  #1
Old 01-10-2009, 06:35 PM
super diesel's Avatar
super diesel super diesel is offline
<<<< Under Pressure
Default Mod to turbo intake horn
Just a little test I finally preformed on a another LB7 to try to help with air flow to the stock turbo. The owner had great reviews on the mod. Said it spooled up much quicker and much harder. I need to get my reg and suction pump mod done on it next to help more. I cant believe GM did this. It's choking the turbo down. The tube exits into the turbo at 2.430". I opened it up to about 2.780" and put a 1/4 radius on the lip where it goes into the charger. We haven't done extensive testing on it yet, but it looks VERY promising for guys with stock chargers that want a little more. What do you think?
__________________
FOR REAL POWER: Remove the static wire from ovulation bearing and let her run!
McRat Racing, SoCal Diesel, Ridge Runner, Mike L. Special, PPE, Creatures of the Night Performance
Michael
OIL COOLING CLUB
CC LB7 4X4 Dually GMC with Fluidyne oil cooler
CC LLY 4X4 3500 SRW with oil cooling coming (stock with a few goodies)
Currently for street driving and towing GT4202 and Dual Fueler from PPE
Carrillo rods, Heads, balancing, cut pistons, Head studs, Injector clamps from Guy at SoCal
Tune by Tony at Ridge Runner (Clark Kent special)
Moded LBZ CP3s and special fuel system by Super Diesel
SC Trans w/snake oiler and cooler by Mike L.
Blowoff and Wastegate by Tial
Various machining touches, built and fabed by Super Diesel
Broke motor #2 becomes built motor #4
New motor and trans oil purifiers available (dual and single elements) and vital fluid cooling components. Start saving your truck today!
SUPER DIESEL 720-404-7553 Please leave message if no answer.
  #2
Old 01-10-2009, 08:37 PM
maine04max's Avatar
maine04max maine04max is offline
Default
looks like a good improvment . what did you use to open it up with?
__________________
9/26/09 450 rwhp & 869
4/01/10 mild built motor
05/23/10 656rwhp 1190 trq 12.06 @113
07/20/10 Homebuilt 366 /480 twins
10/23/10 11.74 @121 soft launch
9/11/11 11.39 @120
  #3
Old 01-10-2009, 08:42 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Where do I send the check Michael? It's about time you got your ass back into development.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #4
Old 01-10-2009, 08:56 PM
mytmousemalibu's Avatar
mytmousemalibu mytmousemalibu is offline
Cut your ride, sissy!
Default
X2, what did you use? I knew of this but i noticed that by opening it up, looks like airflow would go into the void around the inducer? so i left it alone. Seems opening it up and how bout a bushing sandwiched between to flow uninterupted into the compressor would be a hot trick? Thanks for posting, i might take on this endevor too!
__________________
PLAN-B...Replacment of the Ally for a 5spd Bruno/Lenco
03 2500HD......Custom Compound Twins, this winter maybe sooner?
Ind. Injection Dual Feed Line, BD/TiAL BOV, BD Fullbore, FS-2500,
Coolingmist Stage2 M/W, TTS fuel pick-up, S&B intake, 6" exh, In-cab boost control
50% ExtrudeHone nozzles, Modded CP3, MytNasty Tuned
Summit Billet LP, Intake Heater Delete EFILive V2
LOWERED,Hehehe TEAM BORROWED TIME, Member #12
Ghostly Lucky #13
Newest DD: 87' M-B 300D W124 OM603 3.0L 12v SOHC I-6, Stock turbo. Just cranked ALDA and a gutted kitty. Reasonably quick and bone stock! Future plans: OM606 24v I-6, big turbo, DervTuning 7.5mm Bosch M-pump, exhaust, 5spd, intercooler, fab'd intake, Some cosmetic work. Diesel isn't just a fuel, its a way of life...
  #5
Old 01-10-2009, 09:01 PM
<<<< Under Pressure
Default
This was no fun to set up to cut (need a jig). I have a machine shop (regained after every thing was stollen), and I just bored it (very carefully). I'll get a few made up to send out and do an exchange program. PM sent Mikey.
__________________
Michael
OIL COOLING CLUB
  #6
Old 01-10-2009, 09:07 PM
Default
What do you think about a bushing to smooth airflow into the compressor?
__________________
Ghostly Lucky #13
  #7
Old 01-10-2009, 09:53 PM
<<<< Under Pressure
Default
I don't know about the bushing. This pretty much smooths it out and helps the transition for the air. The next ones will have a larger transition for the radius. This and the CP3 regulator with suction pump mod (some will remember me starting this back in early 05) is awesome power mods for stock looking trucks (reg on moded trucks as well). We don't know how many HP these all add together over a stocker (comparable mods). One thing we do know. Both as individual mods decrease spool up time noticably and we found out back in 05 the reg moded offered increased HP and even more in the torque department. This intake mod was very noticable to the driver through the powerband. He said it spooled quicker too (stands to reason because the stocker intake is basicly a turbo bushing reducer. This truck testing it is a manual 6 speed, and it is importaint to him to reduce lag. He said he was happy.
__________________
Michael
OIL COOLING CLUB
  #8
Old 01-10-2009, 10:03 PM
Turbo Buick 6's Avatar
Turbo Buick 6 Turbo Buick 6 is offline
Default
Nice work
__________________
4.5 CLUB
Member #2
06 2500HD LLY reg cab 4wd
Ever feel like lying, down inside a grave
Listen to the elegy, a buyer of the hate
Ever dance beside the devil, taste the barrel of a gauge,
Ever pull the trigger, the light begins to fade
Feel like slipping away
  #9
Old 01-10-2009, 10:07 PM
<<<< Under Pressure
Default
Quote:
Originally Posted by Turbo Buick 6 View Post
Nice work
Thanks for the kind words. Thank you much. I'm just sorry to say that I'm quite a few years over due on this one sad to say.
__________________
Michael
OIL COOLING CLUB
  #10
Old 01-10-2009, 10:11 PM
Default
Quote:
Better late than never, saddly many of us have more importent things in our life than trucks
__________________
4.5 CLUB
Member #2
  #11
Old 01-11-2009, 12:16 AM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
Glad you got everything back Michael
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #12
Old 01-11-2009, 12:24 AM
LBZrcks's Avatar
LBZrcks LBZrcks is offline
Default
Looks good!
__________________
17' Denali HD CCSB Z71 Stock
Previous Dmax's
06' Chevy 2500HD CCSB 4x4, EFI Live, PPE GT40/GTX45 Twins, Socal 60s, Mike L. Trans
08' Sierra LMM CCLB Z71, Mike L. Trans, EFI Live, McRat Racing Tune 12.97@102.73
06' Sierra LBZ RCLB 4X4, Mike L. Trans, EFI Live, McRat Racing Tune 12.25@111.30
06' Chevy LBZ CST 9-11 Candy Red and Chrome
04' Chevy LB7 FabTech 8" Suncoast III w/TTS Converter
  #13
Old 01-11-2009, 06:33 AM
malibu795's Avatar
malibu795 malibu795 is offline
Default
hmm havent looked at mine..
what is the opening on the compressor cover?
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #14
Old 01-11-2009, 09:33 AM
<<<< Under Pressure
Default
Quote:
I can't remember Adam. I'll have to go out to the shop and measure it. I forgot the dim. It's around 3.150 dia. To many other things going on. I'm going to make a new intake mount as well that will replace this altogether and a larger intake can be hooked up for hopefully even better gains.
__________________
Michael
OIL COOLING CLUB
  #15
Old 01-11-2009, 09:34 AM
<<<< Under Pressure
Default
Quote:
Not everything back yet, but hopefully soon. Thanks Kat.
__________________
Michael
OIL COOLING CLUB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
