  #121
Old 10-20-2017, 02:15 PM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default
Quote:
Originally Posted by IdahoRob View Post
I have a hard time believing that storing injectors for a year, packaged correctly, would be an issue. In racing and pulling circles this is done all the time. I have done this many times and have installed my cp3s and injectors that have been sitting packaged on the shelf for over a year and have never had an issue.
Now i can see if they are left open or the diesel had water in it but i don't see blaming the injectors being stored the problem.
Looking at that photo, i can see contamination and/or rust from improper storage could surely be an issue.
Just my experience in over ten years of racing and storing fuel parts while new builds are happening.
X2 I put an LBZ back together that was taken apart by another shop and the truck sat for two years. The injectors were not seal or cleaned and the truck started and ran fine after I put it together.
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #122
Old 10-20-2017, 02:51 PM
Tothemax's Avatar
Tothemax Tothemax is offline
xgmtech
Default
just going to throw this out there. I have used both cp3s and injectors that have sat for over 2 years with no issue. more than 1 time too. idk
__________________
2017 l5p cc/sb ltz z71 (stormtrooper edition)
06 lbz ec/sb. stock motor, Danville 4094s2r, built trans by me, limitless 1078 converter, 60% sticks, S&S 12mm pump. dyno tuned by mark @ Danville. 775hp 1383ftlb
best so far. 11.59 @ 116.55 1.707 60ft
06 lbz rc/fb dually work truck. Danville tuned
  #123
Old 10-20-2017, 03:16 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Default
I have unfortunately seen it happen more then once, it's call shelf shock and it happens!
__________________
06 LBZ "White Lightning" 2wd rclb DP built motor Carillo, 15.25:1 "Finger" Oval Pistons w/reliefs, Socal Titanium upgraded springs on Stock heads w/Socal Billet injector holddowns,ARP, head-main-rocker studs,Soca Billet mains& Dampner, Chromoly pushrds, DP B72mmstg2R1VGT/StainlessDiesel S472/87 1.0SS triples, DHD Cast SuperHighflow intake, Exergy 14mmCP3 & 250%inj,Fass, PPE Race Valve PPE Manifolds, Banks Technicooler, AFE Boost tube, SC GMax6 Goerend "G" Grizzly Locker 3.42 gears, 1198+++hp 2k+ftlbs
Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
159.8mph in standing 1/2mile
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out B68mm Stg2R
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
  #124
Old 10-20-2017, 04:05 PM
Josh154's Avatar
Josh154 Josh154 is offline
Default
I just finished swapping all stock injectors back in and flashing the new tune from mark right now. Let’s hope she fires!!
__________________
08 CCSB LMM - HSP 369sxe kit, 10mm S&S cp3, built trans with suncoast 1058, supporting mods and Danville tuned
Best 1/4 mile
12.86 - 104.92mph
  #125
Old 10-20-2017, 04:13 PM
Josh154's Avatar
Default
It runs!!!
__________________
Best 1/4 mile
12.86 - 104.92mph
  #126
Old 10-20-2017, 04:24 PM
Awenta's Avatar
Awenta Awenta is offline
Default
Who knows the real history of these injectors anyway. Let alone how they were stored.
What about vacuum packaging them?
I used atf in cp3 though.
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #127
Old 10-20-2017, 08:22 PM
TeaBagger2006's Avatar
TeaBagger2006 TeaBagger2006 is offline
Im a Garrett Nut Swinger
Default
It's a crap shoot with used parts is what I've learned..... More specifically FUEL SYSTEM PARTS
__________________
Joe
Loosest Tailgater in USA
2006 GMC 3500 D/A LBZ SRW CC/LB SLT 4x4
8" Fabtech lift 37x13.5/20 tires....Mike L trans....some go fast goodies
13.20@106mph
'06 Jetta TDI
  #128
Old 10-20-2017, 08:23 PM
Josh154's Avatar
Default
Truck is running great on stock injectors. This is definitely not user error, injectors are defective forsure.
__________________
Best 1/4 mile
12.86 - 104.92mph
  #129
Old 10-21-2017, 07:19 AM
wilrob's Avatar
wilrob wilrob is offline
Displaced Texan
Default
Quote:
Good it's running, bummer the injectors are whack
__________________
Wil
2008 CC/SB LMM SLT
EFI by Idaho Rob | 5in Straight Pipe | Isspro Ev2 Gauges | Titan 52gal Fuel Tank | Banks Intake/Filter | DJM 3in Drop Shackles | PCV Reroute | Custom Power Steering Cooler
1983 c10/Cummins Conversion - On Hold
"I think we missed the turn..." - Somewhere in Baja
  #130
Old 10-21-2017, 08:51 AM
Josh154's Avatar
Default
I just really hope PayPal pulls through and makes it right.
__________________
Best 1/4 mile
12.86 - 104.92mph
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
