  #1
Old 01-31-2009, 01:29 PM
Cougar281's Avatar
Cougar281 Cougar281 is offline
Default Two Piece DS center support bushing
I've gotten my driveshafts, starter and transfer case out of my truck (Only thing left is the transmission), and I've found my center support bushing is shot (big surprise there ). What's the procedure for replacing it? Doesn't look like it'll be easy...
__________________
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
446.4RWHP/820.2RWTq
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
  #2
Old 01-31-2009, 02:06 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Quote:
Yake it to a drive shaft place. New unit from GM is close to 200.00 and has to be pressed on and off.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #3
Old 01-31-2009, 02:07 PM
NelsonDiesel's Avatar
NelsonDiesel NelsonDiesel is offline
Formerly StewieTuned
Default
you will need a press or the special puller to get it off.
just seperate the 2, then set it up on the puller or press...
It's real basic, just need the right tools.
I have a center support bearing (genuine Gm) if you need one.
__________________
2002 and 2007 Silverado's
PPE Hot+2 Efi Live
  #4
Old 01-31-2009, 02:30 PM
Cougar281's Avatar
Default
Quote:
Holy Crap! Almost $200 for a piece of rubber that'll wear out in less than 150k? Are there any better alternatives, or is an OE replacement my best bet?
__________________
Best 1/4 times:
446.4RWHP/820.2RWTq
  #5
Old 01-31-2009, 02:31 PM
The Neens's Avatar
The Neens The Neens is offline
BFD
Default
Mike----
Depending on mileage, would it be wise to replace u-joints and re-balance?
__________________
2007 GMC 4WD CC/SB...McRat EFI Live, Trans & Trans Cooler by Inglewood Transmission, SoCal Diesel, PPE, RKTMech
2002 Chevy 2WD CC Dually...McRat EFI Live, Trans & Trans Cooler by Inglewood Transmission, SoCal Diesel, PPE, RKTMech
Next Taps party on ??-??-??
The sooner you fall behind, the more time you'll have to catch up...
Team Arrogance Founding Member
The Gerbil Clubs founding Member#1
"Gerbil Trainer for the Stars"
  #6
Old 01-31-2009, 04:31 PM
Cougar281's Avatar
Default
Quote:
Originally Posted by The Neens View Post
Mike----
Balance may not be a bad idea, but FWIW, the driveshaft was tight from end to end near as I could tell.
__________________
Best 1/4 times:
446.4RWHP/820.2RWTq
  #7
Old 01-31-2009, 04:51 PM
The Neens's Avatar
BFD
Default
I had all that done about a year ago on my Dad's dually when the center support got funky...U-joints and balance were kinda a "just do it because it's out" type of situation...Might have lasted forever, but we do tend to abuse parts
__________________
  #8
Old 01-31-2009, 05:10 PM
super diesel's Avatar
super diesel super diesel is offline
<<<< Under Pressure
Default
NO!!! On our good lookin trucks?! Who would do such a thing?
__________________
FOR REAL POWER: Remove the static wire from ovulation bearing and let her run!
McRat Racing, SoCal Diesel, Ridge Runner, Mike L. Special, PPE, Creatures of the Night Performance
Michael
OIL COOLING CLUB
CC LB7 4X4 Dually GMC with Fluidyne oil cooler
CC LLY 4X4 3500 SRW with oil cooling coming (stock with a few goodies)
Currently for street driving and towing GT4202 and Dual Fueler from PPE
Carrillo rods, Heads, balancing, cut pistons, Head studs, Injector clamps from Guy at SoCal
Tune by Tony at Ridge Runner (Clark Kent special)
Moded LBZ CP3s and special fuel system by Super Diesel
SC Trans w/snake oiler and cooler by Mike L.
Blowoff and Wastegate by Tial
Various machining touches, built and fabed by Super Diesel
Broke motor #2 becomes built motor #4
New motor and trans oil purifiers available (dual and single elements) and vital fluid cooling components. Start saving your truck today!
SUPER DIESEL 720-404-7553 Please leave message if no answer.
  #9
Old 01-31-2009, 06:19 PM
Mike L.'s Avatar
Default
Mike----
Rebalance is not necessary. I suggested a driveshaft rebuilder because there might be more inexpensive options.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #10
Old 02-02-2009, 10:36 AM
turbo_bu turbo_bu is offline
Default
I know this is probably not an approved method, but I have a friend with a 1 ton, 4x4 Dodge dually with a 5.9 in it. After his bushing went out for the 2nd time, he simply filled up the air space around the rubber with RTV. The black stuff I think. That has held for over 50K miles. And yes, he beats on it regularly and tows heavily (typiclaly at least 15K 5th wheel back there).
I agree with the while it's out philosophy, but if your looking for a slightly cheaper route, might give it a try.
__________________
Got Boost?
2004 CC SB LB7 Auto
OS - 15189044
  #11
Old 02-13-2009, 12:24 AM
Default
http://www.dieselplace.com/forum/sho...d.php?t=292074
__________________
PPE Hot+2 Efi Live
  #12
Old 02-13-2009, 03:56 PM
radvans radvans is offline
Default
Quote:
Originally Posted by NelsonDiesel View Post
I so would have taken this...got another????
  #13
Old 02-13-2009, 09:07 PM
WanaDmaxsub's Avatar
WanaDmaxsub WanaDmaxsub is offline
Junior Member W/gray hair
Default
What would be the down side of going with a longer single?
__________________
'04 C2500HD D/A LS EC SB, Chrome Nerf bars, Prodigy, Weatherflector, Breezer, A.R.E. Z w/accordion boot, Bedrug, H2's, Bilsteins, Predator, VR Straps, Bowtie Flag, Mag-Hytec's, SPA Boost/EGT, Corsa 4" SS Muffler, BigMouth Grille, SD Manifold(s), Allison built by MikeL, Airlift Superduty bags, Banks Bighead, Fugly '06 Mirrors, Van Aaken 230, Garvin Wilderness Rack, EFILive, Cognito Idler/pitman braces, Super Hitch, SD turbo intake, ML Tranny cooler
#1 04039B (Injectors) '01-'04 LB7's Special Coverage Adjustment
#2 #04-06-04-007H TSB (Injectors) '01-'04 LB7's
#3 07057 Engine Glow Plug '02-'04 LB7's w/YF5/NE1 Special Coverage Adjustment
  #14
Old 02-13-2009, 09:41 PM
Cougar281's Avatar
Default
Quote:
More unsupported rotating mass and more stress on the transfer case output shaft would be my guess... a single piece on a CCLB would be one LOOOOOOONG driveshaft.... Imagine how long that DS would be on a CCLB 2x4 ....
__________________
Best 1/4 times:
446.4RWHP/820.2RWTq
  #15
Old 02-15-2009, 02:11 PM
Vrabel's Avatar
Vrabel Vrabel is offline
TOYAHOLIC
Default
how about ccsb? My '01 is a 2 piece, but my buddies '06 is a single. as long as no lift, wouldnt that be the way to go?
__________________
R.I.P.
'01 Silverado 2500HD. Not Quite Stock.
Sheet Metal Workers Local #22
Creatures Of The Night Performance
ProFab Performance
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
