  #1
Old 01-12-2009, 07:30 PM
55shoebox 55shoebox is offline
FNG
Default LB7 fuel pressure sensor
I would like to check my fuel rail pressure sensor does someone have the specs on how to check it (ohms). If possible is there a way to check the fuel regulator / solenoid?? I think i have reduced my problems to either of these and was hoping to check them besides just replacing the parts. Thanks Tracy
2001 lb7
__________________
2001 LB7 Crew cab HD - All stock
  #2
Old 01-14-2009, 10:12 PM
scramHD's Avatar
scramHD scramHD is offline
Its only a Baby Ruth
Default
Only way I know to check it is with a TECH II or EFI Live. I am guessing your talking about the fuel pressure regulator.
If it was a sensor, you would light a CEL.
__________________
02 LB7, cc/sb 2wd
EFI LiveV2/Neens/ATS/SoCal/PPE/SuperDiesel/Industrial Injection/TrentNell/MFrank*rip*/TTS/-McRat--Kat-/Dan
15 LML cc/sb 4wd
Zone 5"/Fox 2.0 Resi
Kryptonite UCA's/WB's/LBJ's
Cognito PISK / SB end links / PPE Stg3 tie rods
63.5mm 6+6 / QuickFuel 155
Revmax Billet Triple / vb mods / T87 tuning by me
E86b Ridgerunner / EFIv2 / l25hp
Bora 1.5"/18s/295/70
12 yz450f
polished frame/swingarm by hand by me
GYTR head / Cycra powerflo / Flo motorsports/ Vortex bars / Ascerbis X seat / ASV shorty levers/
Bazzaz Tuning/Logging /SCAR racing / Scorcher SS header /HotCams / Twin Air
  #3
Old 01-14-2009, 11:16 PM
2500HeavyDuty's Avatar
2500HeavyDuty 2500HeavyDuty is offline
Book 'em, Danno!
Default
to test it disconnect the FRP sensor with the truck runnin and observe the RP, if it goes higher than 175MPa then replace the FRP sensor.
idf it dont then thee might be a short to a ground in the wiring for the FRP sensor.
__________________
theres a new sheriff in town
Team Borrowed Time Member #17
Danny@dieselbombers.com
  #4
Old 01-15-2009, 03:11 PM
scramHD's Avatar
Default
Uh, hes got to have TECH II or EFI to observe rail pressure right? Dont think he has the RP gauge.
What symptoms is the truck having?
__________________
02 LB7, cc/sb 2wd
15 LML cc/sb 4wd
12 yz450f
  #5
Old 01-15-2009, 10:28 PM
Book 'em, Danno!
Default
yup one of them
__________________
  #6
Old 01-16-2009, 09:11 AM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Ask Henry if he hasnt allready posted it Look in the GM specs section
Look for big flucuations in the milli amps of regulator Des VS Actual
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #7
Old 01-16-2009, 08:25 PM
FNG
Default
The truck runs ok at idle but as soon as you roll onto the throttle it stumbles and feels like it is dropping cylinders. I have changed injectors - primed the fuel system ALOT and have had several people try to figure it out with no luck. I don't have monitoring equipment, or a pressure tester for that high of pressure. I have had several people tell me the next thing to check would be the rail pressure sensor or the regulator on the pump. Any help will be appreciated - Is there anybody on here that is in SE WA state that i can bring the truck too?? Thanks Tracy
__________________
  #8
Old 01-16-2009, 09:06 PM
radvans radvans is offline
Default
fuel filter
  #9
Old 01-16-2009, 09:08 PM
Default
Normally a bad fpr will have a slight surge at idle and be fine when driving.
There are some handheld tuners that can show rail pressure, ppe for example.
  #10
Old 01-16-2009, 09:45 PM
Book 'em, Danno!
Default
changing out the fca with a new one might help
__________________
  #11
Old 01-20-2009, 07:13 PM
FNG
Default
Yeah changed the fuel filter twice cut them open even first one was pretty funky next one was clean. FCA ? dont know what this is - i am kinda a newbie to all the diesel terms. I dont have a tuner or really know anybody who does - if i need to take it somewhere i will, any help and or suggestions will be help. Thanks Tracy
__________________
  #12
Old 01-20-2009, 11:13 PM
Book 'em, Danno!
Default
FCA is commonly referred to as the fpr. its on the cp3 it has 2 wires coming out from it
__________________
  #13
Old 09-15-2011, 12:19 AM
onebadduramax's Avatar
onebadduramax onebadduramax is offline
One Bad Duramax
Default
do you know where the ground is for that wire?
__________________
Just One Bad Duramax
http://www.8-lug.com/features/chevy/...cab/index.html
Current Sponsors: Ultimate Truck Gear,Hayden Automotive,Duramax Tuner,S&B filters,Going Greener Today,All ways Welding,Optima Batteries,Interco Tire Corporation,Mag-Hytec,818 Autosport,Herculiner,Setrab,Silverline,Titan Fuel Tanks,AirDog,Dee Zee,Power Stop,VIAIRCORP, MisterDecal.com Mean-Green.com Yukon Gears, ISSPRO MileMarker,Socal Diesel
  #14
Old 11-22-2011, 02:12 PM
JSmitty JSmitty is offline
The Legend
Default
Im currently having the same issue, Did you ever figure out what fixed it?
__________________
2001 LB7.. CCSB GMC 2500HD, all stock for a couple more days
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
