  #46
Old 09-30-2017, 05:57 AM
clrussell's Avatar
clrussell clrussell is online now
pro-procrastinator
My ls project is on the back burner. Found a potential house
01 ext cab, Billet ihi, trans with g converter, sac 45s, tap shift, lots of black, everything built by myself with help from some of the best in the buisness.
Thanks to everyone on this forum who has helped me and those whom I bought parts from.
Special thanks to Evan, James, Russell, Mark and all the others I'm forgetting.
  #47
NC-smokinlmm's Avatar
<<<Future tuna killer
[QUOTE=A. Stock Lbz;1080316]
Originally Posted by NC-smokinlmm View Post
. If you are running 93 you will blow out the main bearings before you run out of fuel...[TE]
Please explain this.
The weak link is going to be bearings in a stock gen 4 motor, start worring about mains over 600 rwhp especially if the motor is in a heavy truck with big tires. I was referring to 93 bc if you want to run e85 you will need larger injectors than if just running 93. 600 rwhp isn't a problem on 93 with 6.2 flex fuel injectors so there you go.
2001 LB7 ECSB SL Built trans, batmo, lbz cp3, everything else, etc... Sold...
2006 LBZ CCSB SLT < My first, Superchips Flashpac... Sold...
2008 LMM CCSB SLT < Blue beast. way too much to list.... Sold...
2015 LML CCSB Denali < Lifted 20's/35's Deleted Airdog ETC. Sold...
2016 LML CCSB Denali < Lifted 22's/35's >I officially need help.
2010 1500 RCSB Denali clone <Lifted 22's/33's, 5.3, 6L80, TVS1900, Mayhem tuned, etc ...
2015 Corvette Stingray LT3 White on Black
  #48
Old 09-30-2017, 09:46 AM
AZlml's Avatar
AZlml AZlml is offline
Svo 42# can be picked up for dirt cheap if you're staying NA. As mentioned the deka 80# would be plenty for a stock bottom end with a turbo.
Bryan
11 CCSB 4x4
Full delete, EFI by Ridgerunner, 5" FloPro, Profab manifolds and up pipes, Wehrli cp3 conversion, 3" downpipe, S&B intake, AD165 4G, DHD tie rod sleeves, 2" rear drop shackles, Rancho RS9000XL
