  #1
Old 04-29-2009, 12:28 PM
kenny's Avatar
kenny kenny is offline
kennydiesel
Truck: 2006.5 CCSB 2500HD
Engine: LBZ
Transmission: Automatic
Question Twin Turbo kit
Just curious to know how many users here run the Twin turbo kit on their trucks and what they are getting for power. Looking for possible insight on the guys that run it on the LBZ motor too. Thanks agin everyone.
__________________
2006 Chevy 4X4, CCSB, 2500HD, LBZ, 6" Fabtech lift with traction bars and wireless air ride, 20" WCC Wheels, 35" Toyo MTR tires, Flowmaster full turbo back exhaust, BD exhaust manifold, Airdog 150 lift pump, Mag Hytec deep sump tranny pan, 3 Autometer Phantom 2 guages, carbon fiber lined interior, full audio sound system with woofers, monitors, navigation, and back-up camera, and I own this truck just to pull the toys around.
My weekend warrior toy with 500HP LS1 to stand out from all others on the trail
Yes, those are 40" tires too...
  #2
Old 04-29-2009, 12:38 PM
TrentNell's Avatar
TrentNell TrentNell is offline
<----Larry is evil
Truck: 2001 duramax
Engine: 6.6 duramax lb7
Default
MPI twins " big set" , HP on a single stock lb7 cp3 620-640 .
__________________
Trent
01 DMAX 2500 HD , Under construction............ 4link , motor build , trans build , W/A intercooler, coil over front shocks, and hopefully more .
11.06 @ 123.** MPH Tuned by IdahoRob
Quote:
Be careful if you start the jorney , Diesel performance is as adictive as "Heroin " but 10 times as expensive
2001 GMC CC/LB , 8" Fabtech , 35's , 5" exhaust , intake ,
  #3
Old 04-29-2009, 01:46 PM
Bako_Dmax's Avatar
Bako_Dmax Bako_Dmax is offline
GTO Slayer
Truck: 2006 Chevy Dmax
Engine: 6.6 Dmax
Default
I have twins on my LBZ. I havnt dynoed it or raced lately but its about half second faster on my Gtech then the tune I ran a 12.9 w/.
__________________
2006 Chevy LBZ
MBRP exhaust, Shimmed FPRV, Blocked EGR
Homemade Lift Pump W/ Bypass
Homemade Pitman & Idler Braces
Tierod Sleeves
EFI Live
Built trans w/ triple disc
Homemade Twins S475 w/ 38mm gate
  #4
Old 04-29-2009, 02:15 PM
Subman's Avatar
Subman Subman is offline
Old Geezer
Truck: 06 Chev EC/SB
Engine: 6.6 LBZ
Default
I have a twinned lbz, it's the, "stock" set by MPI. Same set as Idaho Rob runs on his LBZ. I have stock motor, injectors and cp pump, do have a lift pump. I hold my boost to 43 lbs and run a hot street tune only. 575 hp to the ground, 12.6-7, 106-7 depending on track and conditions. 21+ highway, 13.5+ towing my 25 foot travel trailer, all on same tune by Idaho Rob of ATP. He runs a hotter tune, has 35 over Big Dipper Injectors, and has run 11.7 with his stock engine and cp pump. He also has a lift pump. He runs about 50 lbs of boost. He ran last weekend at Bremerton with a street tune and won both Superstreet and prostreet at the NHRDA event. Ran consistent 12.1 and 12.2 at 111+. Track was very slick.
__________________
WHITE OUT 06 ec/sb fully built daily driver
Max'd Out 02 GMC Prostreet/Superstreet race truck
BEST TO DATE 9.80, 140.39 BOISE 10/10/09 ROB
Max'd Out Racing Subman,
SPONSORS
MPI
ADRENALINE TRUCK PERFROMANCE
INTELLEGENT ENGINEERING
FORMULA 1 INJECTORS
SUNCOAST
ULTIMATE TRANSMISSION
BIG DIPPER
PERFORMANCE AUTHORITY
PROFAB PERFORMANCE
  #5
Old 04-29-2009, 02:54 PM
Utahski's Avatar
Utahski Utahski is offline
Truck: Chev. Duramax
Engine: 6.6 Diesel
Default
Before twins my stock LLY with lift pump, 4" no cat exhaust and Edge/Attitude dyno'd 349/703 on the biggest #5 setting (stock setting did 236/441).
Engine is still completely stock but with a std MPI set of twins and EFI with Rob's tunes. On the #5 DSP5 tune it dyno'd 506/942 uncorrected at 4300' elevation on winter blend fuel. It's a safe tune for the engine. Dragstrip time 12.77-108.4 at estimated 7200-7300lbs with too much tire spin and a slow 60'. Best mph 108.95. The DSP5 switch is set on #4 street tune for every day. That one is 463/872 and plenty enough to run away from most other vehicles...... gets 21-22mpg cruise control on the highway even with the occasional full throttle stomp.
The truck is a lot of fun to drive. If you're thinking about twin turbos, don't hesitate just do it.
****Addtion - I know of bunch of people who have these things and they're all very satisfied.
__________________
'04.5 LLY / ECSB - MPI Twin turbo by Nathan - EFI Live, DSP5 switch, BD manifold, and UltraLite II gauges all by Idaho Rob - Suncoast IV with 1057 & 6sp conversion, brace, tranny cooler by Mike L - Alcoa 16" Classic/Michelin AT2 - AirDog 150 by Gillett Diesel - MBRP 4" - 53 Gal. Supertanks - Snugtop shell - Tie rod sleeves - Bilstein - etc.
10/16/08
12.77@108.43 - 1.90 60' -- Best mph 108.95
Weight about 7300lbs. Need better 60' time, less weight, some prep, and lots more traction.
  #6
Old 04-29-2009, 03:04 PM
TrentNell's Avatar
<----Larry is evil
Truck: 2001 duramax
Default
The truck is a lot of fun to drive. If you're thinking about twin turbos, do it.
was this matts dyno dave ?
__________________
Trent
  #7
Old 04-29-2009, 03:08 PM
Utahski's Avatar
Engine: 6.6 Diesel
Default
Quote:
Yes. Very early '08.
__________________
10/16/08
  #8
Old 04-29-2009, 03:13 PM
TrentNell's Avatar
<----Larry is evil
Truck: 2001 duramax
Default
from what i found on my truck that dyno has shown to be off by about 60 hp from a dyno jet , and 100 hp from track results . so figure yourself 550-575 rwhp .
but when matt dyno's a truck e is not inflating #'s just giving real world results . he could get it to read higher if he wanted to .
__________________
Trent
  #9
Old 04-29-2009, 03:25 PM
Subman's Avatar
Old Geezer
Engine: 6.6 LBZ
Default
Lots of twin turbo guys watching this thread
__________________
SPONSORS
MPI
FORMULA 1 INJECTORS
SUNCOAST
BIG DIPPER
PROFAB PERFORMANCE
  #10
Old 04-29-2009, 09:27 PM
JoshH's Avatar
JoshH JoshH is offline
I know nuh-thing
Truck: 06 2500HD CC/SB
Engine: LLY/LBZ
Default
I had twins. I sold them to get a bigger set. They're GREAT! I was pushing low to mid 600 hp on the stock engine. Ran a best of 12.09@111 with a race weight of about 6650. I had many other low 12 passes, and probably could have gone lower if I had had time to get it dialed in a little better.
__________________
06 Silverado 4x4 CC/SB
EFILive from McRat Racing, MPI twins, MPI dual CP3s, SunCoast 1058 converter, TTS trans kit with some tweaks, TTS dual lift pumps, Cognito braces, SD tie-rod sleeves, 5" straight pipe exhaust, ATS CoPilot lockup controller, SoCal springs and retainers, SoCal 6460 cam, SoCal cut/coated LB7 pistons, SoCal damper, Carrillo rods, ARP head studs, ARP main studs, 40% injectors by F1 Diesel Performance
"History doesn't repeat itself, but it does rhyme." -Mark Twain
"If it weren't for bad luck I'd have no luck at all!" Hee Haw
Team Arrogance They call me Number 2
  #11
Old 04-29-2009, 09:41 PM
mytmousemalibu's Avatar
mytmousemalibu mytmousemalibu is online now
Cut your ride, sissy!
Truck: 03 2500HD 2wd Sleepr
Engine: LB7 injecta killa
Default
Twins are fourthcoming! I have a real pretty S472 awaiting my install, no kit, all me!
__________________
PLAN-B...Replacment of the Ally for a 5spd Bruno/Lenco
03 2500HD......Custom Compound Twins, this winter maybe sooner?
Ind. Injection Dual Feed Line, BD/TiAL BOV, BD Fullbore, FS-2500,
Coolingmist Stage2 M/W, TTS fuel pick-up, S&B intake, 6" exh, In-cab boost control
50% ExtrudeHone nozzles, Modded CP3, MytNasty Tuned
Summit Billet LP, Intake Heater Delete EFILive V2
LOWERED,Hehehe TEAM BORROWED TIME, Member #12
Ghostly Lucky #13
New DD: 81' M-B 300SD, 299K miles...just broke in! Well thats where the odometer quit!
ALDA aneroid go bye, bye! Cut DV's for fun! AERO Turbine
Soon?cranked pump, intake! Maybe a VVT turbo, M/W, injectors! Diesel isn't just a fuel, its a way of life...
  #12
Old 04-29-2009, 10:08 PM
2500HeavyDuty's Avatar
2500HeavyDuty 2500HeavyDuty is online now
Book 'em, Danno!
Truck: '01 Ext. Cab LB 4x4
Engine: LB7
Default
Quote:
waitin to order mine still, truck needs to run first
__________________
EFI Live
ScIV
Team Borrowed Time Member #17
Danny@dieselbombers.com
  #13
Old 04-29-2009, 10:20 PM
Default
Quote:
Hadnt heared from ya ina bit, whats the latest?
Oh and the V/C's look great!
__________________
Ghostly Lucky #13
  #14
Old 04-29-2009, 10:26 PM
Book 'em, Danno!
Engine: LB7
Default
bad weather keeping me from getting stuff done on the truck. got my injectors in though
__________________
EFI Live
ScIV
  #15
Old 04-29-2009, 10:27 PM
RPM Motorsports's Avatar
RPM Motorsports RPM Motorsports is offline
What's Plan B ???
Truck: 07 CC/SB
Engine: LBZ 6.6L
Default
First thing before even thinking about twins is the trans.
I have the MPI Tow twins (On my LBZ)! I have been the best of 12.04 @110.5 with a MikeL trans and Rob's tuning, & towed a 26' Toy Hauler to the track. I Don't know what it dyno's but the ET should be low 600's. I have since added a set of 30% over tips from Dipper, and went 113.5mph, but was having some other issues. The kit is a perfect fit and finish, and would recomend MPI to anybody looking for twins. My EGT's never see over 1250, no matter what im doing. Like it was said. If you have the funds, Just do it. You will not be dissapointed!
__________________
(Russ) 07 CC/SB Greystone 4x4 4" TC lift, Thanks-> MPI, ATP, Big Dipper. (11.80@115.8mph 1.62 60' Stock motor, Stock CP3)
"Dream as if you will live forever, Live as if you will die tomorrow."
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
