Old 11-25-2017, 05:59 PM
weazel's Avatar
weazel weazel is offline
Default Need some help locating harness..
Where can I find the male end of the wiring harness under the dash that the apps and brake switch harness hooks to? The throttle is plugged and as well as the brake switch, but I canít for the life of me find where this other ends plugs into..
This is an 08 3500hd 4x4 LMM
Any help will be greatly appreciated so I can fire up this engine I just put back together.
88 Chevy 1/2 ton- LB7 conversion project
93 Chevy K3500- CR Cummins conversion project
05 Chevy LLY 5" ex, EFI DSP5
Old 11-25-2017, 07:21 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Are you talking about the plug on the other side of the firewall in the engine bay? It's between the driver side hood hinge and the master cylinder.
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
Old 11-25-2017, 08:02 PM
weazel's Avatar
I know on the older models that’s where it is at, will it be the same for this lmm?
Old 11-25-2017, 08:46 PM
weazel's Avatar
Iíve got another LMM truck here I went and compared this one to. Thing is, this other truck has the adjustable pedals, and the one Iím working on now does not.
On the spare truck, the harness goes through the firewall and connects to the harness just behind and below the fuse box.
I went back to this truck and looked, there is a connector, but itís already snapped into another connector that goes into the wad of wires, and goes through the firewall in a large bundle and grommet.
So I need to search more under the dash I think to find this other end.. and the original owner of this truck that took this harness out doesnít remember exactly where itís at, just that itís on the left side close to the pillar.
Old 11-26-2017, 12:28 PM
weazel's Avatar
Bump, still not having any luck...
Old 11-26-2017, 01:10 PM
weazel's Avatar
Wow!
Ok, took all kinds of parts off the dang dash and finally found the dang connector. It’s directly behind the gauge cluster, tucked under the dash piece that pops out from under the windshield, also where the little bulb looking thing that controls automatic daytime lights and what not. Can’t believe the throttle sensor plug goes all the way up in there
Old 11-26-2017, 01:39 PM
Hambone's Avatar
Hambone Hambone is offline
Always learning
Thanks for the RnD
Can you reach it through the radio box out or did you need to remove the whole dash?
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
Old 11-26-2017, 04:01 PM
weazel's Avatar
Not too sure about removing the radio box, but it was actually way easier than I thought it would be..
If you remove the pillar, remove the dash piece that is directly under the windshield that snaps down into the main part of the dash, remove the knee bolster and follow the small harness that connects the throttle sensor, and brake light switch, it goes up and snaps into another connector that is almost directly behind the gauge cluster. You can’t get to it by removing the gauge cluster as behind it, is a plastic “wall”. But being as you just need to remove three panels, it was way easier than I had thought, now that I’ve seen it lol.
  #9
Old 12-09-2017, 08:08 AM
weazel's Avatar
Hereís a video I made to kind of show where the harness goes
https://youtu.be/WAlayNW3nDI
  #10
Old 12-09-2017, 09:40 AM
quinton's Avatar
quinton quinton is offline
Ya I would have had the whole dash out by the time I found it! Lol. I never would have guessed it went up there.
EFIlive dsp5 by me, Built trans by me, 68 danville, stock fuel, lifted. died 6/20/2013 Cracked piston. Best time 12.75 on fuel
Alive 11/15/13: lowered, Built motor, s475, plenty of fuel, plenty of spray. Tune 3 fuel only 11.84 @114, Tune 5 little bit of spray 11.45 @ 121. Both times with melted turbine wheel, loose turbo from pedestal with blown out flange gasket. .
