#1
Having only Done coolant changes/flushes on gassers,
Im wandering whats the best way or whatever way you guys do this on the Dmax. Going to flush out the pink and put some green and distilled water in. Thanks in advance
__________________
![]() 2007 CCSB 4x4 Duramax LT3 LBZ M A STG III Allison- S.C. T-Case brace/Pump rub Fix Precision Industries M L Race Converter EFI LIVE V2 DSP5 ACID Tune by DIESEL ADDICTION Twin Lift Pumps/ Race Valve 6'' T.C. Strong kit/Cognito Braces/SD sleeves. some other goodies. 2000 ECSB Z71 -6.0 LQ4 BLOWN -TVS 1900 10 psi - Comp 226*-224*/ Dyno Tuned By TJ @ Baker Engineering/SS LT Headers/ RPM LVL VI 4L70E Billet output/ Precision 2600 Vigilante Stall. Hauls Ass
#2
seems like i couldnt find a whole lot out about this topic.
I gave up and took it in.
__________________
07 LBZ 3500 CC/LB SRW Express VAN ![]() |
#3
I just drained the whole system then kept refilling water. Then I would let the engine run till the thermostat opened up and then drained with water until everything was clean. Then refilled the whole system with distilled water and green coolant. Take about and hour to do it right.
__________________
Travis 03 CCSB lb7 06 2500hd ECLB 6.0 gasser 2010 Straight Diesel 2.8 Points Champion ![]() special thanks: B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel |
#4
Check with your local shop and see if they offer BG products they have a coolant flush mechine that hooks in to the upper rad. hose and replaces all of the coolant in the system.
__________________
Jonathan 2006 GMC LBZ Crew Cab, Open Exhaust Turbo Back, Banks Inner Cooler, Banks Ram Air, PPE Lift Pump, Race Valve and Ported Rail Fitting, EFIlive THANKS TO PAT & KAT , Transgo JR, TTS Fuel Tank Kit, EGR Block Off, Auto Meter Gauges, Level kit and new XD's Addicts 20's with Nitto 3055520.![]() 600hp one day
#5
When cold, yank the lower rad hose. That drains 85%.
Reattach the hose, and fill the degas, start the truck and keep filling to the top. Stop the truck before it gets hot and pull the lower rad hose again, that is 98%.
__________________
Michael Last edited by Killerbee; 06-21-2009 at 09:53 PM. |
#6
The best way is the right way. Avoid HOT temp readings
IF your going to use distilled water have plenty on hand and use for flushing. I also did it with the truck at normal operating temperature. Shouldn't have to tell you but with the truck not running of course and be cautious as the fluid will be warm and splash around a bit. Do your part and be environmentally friendly. Remove the radiator cap before shut down. Get a empty 5 gallon bucket and locate the petcock in the radiator open and drain in the empty bucket . Once it's done draining refill with distilled water and restart the vehicle. Not necessary to put the radiator cap back in place. Allow the fluid to circulate top off as necessary. Repeat the drain process and refill until you see clear fluid coming out of the petcock. With having the coolant capacity at hand ,I don't recall and I'm to lazy to look it up,drain off half of the capacity approx and refill with your choice of antifreeze. Allow the fluid to circulate and top off as necessary. Leaving the radiator cap off raise the RPM's allowing it to burp off any air pockets. Test antifreeze for proper temperature protection. It's simple but messy and takes about an hour. This is the procedure I did.
__________________
I have nothing want nothing because what I have cost me to much to have. 01 Big Dually (Gone but not forgotten) 05 Fat-Boy (gets it done) 83 CJ7 (slug but cool) 07 Audi A4 ( I like German Girls they're HOT!!) LIFES JOURNEY IS NOT TO ARRIVE IN HEAVEN SAFELY IN A WELL PRESERVED BODY, BUT RATHER TO SKID IN SIDEWAYS, TOTALLY WORN OUT, SHOUTING,HOLY SHIT WHAT A RIDE! |
#7
Thanks guys for the info, really appreciate it.
Yeah, im enviromentally friendly you could say, i use my sons old Kiddie pool to drain the old coolant into, then use my little sump pump to put it into 5 gal drywall buckets to take to my friends at the dealer for disposal, i dont want to polute my own water! I wasnt sure if our radiators had a drain cock. Glad to see im not the only one running green.
__________________
#8
Tim, the lbz's dont have a drain on the passenger side like the lb7's do.
__________________
2003 Chevy RC/LB. RIP stock engine 03-16-13 Alive again 05-25-13 5530 lbs xx.xx @ xxx.xx TBD on 06-28-13 ![]() 2006 Chevy Colorado I5. Not stock. Tailgate Crew Member #3 |
#9
Quote:
it was very irritating to find out there was no petcock on my LBZ radiator. Whiskey. Tango. Foxtrot. GM!
__________________
2006 K3500 Dmax - ZF 6 speed Crue/Dually Blue Granite Matalic. South Bend DD-MAX FB ,Mud flaps all around, 6" Bull haler 5" pipe , Big Dave downpipe, EFILive tuned, egr removed completely , PCV replumbed , ghost Cat, Custom intake and turbo piping, Super Diesels 1 1/2 Dia SS Center Link, Bulletproof Steering race Tie rods... more to come My Krawler 1985 Dodge Ram 50 6.2 diesel with banks turbo, 38.5x16 MT Baja Claws, AirBag Suspension . to much to list "Some is good, More is better, To much is just right!" Last edited by the4wheeler; 06-23-2009 at 10:17 AM. |
#10
This is one reason i asked, cuz i couldnt find one!
__________________
#11
![]() Think with your dipstick jimmy!
__________________
2003 Chevy RC/LB. RIP stock engine 03-16-13 Alive again 05-25-13 5530 lbs xx.xx @ xxx.xx TBD on 06-28-13 ![]() 2006 Chevy Colorado I5. Not stock. Tailgate Crew Member #3 Last edited by hondarider552; 06-23-2009 at 06:53 PM. |
#12
Quote:
Well aint that dumb............. Is there a block drain or what is the procedure in the GM service manual for draining the coolant system? It can't be pulling the lower radiator hose.
__________________
#13
Good question cuz pulling the lower hose is my only option right now.
__________________
#14
Actually it could be, cause that's it! At least it's a "quick connect" fitting. No hose clamp or anything...
__________________
06 Silverado 4x4 CC/SB 11.13 @ 123.5 <---The good old days 06 Express 2500 Duramax Van "The Dumpster" 11.57 @ 115.6 |
#15
I hate those damn quick clamps on the Rad hoses. Got my share of pinched fingers from those sonsobitches.
__________________
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
