  #1
Old 04-04-2017, 05:35 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default Trailer Weight Distribution Calculator
I made a "visual" weight distribution calculator in excel.
it doesn't take into account the difference in the trailers own weight throughout the trailer so if anyone has base line percentages that will increase its accuracy.
I made it more for a camping trailer for loading up or building the inside and wanting to see how placing different items such as the shower, toilet, beds, cabinets, etc affected the tongue weight based on where i would place them. but it should work for any trailer really.
Now, it is only set up right now for a 27 foot trailer but i will likely make it scalable for any length trailer with some more formulas in the future.
so, before you yell at me and tell me it is not accurate, I already know that. it was more for rough calculations and a visual aid to seeing how the weight distributed across the trailer changed the load on the tongue and tires
make sure to remove the ".doc" from the end of the file name to make it an excel ".xls" file
Play around with it and let me know what you think
File Type: doc Trailer Weight Distribution Calculator.xls.doc (35.0 KB, 23 views)
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #2
Old 04-05-2017, 10:36 AM
2004LB7's Avatar
Default
Version 2 with auto adjusting for trailers beds up to 50 feet and dovetail up to 10 feet.
thanks Jason
File Type: doc Trailer Weight Distribution Calculator V2.xls.doc (66.5 KB, 4 views)
__________________
  #3
Old 04-10-2017, 11:30 AM
2004LB7's Avatar
Default
some small tweaks to the formulas so it doesn't calculate weights that didn't get removed if the trailer was shortened. make it less error prone
File Type: doc Trailer Weight Distribution Calculator V2.xls.doc (73.5 KB, 10 views)
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
