  #31
Old 10-21-2017, 11:38 PM
chrisuns's Avatar
chrisuns chrisuns is offline
Default
Quote:
Originally Posted by Dozerboy View Post
Lol Let's see properly taking care of a vehical and posibly burning a fraction of a cent of fuel vs a $2500 turbo plus install. Yep you better not let your vehicle dictate anything to you. Heck why even change the oil and filters.
Let's see, 2 minutes "cooling down" x 300 days a year = 600 minutes x 11 years of duramax ownership = 110 hours I would have pissed away, sitting in a truck, waiting for it to cool down.
That's time spent otherwise working, which I do during the day; when I am driving my truck. That would pay for several turbos over again in the course of a year, at my rates and residuals I manage (Let me remind you, I've never had a major failure; outside of lb7 injectors).
Let's not get into the debate of the amount of fuel that would have been wasted away, idling over that time period. Money is money, but there's a reason some people have it as a tool, and others work their lives away for it.
Also, never in my post did I mention anything about neglecting the maintenance of my vehicles.
So you're correct. As much as I enjoy the hobby of my trucks, I will not allow it to dictate how I treat it or drive it; because, it is a vehicle, not my life.
__________________
2007 LBZ - Few go fast and handling parts.
  #32
Old 10-22-2017, 05:46 AM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
Sky View Imaging
Default
Quote:
Originally Posted by OregonDMAX View Post
Unless water temp is 200+ and oil is 220+ then your point is mute
It’s not mute. I can talk just fine. It’s moot.
And it’s common sense. Coolant circulating through a turbo cools it.
__________________
06 Chevy LBZ
Olympic White Built Motor/Trans Bullseye s375 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76@115.12
08 BMW 528xi
Alpine White Brown Dakota Leather Premium/Cold/Smoker Pkg LED AEs MTec D1S 50% tint
2000 Buick Regal GS
Bright White Lowered Homemade CAI 4500K HIDs Supercharged Beater
  #33
Old 10-22-2017, 07:25 AM
beach_33's Avatar
beach_33 beach_33 is offline
Default
I haul my boat regularly (16,000lbs) if I happen to be working the truck hard which I do.... I will leave the truck run for a min. But I just hit the remote starter button and then take the key out. The turn it off when Im ready. But I also think just a min of regular driving is enough cool down time. On top of that I usually have to gather my shit before I get out of the truck. Then I shut her down. Plenty of time
__________________
Sold:efi live. thank you pat and kat.
68mm cheetah
fleece modded regulator
diamond eye down pipe
bd manifold
airdog 150
custom 5in pipe to 6in powdercoated stack
fleece sc stage 4 . thanks again brayden
team borrowed time member #8
cedarfalls raceway- sep/27/09 12.63@107mph
2016 2500HD z71: all stock except rims and tires
2006 Volkswagen Jetta tdi
  #34
Old 10-22-2017, 11:08 AM
Digmax Digmax is offline
Default
I used to have to wait for cool down but now I just drive the last little bit easy and shutter down usually 400 degrees . On warm up to understand what happens take a accetalyne torch and cut a thin strip of steel and watch it warp and then imagine the inside of your cylinder making a thousand degrees and your block and crank and oil 15 degrees or whatever ambient temp is. That high cylinder temp makes all of the material in your engine expand at a terrific rate. Once everything has stabilized the high cylinder temp isn't an issue. Your engine needs a gradual temperature transition for component longevity. Just my uneducated opinion. Someone with some actual schooling chime in here.
Sent from my SM-G935V using Tapatalk
  #35
Old 10-22-2017, 11:22 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
Someone piss in your Cheerios or what? Did you read any posts? No body said it had to cool down every time you drive it. That's the point of this thread.
Its aparent your in a bad mood so I just leave this other little tidbit of info for you and be done here. 110 hrs of idling is only about a tank of fuel. So in 11 years no loss there.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
