#1
i heard that ac delco has the best fuel filter does any one agree i need to buy a new fuel and oil filter what do you suggest?? thanks
__________________
2004 lb7 cc-sb -EFI with dsp5/ACID -fresh motor build -tranny- george -60%over injectors -batmowheel -arp headstuds -bigger pushrods -headwork and new bigger valve springs -airdog 165 lift pump, - bd manifold -4in. mbrp exhuast -white traction bars -cognito hd tierods, using sleeves now -hd swaybar endlinks -cognito steering braces and idler povit -k&n intake -ppe boost valve - isspro performax guages , hid's -alpine system 400w sub |
#2
I tried wix it last about half the time of a AC i would go with AC unless you have aftermarket filter system.
#3
try fleetfilter they sell NAPA filters that are made by wix. I run their fuel filters and oil filters but i buy the allison trans filters. I did not like the way the magnet covered up all the holes on the WIX style trans filters.
__________________
01 2500HD D/A red RC/LB 11.68@119 MPH, SOLD 01 2500HD D/A Black CC/LB, SOLD 01 S10 Blazer, 4.3, auto, 4wd 01 S10, 2.2 5 speed, lowered 4/5 |
#4
Only ACDelco here, thats the only oil and fuel filter I will run. I keep my truck all GM.
The GM fuel filter has the advancements made based on the injectors for the LB7. On the trans I only use Allison filters, like ZeroGravity said the magnet doesn't line up and could possibly restrict flow.
__________________
Brandon '03 LB7... LLY swap on the horizon EFI Live tuning by vern, jeramoosh, and The Neens If you feel like everything is under control, you're not going fast enough - Mario Andretti |
#5
AFE filters here. Fuel filter seem to have less DP than the others. Makes me wonder if it cleans the fuel like it should or just lets larger partical through.
__________________
2007 LBZ CCSB CLASSIC, EFI by Dmitri 2001 LB7 SC . Sold to Dmitri 2002 CCSB, A5k, Twin CP3, trans,ATS flywheel, 100hp injectors, cam, Rods, head work, sleeves, PPE up pipes and manifolds, Derale trans cooler, ATI dampner, Twin 150 lift pumps, 3/4 stainless tubing fuel system, custom intake manifold,co-pilot, SD sleeves, Air locker up front |
#6
Amsoil EAO-52 oil filter
Racor PFF5544 fuel filter Allison tranny filters
__________________
02 GMC 2500HD RC/LB 12.26 @ 109 Ridge Runner Diesel Performance, Big Dipper tranny, Profab Performance, Super Diesel, Creatures of the Night, AirDog, BD 02 GMC 2500HD EC/SB Bay State Diesels |
#7
wix fuel filter/ cat pre filer
__________________
2003 Chevy RC/LB. S475, Mike L trans w/1058, Airdog2, EFILive. Caltracs. Crank It Up centerlink/sleeves. 5" intake from Dmax711, Rancho's, ATS, Merchant and PPE parts, Carrillo's, ARP head, main, rocker & injector studs, Hamilton springs, LB7 cut pistons, DDP 38LPM sticks, LBZ CP3. Lowered on 22's RIP stock engine 03-16-13 2006 Chevy Colorado I5. Not stock. Tailgate Crew Member #3 |
#8
yeah i always run allison filters for the tranny i agree with all you guys on that i just put one in. just need to filter the rest of the truck now...lol
__________________
#9
They are all good filters. I use the Wix fuel filter which I beleive is a lower micron rating than the AC Delco. For oil filters as far as efficiency goes you would be hard pressed to find one that filters at a lower micron rating than the Amsoil EaO filter.
__________________
2005 Silverado Dark Charchol Metallic 4X4 CC LB LLY FOR SALE 16875.00
Amsoil, Air Lift Bags, PPE X STD, KB IOH Kit, Fumoto Valve, BD Full Flow Manifold, PCV Reroute, Res Plugged, Mag-Hytec Diff cover, PPE Deep Trans Pan, 4" SS Maganflow DP back with Lost kitty, AMP Research Power Steps, PCV Reroute MadJack Diesel Perf Discount filters & Maintenance Items So Cal Diesel Trucks Member |
#10
I use AC Delco fuel filters, Allison spin on filters, and right now I am running a Wix oil filter.
__________________
Dan 2006 Chevrolet 2500HD 4x4 CC/SB LBZ Allison PPE Hot+2 ET, S&B Cool Air Intake, MBRP 4", PCV Reroute, BD Manifold, SD Manifold, SCIV/PPE-Precision Converter/Pump Rub Fix/T-Case Brace/SoCal Diesel Flexplate By Ted @ MPL |
#11
i've read that they have redesigned the Wix filter for the magnet
#12
That is totally correct they did redesign it.
__________________
#13
Only AC Delco fuel and oil filters, and Allison spin ons. Got 15 of each here....
__________________
Matt...2008 Chevy DMax CCSB 4x4 LTZ LMM Carillos, Mahles, ARP 625s, SoCal Cam, Stage 1 Heads, 60% sticks, PPE Dual CP3, HTT 66SS/GT4718R Stainless Steel Twins, PPE High Flow Intake Manifold, Up Pipes and Headers. 6" MBRP single stack. Mike L. Suncoast 4 w/ 1057 |
#14
fram oil- wix fuel-allison trans
__________________
'01 Silverado 2500HD. Not Quite Stock. Sheet Metal Workers Local #22 Creatures Of The Night Performance
ProFab Performance |
#15
FYI Napa's fuel filter's are 4 micron @ $32 while the GM is 2 micron for $34. I bought the GM.
__________________
AFE intake, GT4094R, PPE Dual CP3, Fass 150, II 3 flow injectors, headers, Spearco Intercooler, Socal Stage 1 heads, cam, pushrods, cut & coated pistons, Carillo rods, AFI damper, balanced, DPR HV oil pump, AFE head & main studs, injector clamps, ATS Triple Lock (old-style) Torque Convertor w/ hd plates & Co-Pilot, Allison deep pan, Mike L. cooler & snake oil kit, billet input/output shafts, 6-speed conversion, Redline centerlink, sleeves, cognito braces, cal-tracs, DJM 3/5 lowering kit, Flex-a-Lite fans, Merchant & Kennedy pump rub fixes, Sears Platinum batteries, SPA gauges, EFI Live w/DSP5 tuning by McRat |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
