  #1
Old 03-31-2009, 12:58 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default power steering pump
What do you guys with bigger tires do?? I can't turn the wheel if the truck is not moving. (I can, but my girl friend can't) It's too hard to turn, is there an aftermarket pump/setup?
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #2
Old 03-31-2009, 01:27 PM
05' Ditry Duramax's Avatar
05' Ditry Duramax 05' Ditry Duramax is offline
Default
After years of owning lifted Chevy's I've just come to the fact that you can't turn the wheel while sitting still. I don't think it's a good idea to even try and turn it if your not moving. I've found out that it is very hard on the steering parts. You will wear out the idle arm, pitman arm and tie rods faster if you crank the wheel while not moving.
If your looking for a better pump I would try AGR but i've never looked into it that far. I would look at their web site or give them a call. Your gonna pay for it though. They don't give those things away.
__________________
05 LLY C/C SB
Moving right along. Gonna do stuff this summer.
  #3
Old 03-31-2009, 01:41 PM
GCncsuHD's Avatar
GCncsuHD GCncsuHD is offline
Go Pack
Default
Simply don't try to turn the wheel without the truck moving. 1. Its hard on your tires, 2. Its hard on the pump and steering box as well as the steering linkage parts. Even rolling 0.25 MPH makes it a million times easier to turn the wheel.
  #4
Old 03-31-2009, 03:28 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
PSC makes the best aftermarket pumps IMO. You can also stretch the spring out on the relief valve of the stock pump, and do a couple other things to increase pressure; but if you go too far you'll blow the back off the pump.
ben
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #5
Old 03-31-2009, 03:30 PM
Vrabel's Avatar
Vrabel Vrabel is offline
TOYAHOLIC
Default
on the older trucks (solid axle) turning wheel without moving caused strees cracks on frame around box. Not good on truck
__________________
R.I.P.
'01 Silverado 2500HD. Not Quite Stock.
Sheet Metal Workers Local #22
Creatures Of The Night Performance
ProFab Performance
  #6
Old 03-31-2009, 04:23 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Boosted steering Step on the brake and the gas at the same time you are steering
you dont need to give it much throttle and it helps
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #7
Old 03-31-2009, 04:39 PM
<--- slippery roads
Default
no...revving the engine up doesnt do anything for almost all "GM HD hard to steer" problems/cases Ive come across.
best advice I can give is get a modded pump or keep the front tire pressure up.
__________________
  #8
Old 03-31-2009, 04:44 PM
TrentNell's Avatar
TrentNell TrentNell is offline
Finally underway !!!!!
Default
my truck is the same as simons a little throttle and it steers much easier at slow speeds .
__________________
Trent Nell
01 DMAX 2500 HD = Extreme Prejudice -> EPR Triple turbo Kit, EPR Allison Transmission, Aria's Forded Pistons, Howards Xbeam Rods , Built Engine, Ported Heads , Stage 2 cam, and Gorilla Girdle all by Randy's Engine And Machine , PPE Dual CP3's with 120% stroker pump , DDP 47LMP Injectors , 2-BD Diesel 165 GPH lift pumps , Frozen Boost W/A Cooler , 4link with coil overs at every corner , and a bunch of stuff I am probably forgetting.
9.87 @ 143.56, DA=6550
www.extremeprejudiceracing.com
2001 GMC CC/LB "The tow rig" , EPR Triple Turbo's EPR Trans , EFI live , RDL Headers and mouth peice, 305/55 R20 Coopers , 5" exhaust .
  #9
Old 03-31-2009, 09:05 PM
2500HeavyDuty's Avatar
2500HeavyDuty 2500HeavyDuty is offline
Book 'em, Danno!
Default
i turn fine
but u i am on my 3rd one so far
__________________
theres a new sheriff in town
Team Borrowed Time Member #17
Danny@dieselbombers.com
  #10
Old 03-31-2009, 10:35 PM
LBZrcks's Avatar
LBZrcks LBZrcks is offline
Default
Hydraulic ram assist steering
Doubles as a stabilizer
__________________
CTS-V Sedan, Stuff, 724RWHP
16' ATS-V Coupe, Frost White Edition
Previous Dmax's
06' Chevy 2500HD CCSB 4x4, EFI Live, PPE GT40/GTX45 Twins, Socal 60s, Mike L. Trans
08' Sierra LMM CCLB Z71, Mike L. Trans, EFI Live, McRat Racing Tune 12.97@102.73
06' Sierra LBZ RCLB 4X4, Mike L. Trans, EFI Live, McRat Racing Tune 12.25@111.30
06' Chevy LBZ CST 9-11 Candy Red and Chrome
04' Chevy LB7 FabTech 8" Suncoast III w/TTS Converter
  #11
Old 04-01-2009, 03:59 AM
MAXLLY's Avatar
MAXLLY MAXLLY is offline
No Lemming Here
Default
Call the guys at Howe Engineering (google it)
I steer mine with the locker engaged. Choose ram assisted , pump and hoses.
$2000 to do it right, no labor fab required.
  #12
Old 04-01-2009, 04:09 AM
WolfLLY's Avatar
Making Chips
Default
Thats what I talking about.
__________________
LB7 ECSB 4X4
  #13
Old 04-01-2009, 04:12 AM
WolfLLY's Avatar
Making Chips
Default
Quote:
Thats not an option. I can't do a fifty point turn everytime I need to back out off a tight parking space. I need the tires turning as fast as they can as soon as possible ie sitting still or barely moving. I have to be moving at least 5 mph before it eases up on the steering. In fact I question if I even have power steering anymore.
__________________
LB7 ECSB 4X4
  #14
Old 04-01-2009, 04:15 AM
WolfLLY's Avatar
Making Chips
Default
Quote:
ben
Could you shim the spring instead of stretching it?
__________________
LB7 ECSB 4X4
  #15
Old 04-01-2009, 04:50 AM
SRomans84 SRomans84 is offline
FNG
Default
PSC motorsports makes a standard output and high output pump, the high output requires a cooler and having the hydroboost high flowed. Their hydroassist kits are the best in my opinion. I would give them a call or shoot them an email. Kelvin usually answers email quickly
I can turn my tires from a dead stop, but dont really like to.
http://pscmotorsports.com
__________________
Solid Axle Conversion 24"F 21"R, Dana 60 Front Axle, Hydro assisted stearing, 2 Bilsteins per corner, Locked rear, 5.13 gears, 44x21 STS on some skinny 20x10 wheels, PPE GT4094R, AFE stage 2 with BD turbo inlet, 4" exhaust, BD manifold, Stock tranny
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
