  #1
Old 04-02-2009, 05:23 PM
tobyk321's Avatar
tobyk321 tobyk321 is offline
BIODIESEL BURNER
Default possible injector problem with a LLY
a friend of mine is have a problem with his LLY. it has a very rough idle and rattles badly. the truck is an 05 with 153,000mi on it, had its head gaskets replaced about 15,000mi ago. he says the problem came up all of a sudden, was running fine one day then bad the next. the only codes i could pull where P0202 and P2149. something with injector #2 voltage and control circuit. anybody got any ideas?
__________________
2005 lly crew cab long bed
egr DELETED!
carter lift pump
suncoast IV w/1056
straight centerlink and tierod sleeves
efi live by mcrat and team salad
ppe race valve and ported fitting
tobyk321@yahoo.com
http://www.youtube.com/watch?v=xJXVfNXywMg
http://www.youtube.com/watch?v=-l0qMUjJ2oM
http://www.youtube.com/watch?v=SMCNamkm_Jc
http://www.youtube.com/watch?v=wzfKxSwsqmA
http://www.youtube.com/watch?v=m4GGF3g8CXw
  #2
Old 04-02-2009, 05:27 PM
rgullett83's Avatar
rgullett83 rgullett83 is offline
Default
sounds like an injector harness issue
__________________
Riley
Mine: 01 CCSB Siverado frame off restored with various parts from 01-06 built lly motor, built 03 trans, 2xcp3, 100% exergys, billet s366 and much more that I wont fill this space with...
Hers: 07.5 CCSB GMC Sierra SLT LMM, XD Spys, Tuned and deleted
  #3
Old 04-02-2009, 05:29 PM
rgullett83's Avatar
Default
#06-06-04-026A: LLY Intermittent SES/MIL Lamp Illuminated, Reduced Engine Power, Fuel Injector Driver Circuit DTCs P0201, P0202, P0203, P0204, P0205, P0206, P0207, P0208, Cylinder Bank Shut Down DTCs P2146 or P2149 - (Dec 8, 2006)
Subject:LLY Intermittent SES/MIL Lamp Illuminated, Reduced Engine Power, Fuel Injector Driver Circuit DTCs P0201, P0202, P0203, P0204, P0205, P0206, P0207, P0208 and Cylinder Bank Shut Down DTCs P2146 or P2149 (Replace Affected Injector Connector Pigtail Harness)
Models:2004-2005 Chevrolet Kodiak C4500/C5500 Series, Silverado Models
2004-2005 GMC Sierra Models, TopKick C4500/C5500 Series
with 6.6L Duramax™ Diesel Engine (VIN 2 -- RPO LLY)
This bulletin is being revised to update the Kent Moore tool number used on inspecting the injector connections. Please discard Corporate Bulletin Number 06-06-04-026 (Section 06 -- Engine/Propulsion System).
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1876986&from=bcpi#ss1-1876986">Condition
Some customers may comment that the Service Engine Soon lamp is illuminated and/or intermittent along with a significant reduction in engine power (limp home mode). Upon investigation, the technician may find one or multiple injector driver circuit diagnostic trouble codes (DTCs) P0201, P0202, P0203, P0204, P0205, P0206, P0207, P0208 and bank shut down DTCs P2146 or P2149.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1876986&from=bcpi#ss2-1876986">Correction
Important: If the published diagnostics lead to an injector connector on cylinders 2 and 7, the 2 and 7 cylinder injector connectors must be repaired and supported as per bulletin 05-06-04-047B.
If the published diagnostics lead to an injector connector on cylinders 1, 3, 4, 5, 6 or 8, replace the affected injector connector pigtail harness with P/N 88988963 using the following repair procedure.
  1. <LI type=1>Complete normal SI diagnosis for the trouble codes set. <LI type=1>Injector circuit or injector coil tests may be normal until the engine reaches operating temperature. Recheck circuit/injector resistance readings with a warm engine. Important: Dealer technicians are to repair wire chafes at the Fuel Injection Control Module (FICM) as needed. Follow the correct SI wiring repair procedures. Insulate the harness from the aluminum retaining bracket with suitable material (electrical conduit or heater hose) so the harness will not chafe again.
    Important: When diagnostics are being completed for Injector Driver Fault codes, the dealer technician may notice the Fuel Injection Control Module (FICM) connector is wet or has a wet residue on it. The FICM connectors do have a type of dielectric grease that may be mistaken for diesel fuel. The FICM should not be replaced if this type of wet residue is found. Clean and dry the connectors as needed. No extra dielectric grease needs to be added to the FICM connectors.
    <LI type=1>Inspect for wire harness chafes on the Fuel Injection Control Module (FICM) wiring harness retaining bracket. This is an aluminum bracket very close to the FICM connectors. If any part of the taped portion of the harness is touching the FICM wiring harness retaining bracket, then you must look for chaffing on the wiring harness. It must be disconnected from the FICM and bent back towards the engine. Look for any chafes into the tape. If necessary peel the tape from the area and look for any chafes into the wires. Some of these chafes are very small, possibly the size of a pen tip, but could still cause injector circuit concerns. <LI type=1>If diagnosis is inconclusive, inspect the injector connections on all related cylinders. Pin drags and terminal tension can be checked with Kent Moore tool number J 35616-35. <LI type=1>Clear the trouble codes and then wiggle test the related injector connectors to see if the trouble codes can be induced. If the vehicle had only injector circuit codes for P0202 or P0207 (with bank shutdown P2146 or P2149), and the wiggle test induces a P0202 or P0207 to reset, use bulletin number 05-06-04-047B to repair the injector connectors and install the injector harness support kit.
  2. If the trouble codes or customer concern is induced during the wiggle test on any other cylinders (other then P0202/P0207), replace the affected injector connector pigtail with P/N 88988963. This replacement pigtail can be used to repair any cylinder except number 2 and number 7. The 2 and 7 cylinder connectors must be repaired and supported as per bulletin 05-06-04-047B.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1876986&from=bcpi#ss3-1876986">Parts Information
Part Number
Description
88988963
Pigtail Harness, Fuel Injector Connector
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=1876986&from=bcpi#ss4-1876986">Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N6606
Wiring and/or Connector-Fuel System - Repair or Replace
Use Published Labor Operation Time
__________________
Riley
  #4
Old 04-02-2009, 05:37 PM
tobyk321's Avatar
BIODIESEL BURNER
Default
Part Number
Description
88988963
Labor Operation
Description
Labor Time
N6606
WOW! thanks now where the hell is that icepick fix i read about awhile ago.
__________________
egr DELETED!
carter lift pump
suncoast IV w/1056
tobyk321@yahoo.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
