  #1
Old 06-23-2009, 02:40 PM
bigbird's Avatar
bigbird bigbird is offline
Default How much $ to rebuild turbo?
My siverbullet 66 has some "in and out" impeller shaft play. is any play ok? secondly how much should it cost to rebuild. I have been told $1000
__________________
10.76@ 127
EPR triples
  #2
Old 06-23-2009, 04:09 PM
TrentNell's Avatar
TrentNell TrentNell is offline
Finally underway !!!!!
Default
Quote:
I had my S300 rebuilt and turned into a 66mm for 600.00 but probably got a discount . i cant imagine more than 600-700 for a rebuild .
__________________
Trent Nell
01 DMAX 2500 HD = Extreme Prejudice -> EPR Triple turbo Kit, EPR Allison Transmission, Aria's Forded Pistons, Howards Xbeam Rods , Built Engine, Ported Heads , Stage 2 cam, and Gorilla Girdle all by Randy's Engine And Machine , PPE Dual CP3's with 120% stroker pump , DDP 47LMP Injectors , 2-BD Diesel 165 GPH lift pumps , Frozen Boost W/A Cooler , 4link with coil overs at every corner , and a bunch of stuff I am probably forgetting.
9.87 @ 143.56, DA=6550
www.extremeprejudiceracing.com
2001 GMC CC/LB "The tow rig" , EPR Triple Turbo's EPR Trans , EFI live , RDL Headers and mouth peice, 305/55 R20 Coopers , 5" exhaust .
  #3
Old 06-23-2009, 10:53 PM
MaxPowerLB7's Avatar
MaxPowerLB7 MaxPowerLB7 is offline
Amateur
Default
I had my S366 rebuilt by high tech for 300 dollars. That was for new bushings only, if the wheels need to be replaced then obviously it would be more.
__________________
02 4x4 Reg Cab Long Bed
10.47@132
  #4
Old 06-24-2009, 01:20 AM
Turbo Buick 6's Avatar
Turbo Buick 6 Turbo Buick 6 is offline
Default
Thrust play is a no no. If there hasn't been any contact yet it will be much less. I would say around $300
__________________
4.5 CLUB
Member #2
06 2500HD LLY reg cab 4wd
Ever feel like lying, down inside a grave
Listen to the elegy, a buyer of the hate
Ever dance beside the devil, taste the barrel of a gauge,
Ever pull the trigger, the light begins to fade
Feel like slipping away
  #5
Old 06-24-2009, 11:03 AM
S Phinney's Avatar
S Phinney S Phinney is offline
Default
If Industrial did it with new wheels and shaft it would be 700-800. I would think it could
Be done for as little as 500.
__________________
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #6
Old 09-17-2009, 09:02 AM
b2machine b2machine is offline
FNG
Default
S Phinney. how do you like the Silver Bullet Turbo from industrial? Was it a direct bolt in?
  #7
Old 09-17-2009, 09:41 AM
Ben46a's Avatar
Ben46a Ben46a is offline
Wannabe puller
Default
If its a 66/74 you can buy a whole new t4 turbo for 900 and put your housings on it if theyre telling you 1000. High tech would probably sell you a cartridge for 700. Thats what mine cost.
Heres the T4 charger: http://www.diesel-plus.com/dd_turbo.cfm?npid=7248
__________________
2005 GMC 2500HD 4x4. ZF6, SB Feramic DD
315/70/17 BFG ATs, 4" TC lift, 60% inj, S366, dual fuelers, Stock rods. Work truck/ toy.
  #8
Old 09-17-2009, 11:11 AM
othrgrl's Avatar
othrgrl othrgrl is offline
Diesel Addiction Owner
Default
We can get you whole cartridges for cheaper than that, as has been said a rebuild should be about $300 as long as there hasn't been contact with the housings and the wheels are in god shape.
__________________
Dustin
06 Chevy RCLB 2WD "NO REHAB" - Shop Race truck. Stock bottom end, DA heads and cam, S485/96 single, 300% overs and 14mm CP3 by S&S, DA trans. 6.56 @ 106------10.49 @ 122
05 Chevy ECSB SS "OTHRGRL" - DA EFI Live, Custom DA Trans, Single CP3, Single turbo, Fuel only
835hp 1350tq - 04/18/13-------------11.18 @ 122 - 08-07-09
DIESEL POWER CHALLENGE 2010 - 3rd Place
Coasted to a 10.74 before retirement to street truck status.
04.5 Chevy CCSB "WORKMULE" - Shop Work truck and stock class sled puller thrown together with spare and scrap parts. 11.81 @ 115------7.54 @ 92
  #9
Old 09-17-2009, 03:57 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
I just had my S400 gone through with new bearings adn rebalanced and it cost 125 plus parts which was a little over 250 total.
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #10
Old 09-17-2009, 04:03 PM
Default
Quote:
Thats a really good price
__________________
4.5 CLUB
Member #2
  #11
Old 09-17-2009, 04:08 PM
Big Girl!
Default
Quote:
I know they are a great shop and the owner loves tractor pulling
__________________
Travis
03 CCSB lb7
special thanks:
  #12
Old 09-17-2009, 04:41 PM
S Phinney's Avatar
Default
Quote:
It's a t-3 turbo so you need the after market pedestal but it is a good turbo. You can pull anything but it takes a bit of fuel to make it happy. I make around 700hp on it and it has good daily driving characteristics.
__________________
  #13
Old 09-17-2009, 05:05 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
I had new bushings and regrind the shaft, for 600.00 from HTT. BUT I wanted to upgrad to the SS turbine housing, so HTT gave me a whole new turbo for 1000.
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #14
Old 09-18-2009, 09:11 PM
specialagentPK's Avatar
specialagentPK specialagentPK is offline
Default
I rebuilt my HTT myself for $250 in parts for a complete rebuild kit. Like it has been said as long as the wheels haven't made contact with the housing you are ok.
__________________
2001 GMC 2500HD
BD-Power 4" Duals
EFI Live V2
AFE Stage 2 Intake
Suncoast Stage 4 Tranny & McRat Converter- Special thanks to Mike L.
HTT Turbo
FASS 150GPH
530hp and 1000 lb.ft daily driver
Max Dyno 569hp and 1260 lb.ft
Tuning by Adam(Malibu795)
  #15
Old 09-21-2009, 11:13 AM
FMOS's Avatar
FMOS FMOS is offline
Hard Up
Default
Check with Alamo Turbo in Edmonton or Calgary. Not my preference because they were A-holes to me, but they can rebuild a BW.
__________________
08 GMC
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
