  #31
Old 05-29-2017, 07:39 AM
matt78 matt78 is offline
Finally boosted launches
Default
This happened to me recently in my 16 work truck. Plug on the trailer was wet. Just my experience.
__________________
2015 ltz 3500. 97 monaco bus. 2016 2500 gassee. 2001 burb.
  #32
Old 05-29-2017, 11:41 PM
LBZ's Avatar
LBZ LBZ is offline
Default
Quote:
Doesn't help the 7 pole plug is upside down either. That seal isn't 100% when you use a pressure washer.
Sent from my D5803 using Tapatalk
  #33
Old 06-04-2017, 07:01 PM
Ron Nielson Ron Nielson is offline
Gearhead
Default
It would sure be nice if Chevy would publish a well tried and tested decision tree to help those troubleshooting problems with the integrated trailer braking system.. Lots of problems can crop up, and often do, and no rhyme or reason what they might be.
__________________
Ron Nielson
2008 Chevy Silverado LT, SRW, Crew Cab, LB, LMM/Allison, Rear lowered 2": otherwise, fully stock at this point. Edge Insight CTS
  #34
Old 06-04-2017, 09:27 PM
Troysalm71's Avatar
Troysalm71 Troysalm71 is offline
Default
Mine was similar to what another member said on here. Trailer brakes didn't function,service stabiltak abs light was on and no traction control, tracked it down to left front wheel speed sensor. After the lift being put on the connector broke coming into contact and out of contact, zip tied it good ever sense.
__________________
2011 cc/sb, efi Kory , 1058 suncoast, stock injectors, HSP y bridge, HSP inter cooler piping, HSP turbo inlet, PPE down pipe,s&b intake, fass 260 ,fleece 10 mm stroker,cp3 conversion from fleece, afe 4 inch stainless ,welded water pump,pcv re routed to moroso catch can,triple pillar autometer pyro fuel pressure rail pressure edge cts2 monitor for everything else, 5 inch zone lift, 35x12.5x20 toyo mts, 20x10 fuel hostage 2 piece wheels. s369 sxe single next
2005 ec/sb was my first for duramax. Limped trans A ton an kept going.(Sold)
2001 Cummins 6 speed was my first diesel. (Sold)
1994 sc/lb 6.5 nv 4500 130000 miles.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
