  #1
Old 02-03-2009, 11:16 AM
nick1camper nick1camper is offline
Gearhead
Default Best Diesel Oil???
Hey guys, just have a quick question. Looking for some opinions on a good brand of diesel oil to run. My local mechanic said to NOT run Rotella, because it does not have an anti-foam additive in it. He recomends running Texaco Ursa. I have since switched to Ursa, but cannot find a place to buy it except through him. Here in SE Iowa, we have Rotella EVERYWHERE, but not too much else that compares in price. Any suggestions?? Anyone else heard anything bad about Rotella? All opinions are appriciated!
  #2
Old 02-03-2009, 11:22 AM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
Amsoil 15w-45 Heavy Duty Diesel Oil
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #3
Old 02-03-2009, 12:03 PM
NemesisDP's Avatar
NemesisDP NemesisDP is offline
Default
Quote:
X2
__________________
2007 CCSB SOLD
2001 LB7 SC . Sold to Dmitri
2002 CCSB, Danville S464 DB, Twin CP3with LBZ pumps, No Zone trans, ATS flywheel, 60 over injectors, cam, Rods, head work, sleeves, PPE up pipes and manifolds, Derale trans cooler, ATI dampner, Twin 150 lift pumps, 3/4 stainless tubing fuel system, custom intake manifold,co-pilot, SD sleeves, Air locker up front,tuned with MOONSHINE
  #4
Old 02-03-2009, 12:08 PM
cdbright's Avatar
cdbright cdbright is offline
JUST RENT IT
Default
i am runnen DELO 15-40, we run that in all our marine diesel engins and it seems fine, the rest of the diesel guys here run the same oil in all our yachts/boats, and they get run hard, WOT all day.
__________________
2015 GMC Denali 4X4 CC/SB 2500 LML
20" MOTOs
Delete/EFI/5" straight soon to come
2008 GMC 2500 (SOLD)
EFI,all deleted,rode hard,stayed together
2009 Chev 2500 (traded) EFI, all deleted, rode just as hard as her ^^^, stayed together
  #5
Old 02-03-2009, 12:11 PM
NWTDIESEL NWTDIESEL is offline
On a Time Out
Default
After seeing the schafers demonstration i switched over. I would recommend you look into Schafers lubricants.
  #6
Old 02-03-2009, 12:33 PM
LB7Diesel's Avatar
LB7Diesel LB7Diesel is offline
Oh Boy!
Default
Amsoil synthetic in everything here!
__________________
2004 GMC 4x4 CC,SB LB7
And a little of This and That.
12.7 @ 105mph.
11.7 @ 115mph. N2O
O.S.(15189044)
" WHO IS MR.GOODWRENCH "
FORD= " Forget Out Running Duramax's"
FLORIDA DIESEL TRUCK CLUB MEMBER #13
TEAM BORROWED TIME MEMBER #13
  #7
Old 02-03-2009, 12:35 PM
MMLMM's Avatar
MMLMM MMLMM is offline
Default
Amsoil > *
__________________
2002 LB7 EC/SB
Fleece Cheetah, ARPs, LBZ CP3, Built Allison, AirDog 165, Tap Shifter, EFI Live Custom Tuning By Me, Lowering Shackles,
Original Toyo Proxies on 20" XD Spy's, S&B Intake, MagnaFlow DP & 4", and a few other gadgets and appearance mods
  #8
Old 02-03-2009, 12:38 PM
E.carter's Avatar
E.carter E.carter is offline
Default
I didnt see John Deere 15w40 plus 50 in the above posts. I run that along with many other people here and have no reasons to try anything else. my 2 cents
__________________
2006 2500HD LBZ Summit White extended cab.
-EFILIVE and dsp5 from ATP since 12k
-S480 over almost stock
-45% over tips
-Built trans with ML converter-
-Gauges-
72k as of 2-28-13 and for some reason it still runs
Eric Carter
  #9
Old 02-03-2009, 12:41 PM
cdbright's Avatar
JUST RENT IT
Default
when i was back in Minnesota , we used Cenex oil in everything, it was the cleanest runnen oil i have ever seen, however, i did throw a rod or two
__________________
20" MOTOs
  #10
Old 02-03-2009, 01:14 PM
03 D-max's Avatar
03 D-max 03 D-max is offline
Honorary "Tosser"
Default
johndeere 15w40 plus 50 it is a very good quality oil, i have no complaints
__________________
JACOB
Post Whore want to be#1
Easter Whore Member#2
Team Borrowed Time Member#23
Quote:
Originally Posted by The Neens View Post
I don't spray much...Usually only after Mexican food
03 2500hd Efi Live, SD, PPE, FASS, MBRP, K&N
  #11
Old 02-03-2009, 01:23 PM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
moved here
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #12
Old 02-03-2009, 01:24 PM
Default
Quote:
Originally Posted by NemesisDP View Post
X2
Quote:
I agree with these guys, I have amsoil in the motor and diff, so to be in the trans too
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #13
Old 02-03-2009, 03:35 PM
coldLBZ's Avatar
coldLBZ coldLBZ is offline
Default
Amsoil AME 15w40
__________________
Dan
2006 Chevrolet 2500HD 4x4 CC/SB LBZ Allison
PPE Hot+2 ET, S&B Cool Air Intake, MBRP 4", PCV Reroute, BD Manifold, SD Manifold, SCIV/PPE-Precision Converter/Pump Rub Fix/T-Case Brace/SoCal Diesel Flexplate By Ted @ MPL
2014 GMC 1500 4X4 RC/SB 5.3L
2008 GMC 1500 4x4 CC/SB 6.0L 4L70E - GONE
  #14
Old 02-03-2009, 09:11 PM
Whitetail Addict's Avatar
Whitetail Addict Whitetail Addict is offline
Rockin' the stock tune
Default
Quote:
Same here...
It seems a little thicker than most oils....actually cut down on the oil psi fluctuation
__________________
Brandon
'12 LML
'03 LB7
If you feel like everything is under control, you're not going fast enough - Mario Andretti
  #15
Old 02-03-2009, 09:12 PM
Dirtbikindad393 Dirtbikindad393 is offline
Default
I use Amsoil too 15W-40. I have Amsoil in everything that takes lubrication in my stable.
__________________
2005 Silverado Dark Charchol Metallic 4X4 CC LB LLY FOR SALE 16875.00
Amsoil, Air Lift Bags, PPE X STD, KB IOH Kit, Fumoto Valve, BD Full Flow Manifold, PCV Reroute, Res Plugged, Mag-Hytec Diff cover, PPE Deep Trans Pan, 4" SS Maganflow DP back with Lost kitty, AMP Research Power Steps, PCV Reroute
MadJack Diesel Perf
Discount filters & Maintenance Items
So Cal Diesel Trucks Member
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
