  #16
Old 06-24-2009, 08:39 PM
Killerbee's Avatar
Killerbee Killerbee is offline
Got Honey?
Default
The lower hose is extremely simple, and faster to drain, about 10 seconds. Use channel locks.
A petcock takes 10 minutes.
You can do a coolant flush in 15 minutes, if you don't complicate it.
If a high mileage vehicle with poor maintenance, consider running a light degreaser till a bit warm, not hot. Then drain 3-4 times, on the last drain use bottled, distilled or RO water.
No oil based coolants. Ethylene Glycol, Di-ethylene Glycol, or Propylene Glycol (Evans)...each 96%...pH buffers and anti-corrosion, and anti-cavitation additives, 4%.
__________________
Michael
  #17
Old 03-12-2010, 08:04 AM
lotsofmiles lotsofmiles is offline
Father of the Van
Default
Did you end up doing yours Tim?
I'm getting close to another change and am trying to decide if I want to do it or take it in. I think they charged me about $100 last time
__________________
Quote:
Originally Posted by Jeremy Clarkson View Post
Some say he was conceived in a cargo van
  #18
Old 03-12-2010, 08:23 AM
Jared Duramax's Avatar
Jared Duramax Jared Duramax is offline
<---- $$$ Whore!!
Default
would it be faster to pull the thermostats, then drain and fill the radiator and run the truck for a few min then drain it all back out?
__________________
Jared
2003 GMC Sierra 2500HD LB7
  #19
Old 03-20-2010, 10:19 PM
mead mead is offline
Gearhead
Default
On the lmm there is no petcock there is however a block drain on the drivers side. It will drain the entire system without taking off the cap on the overflow. This was the process described in the factory manual.
The way I performed the service was to crawl under the truck with a flashlight, a rack of metric sockets, 3/8 impact with a medium extension and a kiddie pool.
I cannot recommend this method for the faint of heart.
You will be covered in hot coolant but by the time you get out of the shower the truck will be drained and you can crawl back under and put the plug back in.
I used some Teflon tape on mine, I think or at least I thought about it. Anyway I put 2 gal of Dex and about 2 or so of distilled in the overflow tank and started it topped it off etc. Drove to Texas
for what its worth I changed at 35000 ish and I used Dex cool because I had some I am not in love with the stuff and will change to a good diesel specific coolant next time but I always change about 30,000 to 35,000 miles.
jim
__________________
08 lmm CCSB, c20, efi stock tune, dpf delete, complete egr delete (turbobuik), bd manifold, MBRP downpipe to straight pipe, air dog 2, banks cac, 285's on stock, high speed floor mats ,RDS transfer tank
86 cucv k30
05 liberty (motori)
  #20
Old 10-02-2010, 03:46 PM
JD4440's Avatar
JD4440 JD4440 is offline
<< Lo-Carb Monster
Default
It almost looks as if you could use a long extension and get it from a safe distance (out of the shower). Looks to be maybe a 15mm ?
__________________
Chris
EFILive(Tuned by JoshH),SC IV,PPE,TTS,Big Dipper,Ect.
O.S. 6128--508hp/12.26@107.4 so far.......Thanks Josh
Quote:
Originally Posted by Trentnell :
Politicians are the only people in the world who create problems and then campaign against them.
  #21
Old 10-02-2010, 03:52 PM
dmaxfireman's Avatar
dmaxfireman dmaxfireman is offline
'Can do' kind of guy
Default
i pulled the lower hose filled and drained with water and coolant flush then filled and drained water about a dozen times with the truck running. then refilled with power cool
__________________
-Fireman
  #22
Old 10-02-2010, 03:58 PM
JD4440's Avatar
<< Lo-Carb Monster
Default
Another thing is, half the post say use drinking water and the other distilled water? What's power cool ?
__________________
Chris
  #23
Old 10-02-2010, 04:13 PM
Default
normal water is fine.
power cool is was heavy duty commercial trucks use. it can be tested and take additives to recharge it when the protecting properties break down. you can also add a coolant filter that has charge packets in it that will only break down and release when they encounter a situation where they are needed.
very cool stuff. no downsides that i have found yet.
__________________
-Fireman
  #24
Old 10-02-2010, 04:16 PM
Default
__________________
-Fireman
  #25
Old 10-02-2010, 05:15 PM
JD4440's Avatar
<< Lo-Carb Monster
Default
Nice. I may see what they want for a gallon . was planning on stopping by anyway as our DD dealer is also the Allison dealer
__________________
Chris
  #26
Old 10-02-2010, 05:25 PM
Default
same here detroit / allison thats where i get all my special stuff for inventing new shit
__________________
-Fireman
  #27
Old 10-02-2010, 09:48 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
As far as tap water, it should be fine to flush the engine with, but on the final fill you'll probably want to use distilled water, especially if you have hard water.
It's only like $1 a gallon, just pick up 5 gallons on the way to get the coolant and be done with it! I figure $5 is worth 100,000 miles of peace of mind
__________________
  #28
Old 10-02-2010, 11:09 PM
JoshH's Avatar
JoshH JoshH is offline
Default
Before you pull the lower hose, loosen the "radiator" cap to make sure there is no pressure on the system then tighten it back up. Next get the clip out of the channel. Now carefully start to slip the hose back off the radiator, just enough that the coolant can start to drain. When you first pop the hose loose, there will be a big gush of coolant at first, but it should slow down pretty quick. You can now use the cap to regulate the flow of coolant. Loosen it a little to get more flow and tighten it back down to slow it. Obviously, you will want a bucket or some sort of catch pan under the radiator. It also helps if you put a piece of cardboard or something behind the hose to kind of act as a funnel to direct any water from splashing toward the back of the truck.
I was about to post the same thing. Either buy the 50/50 pre-mix antifreeze or use distilled water for the correct mix. You probably won't have an issue if you don't, but it is cheap insurance.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #29
Old 10-03-2010, 11:56 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
I would only use distilled water other then for the flush. The tap water is Socal is so bad it would trash radiators in our equipment in months.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #30
Old 10-03-2010, 02:53 PM
keith2500hd keith2500hd is offline
MOTORKILLER
Default
i would use distilled water with new coolant, water treatment chemicals can screw up antifreeze properties. i have used shop vac to put suction on tank prior to removing hose or plug. use rope, bunge or kid to hold in filler opening.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
