2009, 12:37 PM
TrentNell's Avatar
TrentNell TrentNell is offline
Finally underway !!!!!
Default
have you tried resetting your TAPS yet ?
__________________
Trent Nell
01 DMAX 2500 HD = Extreme Prejudice -> EPR Triple turbo Kit, EPR Allison Transmission, Aria's Forded Pistons, Howards Xbeam Rods , Built Engine, Ported Heads , Stage 2 cam, and Gorilla Girdle all by Randy's Engine And Machine , PPE Dual CP3's with 120% stroker pump , DDP 47LMP Injectors , 2-BD Diesel 165 GPH lift pumps , Frozen Boost W/A Cooler , 4link with coil overs at every corner , and a bunch of stuff I am probably forgetting.
9.87 @ 143.56, DA=6550
www.extremeprejudiceracing.com
2001 GMC CC/LB "The tow rig" , EPR Triple Turbo's EPR Trans , EFI live , RDL Headers and mouth peice, 305/55 R20 Coopers , 5" exhaust .
  #3
Old 07-04-2009, 12:41 PM
03 D-max's Avatar
Honorary "Tosser"
Default
Quote:
No not yet.
Should the local GM dealer have a tech 2?
Edit- what does TAPS stand for
__________________
JACOB
  #4
Old 07-04-2009, 12:45 PM
TrentNell's Avatar
Default
Quote:
Originally Posted by 03 D-max View Post
No not yet.
your HP tuners should be able to do it , in the scan software go under VCM controls then under trans there should be trans adapt reset and fast learn reset .
__________________
Trent Nell
  #5
Old 07-04-2009, 12:53 PM
03 D-max's Avatar
Honorary "Tosser"
Default
it wont let me click on reset?
__________________
JACOB
  #6
Old 07-04-2009, 12:56 PM
TrentNell's Avatar
Default
are you connected to the truck ? if you are and it still doesnt work you might need to check with there Tech support .
__________________
Trent Nell
  #7
Old 07-04-2009, 01:02 PM
03 D-max's Avatar
Honorary "Tosser"
Default
when i connect the buttons that i can push get darker but TAPS dont
__________________
JACOB
  #8
Old 07-04-2009, 01:04 PM
stroke250's Avatar
stroke250 stroke250 is offline
diesel freak
Default
when was the spin on changed last??
__________________
Todd
2013 F350
Tuned
  #9
Old 07-04-2009, 01:06 PM
03 D-max's Avatar
Honorary "Tosser"
Default
Quote:
3000 miles ago
__________________
JACOB
  #10
Old 07-04-2009, 01:25 PM
03 D-max's Avatar
Honorary "Tosser"
Default
Were you able to do the trans adapt with your truck trent? I Emailed hptuners support hopefully they will get back to me
__________________
JACOB
  #11
Old 07-04-2009, 01:26 PM
TrentNell's Avatar
Default
i never had too , just always new it was there .
__________________
Trent Nell
  #12
Old 07-04-2009, 01:27 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Target Apply Pressure
The TCM is always looking for the perfect shift ( about 7/10 of a second ). It is constantly trimming to get to that goal. Occasionaly it will reach it but never hang on to it long because your driving style keeps changing.
Anytime you make an engine mod change of any kind it will throw the TAPs off.
Example:
I just found an exhaust leak at the EGR blocker plate. When I tightened it, engine became more responsive and the Alli flair the shifts pretty bad. I did a quick TAP reset with Tech 2 and problem went away within 4 miles.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #13
Old 07-04-2009, 04:39 PM
03 D-max's Avatar
Honorary "Tosser"
Default
so if i cant get my HPtuner to work wil my GM Dealer/ service center have one. No big deal if i have to go to GM I am very good friends with the owners son.
__________________
JACOB
  #14
Old 07-04-2009, 04:43 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
They should have a Tech II and can reset the TAPs
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #15
Old 07-04-2009, 04:46 PM
03 D-max's Avatar
Honorary "Tosser"
Default
Quote:
Thanks Kat
__________________
JACOB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
