  #121
Old 06-18-2018, 11:45 AM
Chevy1925's Avatar
rear end is pretty close to dialed till the front end gets done. played a bit off road by my parents house Saturday night and scared Erin. there was a good sized drop off onto the street as we were leaving and we were doing about 25-30mph. Probably only about 18"-24" tall. i said "Hey, lets drop this onto the street!" i get yelled at with " NO, DONT YOU F***ING DO IT!" as she starts grabbing grab handles. jump off it as if nothing was there. after she pulled her shorts out of her ass and brooklyn quit giggling, she says "ok, that was cool" lol.
so its time to start thinking about the front end. going to finish ordering the rest of the parts i need (or think i need) as i wont be able to finish it till i finish the bathroom remodel we got going on.
front end is going to be built around this
James
best time to date: 12.39
Tailgate Crew Member #4
  #122
Old 06-18-2018, 03:21 PM
malibu795's Avatar
malibu795 malibu795 is offline
So you bypassed GMs electronic proportion valve crap, iirc I got yelled at for wanting to do exactly that to get more rear brakes bias..........
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
smooth seas never made a skillfull salior
  #123
Old 06-18-2018, 03:33 PM
Chevy1925's Avatar
no, this is by no means that far advanced lol. this had a load sensing proportioning valve that would add more brake bias as you loaded it down via a lever and spring. it never worked while i had it. this thing dont even have ABS factory (was an option then) . with the bigger rear drums, even at 57% i can lock the rear up before the front in a very hard stop but that was prior to the added weight i put in the back as "ballast" for when im not loaded down for a trip. maybe ill do a panic stop on the way home and see what happens.
James
  #124
Old 06-18-2018, 03:56 PM
gmduramax's Avatar
Shits broke
If your brakes are functioning 100% GMís proportioning valve works the way itís supposed to.
10.98@124mph
Tailgate Crew Member #1
  #125
Old 06-18-2018, 08:44 PM
malibu795's Avatar
I made a thread about increase rear brake bias especially when towing...
of the almost 400,000 miles I put on my lmm towing... It would not take very mush effort to get the rear to come around the front, or the little to no rear brake only front brakes at slow speed, front locks rear still turning ABS kicking and you accelerate.
my front brakes would smoke and boil brake fluid long before my rear would while towing.
I could also tell which axle was braking more by how the truck dove/squatted under braking when loaded 90% of the time any light braking was front axle only and was not enough to activate trailer brakes
avg class 5+ truck runs 30/70-10/90 bias to the rear
semis don't apply front axle brakes till after 50% applied brake pressure is reached...and at that time its usually considers a hard stop or panic stop
avg class 4 and smaller vehicle.... 90/10 front rear..
80/90s duallies has a DPR valve on the rear line to control how much rear brake actually happen given squat of the truck
but hey what do I know, most here barely tow anything more than 10K much less double or triple that.
Adam
  #126
Old 06-19-2018, 12:10 PM
Chevy1925's Avatar
Boy this sucker went off topic faster than Adams rear brakes come on (sorry buddy, I just had too )
James
  #127
Old 06-19-2018, 12:15 PM
malibu795's Avatar
My mutt is completely opposite
No prop valve
No abs
1/4" line throughout
Not first curve this thread has seen
Adam
  #128
Old 06-19-2018, 12:28 PM
Chevy1925's Avatar
No prop valve
No abs
not even a chuckle.... you know it was a good pun, admit it
in the dirt, it will probably get opened all the way up to setup for corners. way easier than using an e-brake as im most likely going to ditch mine. its creating more headaches than its worth.
James
  #129
Old 06-19-2018, 03:29 PM
malibu795's Avatar
they have in cab adjustable versions or manual prop valves
there happy?
Adam
  #130
Old 06-19-2018, 03:30 PM
Chevy1925's Avatar
there happy?
no, its too late now.
James
  #131
Old 06-19-2018, 03:42 PM
gmduramax's Avatar
Shits broke
So about that L5P tuning
10.98@124mph
  #132
Old 06-19-2018, 03:44 PM
malibu795's Avatar
Adam
  #133
Old 07-02-2018, 01:47 PM
Chevy1925's Avatar
his weekend was the first real test on the rear end. Been basically street testing on the worse roads i could find to and from work. Thing worked awesome from the old stock setup. need to add more spring back there and make some valving changes but i was more than pleased. Also bottomed out HARD on a few "oh shit" moments and everything held up awesome. Bumps could have used a bit more air pressure to smooth those oh shit moments out but for a first run, im stoked!
We started in wickenburg and drove dirt roads to Golden Valley. part of it was the AZ peace trail, other was home brewed Google Maps "lets see where the hell this goes". 160-170 miles of roads that were in better shape than i expected. Still some good rough sections though. This is part of the reason i love this state. Not very many places you can run cross country else where. High of 105 that day but A/C does not care about that
started in washes crossing under train tracks
my gate bitch
Powerline road.
Old ass buss out at Alamo Lake
coming down into Yucca Valley
hauling ass to Golden Valley
Shitastic drift with all 155hp letting loose.
This is all prerunning routes to get to Laughlin for a trip i eventually want to do. I was promptly told "no, we are overlanding" by my buddy Sebas. i said "f**ker, thats what the f**king hipsters call it accept they spend money on everything else but making their shit go fast in the desert". it was then decided we were "Brolanding". screw it, close enough.
James
