  #1
Old 01-31-2009, 06:03 PM
TIM Z's Avatar
TIM Z TIM Z is offline
Screwed by 0087s
Default Swap out Dexcool
I hate Dexcool due to all the clogged heater cores my last few GM vehicles have had even with regular replacement of the stuff.
So anyway is it Safe to switch to the green in my Dmax? Any of you guys done it?
Thanks.
__________________
2007 CCSB 4x4 Duramax LT3 LBZ
M A STG III Allison- S.C. T-Case brace/Pump rub Fix
Precision Industries M L Race Converter
EFI LIVE V2 DSP5 ACID Tune by DIESEL ADDICTION
Twin Lift Pumps/ Race Valve
6'' T.C. Strong kit/Cognito Braces/SD sleeves.
some other goodies.
2000 ECSB Z71 -6.0 LQ4 BLOWN -TVS 1900 10 psi - Comp 226*-224*/ Dyno Tuned By TJ @ Baker Engineering/SS LT Headers/ RPM LVL VI 4L70E Billet output/ Precision 2600 Vigilante Stall. Hauls Ass
  #2
Old 01-31-2009, 06:48 PM
Josh2002cc's Avatar
Josh2002cc Josh2002cc is offline
That Uncle
Default
Yes you can switch over Tim. However, if you decide to switch over just make sure you flush and flush and flush some more because if you do not, you can create hotspots.
__________________
Quote of the month.
Quote:
Originally Posted by plowboy_lbz View Post
The guy who built it isn't in hiding but no one has been able to contact him.
  #3
Old 01-31-2009, 10:56 PM
Whitetail Addict's Avatar
Whitetail Addict Whitetail Addict is offline
Rockin' the stock tune
Default
I was wondering the same thing. A friend of my Dad's has his own shop now and was a GM truck tech, he told me to get the orange Dexcool out of there and put in the green. He said he has seen it eat seals and gaskets away.
Anybody else heard of this?
__________________
Brandon
'12 LML
'03 LB7
If you feel like everything is under control, you're not going fast enough - Mario Andretti
  #4
Old 02-01-2009, 04:36 AM
malibu795's Avatar
malibu795 malibu795 is offline
Default
dexacool is oil based coolant.. will not eat gaskets...
green stuff is water based..
green stuff breaks down quicker then the dexacool.
you get coolant (green) in the oil it will turn it to a milky white dexxacool wont.
i currently am running green coolant in my truck
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #5
Old 02-01-2009, 06:18 AM
Killerbee's Avatar
Killerbee Killerbee is offline
Got Honey?
Default
dexcool and almost all alternatives, are 96% diethylene glycol. The only differences are in the additive packages, and this leads to compatabilty issues.
Old green is considered very abrasive, and highly precipitive (sandy substance forming over time, especially with poor water quality) with it's high silicated formula. It also has superior anti-cavitation properties.
I use a hybrid low silicated formula, Zerex G-05. A few drops of red food coloring and it looks like Dex.
__________________
Michael
  #6
Old 02-01-2009, 08:46 AM
TIM Z's Avatar
Screwed by 0087s
Default
Cool, I am one to change all fluids regularly and i change my coolant every 2 years or less.
Im just trying to prevent the problems assciated with dexcool, The stuff is crap IMO.
thanks for the info.
__________________
some other goodies.
  #7
Old 02-01-2009, 09:42 AM
Dzlnut's Avatar
Dzlnut Dzlnut is offline
Default
I was thinking about doing this aswell. Just to be clear there are no seal compatability problems and cooling system will perform as it does now??
__________________
Steve
2004.5 GMC 2500HD, LiLLY DURAMAX DIESEL, 5speed ALLI, 4 Inch MBRP Cool Dual Exhaust, EGR Blocked,06 Vertical Towing Mirrors,ISSPRO Gauges, ATS Billet Tierod Sleeves, 06 Silverado Tail lights, Sirrus SIR-GM1,1/2 inch Fuel Filter Spacer, Recon Smoked cab lights, Mag Tech Diff Cover, CCV Mod,EFI LIVE,6.5l lift pump and 2 Micron Filter, Cognito Braces, Suncoast Stage IV Tranny.
13.51 ...101 MPH
  #8
Old 02-01-2009, 09:56 AM
malibu795's Avatar
Default
only thing nice about it is the bitter guard in it.... amn get the shit on your lips and it stays there for a few hours
__________________
Adam
  #9
Old 02-01-2009, 10:05 AM
durallymax's Avatar
durallymax durallymax is offline
Default
my dealer said its perfectly fine, just make sure you get all of the dexcool out. and you have to change the green stuff more often.
__________________
Wife:2010 Jetta TDI "Cup Edition" Thunderbunny. Stg 2 Malone, Rawtek Straightpipe
Me:2000 Jetta TDI/5spd VNT-17, DXD S2 Clutch
Sis:2006 Jetta TDI/DSG
Puller:2003 LB7 GMC
Toy:1973 Kenworth W923
Farm:02,11,13 Duramax/Allisons
  #10
Old 02-01-2009, 01:05 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
Quote:
yes it will bu. You dont run straight coolant in your truck do you? You mix it with water, regardless if you run "dexxacool" or green. When water mixes with oil it makes white froth.
its "dexcool" BTW
all the dexcool stuff is wives tails from a friends brothers uncles mothers who had a problem with intake manifold gaskets on her 96 Tahoe with a 350.
And its got a bad name because idiots mix it with green and then say WTF DEXCOOL SUCKS IT TURNS TO SLUDGE.
I have never heard of dex-cool causing any problems with duramax's or anything. My engine has been out of my truck probably more times than 98% of you guys here and guess what, dex-cool has gone back into it every time ive refilled it.
just my opinion
ben
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #11
Old 02-01-2009, 03:09 PM
NWTDIESEL NWTDIESEL is offline
On a Time Out
Default
I have a 04' dmax and have never had a problem with Dexcool. I have 215k miles and run a A5K and nitrous. However, i did crack a trans cooler in the radiator recently and the Dexcool went into my Trans and ruined it. When i drained my trans it was real real milky. This just happend a couple weeks ago, i already got a new radiator and trans in it and put Dexcool back in.
  #12
Old 02-01-2009, 05:39 PM
Dzlnut's Avatar
Default
Dude that is some crappy luck.
__________________
Steve
13.51 ...101 MPH
  #13
Old 02-01-2009, 08:39 PM
malibu795's Avatar
Default
Quote:
BS!
i was running OEM form the factory. the coolant system had never been opened up or added to since i bought the truck when i lost my INJ and subsequently the block then crank.
the repair sheet i got form GM dealer was straight dexcool no water. and i was still makeing oil.. go read my thread on DP... it didnt start turning milky white till i got tired of spendign 15.00+ a gallon for dexcool and started dumping distilled water in the coolant
dexcool is and petrolium based coolant NOT a water based
__________________
Adam
  #14
Old 02-01-2009, 08:45 PM
malibu795's Avatar
Default
oil and dexcool
oil and water/green coolant
see the difference.
__________________
Adam
  #15
Old 02-01-2009, 10:01 PM
<--- slippery roads
Default
why?? Thats stupid and a huge waste of money. A 50/50 mix will net you freeze protection down to -34* and boil over protection to like 270*
when did I say otherwise. Yes, if you mix straight dexcool and oil it doesnt turn milky. But I dont know who runs just straight dexcool....
ben
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
