  #1
Old 08-03-2007, 09:26 PM
carcrafter22's Avatar
carcrafter22 carcrafter22 is offline
< Danger Ranger
Default HELP!!!! Truck wont start on a hill
I am haveing a problem with my LBZ not starting on a hill. The truck first did it at my dads about a week ago in his driveway which is on level ground. This morning I hopped in the truck which was in my driveway at a pretty steep slope and the truck wouldnt start. I then went to start it earlier to back it up a few feet into my garage this time it started but died after about 15 -20 seconds. All 3 times I got the truck to start by opening the bleeder screw and pumping the primer 4 times then closing the bleeder screw and pumping the primer a couple more times then the truck would start right up but with a very slight rough idle. The truck seems to run fine driving down the road. I looked at the balance rates on the injectors but I am unsure what an acceptable number is. I have to go to laredo texas tomorrow and really need to fix this problem. oh yeah the nicktane and factory filters are new both appear tight and the main and spare tank are full. So please HELP with any suggestions.
Thanks
Randy
__________________
2006 2500HD cc/sb 11.88@115mph
6.6 DURAMAX LBZ/6 spd Alli 4x4
1967 Ford F100 isuzu 3.9L diesel, 2007 crown vic IFS, 94 lincoln mark 8 IRS, sheid deisel 400cc injection pump, compound turbos HY35 and HX52, custom equal length header.
< somehow still cheaper than building my duramax
  #2
Old 08-03-2007, 10:02 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
randy
the first thing that comes to mind is something is leaking
im terrible with the lbz and think that i would need you assistance with tuning them
as far as parking on a hill well that has given grief to hundreds of people for years as you probaly already know
with the LLYs we have the cranking injection quantity and idle fuel
i dont know if these tables are in the lbz but they may help you
but i really dont see why you would have to alter these tables
do you have a pressure gauge to read what the lift pumps are putting out for presssure? Do you have lift pumps? possible that the nictane is resticting some flow untill the trucks starts?
i know that the 10 micron raycor does restict some flow if i dont have my lift pumps on
can you post or email me the the balance rates
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins. SOLD
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / 47RE /BD intercooler / Ted at MPL / Turbo blankets from Levi FOR SALE
  #3
Old 08-04-2007, 04:42 AM
dynarex dynarex is offline
Default
something is wrong with the fuel sender in the factory tank-ive seen where the suction line gets loose from the sender support and it will suck air-if the tank is completely full its usually not a problem-or when you are moving the fuel is being sloshed around
fill the factory tank and try it on a hill-and dont trust your factory guage it may be reading wrong too-
__________________
07 lbz/ally-285/75 revos-banks intake and nokitty dual exh-kennedy lift pump-efi liveMCRAT merchant s/c iv and 1057 and lots of other cool crap
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Hollywood Larry Jewel TrentNell Smoke Signals 54 04-28-2009 09:53 AM
need help truck wont start 02bigstrokin Duramax Hard Parts 3 04-11-2009 05:49 PM
Looking into getting an LBZ ls1dmax Smoke Signals 11 06-19-2008 01:48 PM
Truck won't start kkhamil23 Duramax Hard Parts 4 06-09-2008 09:20 PM
vB.Sponsors
