Old 11-05-2017, 01:50 PM
Josh154's Avatar
Josh154 Josh154 is offline
Default Service 4wd
Been having a intermittent service 4wd issue since last winter. Sometimes it will go into 4wd fine and other times it wonít. I just replaced the front diff actuator and encoder motor. Well Iím still having the issue so we read the codes with a solus last night and getting c0379 for the front diff not engaging. I just changed the diff fluid today, it was a chocolate milk brown looking and didnít have much metal shavings on the plug. About the same as last time I changed it. Also sometimes when it says itís in 4 hi itís really only in 2wd and sometimes it goes into 4 hi just fine. Other times it wonít even go and just says service 4wd system. Any ideas?
08 CCSB LMM - HSP 369sxe kit, 10mm S&S cp3, built trans with suncoast 1058, supporting mods and Danville tuned
Best 1/4 mile
12.86 - 104.92mph
Old 11-05-2017, 02:06 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default Service 4wd
What kind of encoder motor did you put on it? GM or aftermarket?
2003 GMC CCSB LLY
Built by me, tuned by me.
Old 11-05-2017, 02:16 PM
Josh154's Avatar
Gm. You can hear the motor clicking like the t case is going into 4. Both motors have gave me the same symptoms and both actuators have gave me the same symptoms.
Best 1/4 mile
12.86 - 104.92mph
Old 11-05-2017, 02:19 PM
IOWA LLY's Avatar
Yes, its really me
Have you checked the grounds good?
2003 GMC CCSB LLY
Old 11-05-2017, 02:25 PM
Josh154's Avatar
The grounds on the frame rail underneath drivers door? Those were pulled off and cleaned when trying to find my communication error a couple weeks ago. All fuses were gone over also.
Best 1/4 mile
12.86 - 104.92mph
Old 11-05-2017, 02:39 PM
IOWA LLY's Avatar
Yes, its really me
Yes those.
2003 GMC CCSB LLY
Old 11-05-2017, 02:41 PM
Josh154's Avatar
Yeah i cleaned them with a wire brush. Could my switch be bad and not give a signal to the front diff to engage? Or what tells the front diff to engage? Could a shift fork be sticking in the front diff?
Best 1/4 mile
12.86 - 104.92mph
Old 11-05-2017, 02:49 PM
IOWA LLY's Avatar
Yes, its really me
Hmmm. I suppose a switch could cause it. I would be more suspect of the TCCM at this point though.
2003 GMC CCSB LLY
  #9
Josh154's Avatar
Transfer case control module?
Best 1/4 mile
12.86 - 104.92mph
  #10
Old 11-05-2017, 02:51 PM
IOWA LLY's Avatar
Yes, its really me
Yes.
2003 GMC CCSB LLY
  #11
Old 11-05-2017, 02:56 PM
Josh154's Avatar
Do you know a part number? Is this something the dealer needs to reprogram for me?
Best 1/4 mile
12.86 - 104.92mph
  #12
Old 11-05-2017, 02:59 PM
Josh154's Avatar
Found a thread where several people have same issues but no resolution
http://www.duramaxforum.com/forum/06...4wd-c0379.html
Best 1/4 mile
12.86 - 104.92mph
