  #1
Old 07-12-2018, 02:32 AM
Cfeury208 Cfeury208 is offline
FNG
Default Stage 5 PPE build in transmission won't build pressure
I recently had a stage 5 PPE kit installed in my 03 LB7, put the transmission back in the truck and I wasn't getting any pressure to my lines. Pulled back out taken back to the shop after replacing everything electrical on the transmission and checking the internal filter and was found the converter relief valve was stuck open. It was "fixed" and put back together. Now I'm getting no pressure whatsoever out of lines or pressure port. I'm tired of dealing with this and being kicked around on what's wrong. Any suggestions? Also the only code being thrown is P0701. And anytime the truck is put into gear it says "range shift inhibited"
  #2
Old 07-12-2018, 02:52 AM
PureHybrid's Avatar
PureHybrid PureHybrid is online now
Isuzu Shakes IT
Default
How much fluid did you put in it? Did the pump get damaged installing the converter?
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
  #3
Old 07-12-2018, 03:06 AM
FNG
Default
To my knowledge the pump wasn't damaged when the converter was put in and after it was pulled the second time the individual who built it said the pump was fine and everything looked great. I put over 2 gallons in it plus the converter had oil in it. The reading on the stick is at the full hot mark.
  #4
Old 07-12-2018, 03:43 AM
Blackmax123 Blackmax123 is offline
Default
Is the sump filter still seated up in place?
__________________
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
  #5
Old 07-12-2018, 03:47 AM
FNG
Default
Yes it is.
  #6
Old 07-12-2018, 03:49 AM
Default
Sorry just read part about checking the filter. Make sure the converter is fully seated into the pump before its bolted to the flexplate.
If you remove the torque bolts the converter should push back some making a space between it and the flywheel.
__________________
  #7
Old 07-12-2018, 04:05 AM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Bet the bell housing gasket is in backwards...
__________________
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #8
Old 07-12-2018, 05:01 AM
FNG
Default
When putting the converter in it was pushed in so that there was a gap. Converter even "clunked" in as if it were in place after spinning and pushing it on to the shaft.
  #9
Old 07-12-2018, 06:40 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Quote:
^^^^^^ This
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #10
Old 07-12-2018, 06:43 AM
FNG
Default
The gasket tabs should be to the passenger side of the truck correct? I won't be able to look until this evening.
  #11
Old 07-12-2018, 07:32 AM
Mike L.'s Avatar
Default
Quote:
Never go by the tabs. They can still be backwards. If the so called builder is worth a shit, he will be able to tell you which way he installed the gaskets. If he can't, then he is a hack.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #12
Old 07-12-2018, 07:39 AM
FNG
Default
Great. He was a trusted name in my area so I went with him but this a huge setback for me if he was indeed wrong considering he's messed up once
  #13
Old 07-12-2018, 09:47 AM
PureHybrid's Avatar
Isuzu Shakes IT
Default
I guess I assumed the gaskets were correct, being that the stator assembly had been removed and checked already. I suppose if they installed them wrong once it could happen again.
__________________
Jesse
  #14
Old 07-12-2018, 09:51 AM
TheBac's Avatar
TheBac TheBac is offline
Default
Take it back. I realize your time and fuel costs rise, but the builder who screwed this up should man-up and at least partially reimburse you for those costs along with repairing the f-up.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
