  #1
Old 04-23-2009, 08:05 AM
Barlow Barlow is offline
Barlow
Default injector warranty?
if im not original owner of truck does the 200k mile warranty still apply?
__________________
2001 ex cab 4x4 LB7
  #2
Old 04-23-2009, 08:15 AM
jraymer's Avatar
jraymer jraymer is offline
<--Tree Hugger
Default
yup it does, but if the truck in question is the on one in your sig, its past the 7 year time frame. 7yr/200k
__________________
02' GMC CCSB
  #3
Old 04-23-2009, 08:48 AM
TheBac's Avatar
TheBac TheBac is offline
Default
GM recently changed the injector warranty to make it harder for customers to get them warrantied. This info was copied from the DP thread "Bad News on Injectors" in the LB7 engine section:
---- the special policy ----
#04039B: Special Coverage Adjustment - Injectors-Replace - (Nov 19, 2007)
Subject: 04039B - Special Policy Adjustment - Injector - Replace
Models: 2001-2004 Chevrolet Silverado
2001-2004 GMC Sierra
2003-2004 Chevrolet Kodiak
2003-2004 GMC TopKick
Equipped with 6.6L Duramax Diesel (RPO LB7 - VIN Code 1) Engine
THIS BULLETIN IS BEING REVISED TO ADD 2004 MODEL YEAR TRUCKS. PLEASE DISCARD SPECIAL POLICY BULLETIN NUMBER 04039A, DATED OCTOBER, 2006.
Condition
Some customers of 2001-04 model year Chevrolet Silverado; GMC Sierra; 2003-04 Chevrolet Kodiak and GMC TopKick vehicles, equipped with a 6.6L Duramax Diesel (RPO LB7 - VIN Code 1) engine, may experience vehicle service engine soon (SES) light illumination, low engine power, hard start, and/or fuel in crankcase, requiring injector replacement, as a result of high fuel return rates due to fuel injector body cracks, ball seat erosion, or high pressure seal extrusion (refer to Corporate Bulletin Number 04-06-04-007G and SI).
This special policy covers the condition described above for a period of 7 years or 200,000 miles (320,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership. The repairs will be made at no charge to the customer.
Important: This special policy only covers the above noted failure modes, which are identified by high fuel return flow.
For 2001-2002 vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after May 25, 2004, are covered by this special policy and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to May 25, 2004 must be submitted to the Service Contract provider.
For 2003 vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after October 10, 2006 are covered by this special policy and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to October 10, 2006 must be submitted to the Service Contract provider.
For 2004 vehicles covered by Vehicle Service Contracts, all eligible claims with repair orders on or after November 19, 2007 are covered by this special coverage and must be submitted using the labor operation codes provided with this bulletin. Claims with repair orders prior to November 19, 2007 must be submitted to the Service Contract provider.
---- and the new testing procedures ----
#04-06-04-007I: Service Engine Soon (SES) Light On, DTCs P0087, P0093, P1093, Low Power, No Start, Hard Start, Fuel in Crankcase (Replace All Injectors - New Strategy for High Fuel Return Rates) - (Aug 18, 2008)
Subject: Service Engine Soon (SES) Light On, DTCs P0087, P0093, P1093, Low Power, No Start, Hard Start, Fuel in Crankcase (Replace All Injectors -- New Strategy for High Fuel Return Rates)
2003-2004 Chevrolet Kodiak C4500/C5500 Series
2003-2004 GMC TopKick C4500/C5500 Series
with 6.6L Duramax™ Diesel Engine (VIN 1 -- RPO LB7)
This bulletin is being revised to advise technicians that 2001-2004 model year vehicles may be covered by Special Policy 04039. Please discard Corporate Bulletin Number 04-06-04-007H (Section 06 -- Engine/Propulsion System).
Condition
Some customers may comment on the Service Engine Soon light becoming illuminated. Upon investigation, the technician may find DTCs P0087, P0093 or P1093. Additional customer comments may include a lack of power, a fuel smell on the oil indicator (dipstick), fuel in the engine oil, fuel coming out of the crankcase breather, the engine cranks but does not run, or a hard start condition. This condition will not cause an engine misfire. Do not apply this bulletin to any diagnostic other than what is identified in the chart below.
Cause
The fuel injectors have internal conditions that may cause them to return an excessive quantity of fuel to the tank, as well as leak fuel into the crankcase. Due to the excessive return flow and/or leakage, the fuel injection pump may not be able to build up adequate fuel rail pressure.
Correction
Important: Before the technician begins diagnostics and repair, be sure to follow the guidelines in Corporate Service Bulletin Number 03-06-04-036A to avoid fuel system contamination.
Important: If the technician commands the fuel rail pressure with Tech 2 to 160 MPa at idle and it reaches at least 158 MPa, then this bulletin does not apply. The technician should then follow normal SI diagnostics. If the rail pressure does not reach 158 MPa, snapshot the data, then follow the diagnostics in this bulletin.
__________________
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- in progress
2014 Chevy Cruze Diesel -- the DD
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
From mufflerguy on yb,
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!"
  #4
Old 12-22-2009, 06:27 PM
Earthtones Earthtones is offline
FNG
Default
My 02 is in for it's second complete set of injectors. They were replaced in 06. What's the warranty when they replace them? They want $3300 as long as they don't break any lines. Should I plan on every 2-3 years spending 4K?
  #5
Old 12-22-2009, 07:37 PM
Blueox03 Blueox03 is offline
Default
I would pull them out, have them properly tested and replace the bad ones. It's really not hard to replace injectors on these engines, just time consuming. Use GM replacements....
  #6
Old 09-02-2016, 05:55 AM
036.6turbo 036.6turbo is offline
Default
Not that bad of a job, here is a link to the write up I did, the last time I replaced mine;
http://www.dieselplace.com/forum/71-...ment-pics.html
That was 110,000 miles ago and mine is ready for another set. But I am swapping out the LB7 for an LBZ.
__________________
2003 GMC Sierra CCSB.
LBZ / Six speed / EGR Delete / DSP5 with tuning from Idaho Rob @ ATP Trucks / Bilstein 5100s / Air Ride 5000 bags / Merchant Reman Tcase / TNR head unit.
2015.5 Denali. Dmax Allison, under construction.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
