  #16
Old 04-30-2009, 05:35 PM
FMOS's Avatar
FMOS FMOS is offline
Hard Up
Default
Motor disconnects fairly easily, if the front clip was off... I say 2-3 hours you could have the motor out. And once the motor is out you have full access to wrench on everything. I think you could have the heads off, gaskets changed, heads back on and ready to go in a day or so. I guess overall I'm saying it can be done in 2 full days (14 hours) if your prepared.
  #17
Old 05-01-2009, 02:41 PM
durallymax's Avatar
durallymax durallymax is offline
Default
Quote:
you mean one day??
The front clip isnt much work and removing the motor isnt much either. 3 grounds a couple brackets, the P/S pump, the two bale connectors, disconnect the front pipe, get the front clip out of the way, remove the intake and unbolt the trans. Takes me 4 hours not working too hard but i also choose to completely remove the trans so that the truckcanbe rolled out of the shop if needed.
__________________
Wife:2010 Jetta TDI "Cup Edition" Thunderbunny. Stg 2 Malone, Rawtek Straightpipe
Me:2000 Jetta TDI/5spd VNT-17, DXD S2 Clutch
Sis:2006 Jetta TDI/DSG
Puller:2003 LB7 GMC
Toy:1973 Kenworth W923
Farm:02,11,13 Duramax/Allisons
  #18
Old 05-01-2009, 04:31 PM
FMOS's Avatar
Hard Up
Default
I was saying 2 full days you could have head gaskets changed and up and running again if you pull the motor out of the truck.
I'm thinking it will take longer to do in the truck. Plus when its in the truck, one little problem can turn into a big one fairly easily and take quite a bit of time.
... Kinda of like the stupid transmission dipstick. That dipstick BD sends with the install kit is pure crap! I spent about 2 hours bending the shiot out of that thing trying to "tweak" it into place. Finally I just grabbed the stock one, threw it in with no bending required and carried on... I folded the BD one up and chucked it in the garbage.
  #19
Old 05-30-2009, 08:11 PM
smith6.6's Avatar
smith6.6 smith6.6 is offline
Junior Member
Default
I only pull the radiator, I don't pull off the front clip and you can get all the bolts out with out tiping the engine by the trans It's not that bad to do. I will usually pull the exhaust manifolds off it makes it easier to pull the heads.
__________________
2002 E/C S/B
built motor
Custom Compound Twins
sandsdiesel.com
  #20
Old 05-31-2009, 09:16 AM
durallymax's Avatar
Default
Front clip takes all of 20 minutes to remove, so why not do it to make it easier?? Besides its brittle and leaning over it could break it.
__________________
Puller:2003 LB7 GMC
  #21
Old 10-23-2015, 07:54 AM
gmasko's Avatar
gmasko gmasko is offline
Gearhead
Default
Quote:
Originally Posted by TrentNell View Post
Cant help on the time ... but when i do a side job i allways go of the "quoted hours" , where i sell myself is i only charge about 30-40 bucks an hour depending on how shitty the job is . so its a third of the labor cost of the dealer and 1/2 the cost of the ma and pa shop .
Anybody in the Sacramento area like this guy hehehe
Sent from my XT1060 using Tapatalk
__________________
2004 LB7
EFI Live (Autocal) Idaho Rob Mild Tune
Edge CTS2 Gauge
Airdog ll-4G
4" Straight Exhaust
3" Downpipe
Bills Custom 4" Intake w/ S&B filter
Banks BigHead Wastegate
8" CST Lift
35" Toyo MT
Dual King 2.5 w/Remote Res Front/Rear
Deaver Leaf Springs
Cognito Long Travel Airbags
MagHytec Rear Diff
  #22
Old 10-23-2015, 10:28 AM
MrBunny's Avatar
MrBunny MrBunny is offline
Gearhead
Default
here is the gasket kit u should use. it has every thing that you need for gaskets and o rings. plus u can upgrade to studs if the customer wants it. http://www.merchant-automotive.com/p...asket-kit.aspx
__________________
2003 chevy 2500hd, ext cab, short bed, rcd 6" lift, mbrp turbo 5" dual stacks w/ straight pipe, PROFAB 3" down pipe. EFI live with DSP 5 switch. Tuned by Street to Sand, ARP head studs, Full EGR delete, other small things. Amp Research steps.
  #23
Old 10-25-2015, 11:34 AM
duramax on fire duramax on fire is offline
Default
Do you have a two post lift? I pulled my cab and front end in 1 1/2 hours. Never done it before. Made life easy and saved my back. Also water pump is easy to do while you have it tore down that far. I just use a 600lb impact on the harmonic balancer bolt
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
