  #181
Old 09-18-2017, 12:29 PM
Chevy1925's Avatar
Jack one side up, put board under body and frame, then lift the other side. I wouldn't do one side only
James
best time to date: 12.39
Tailgate Crew Member #4
  #182
Old 09-18-2017, 01:10 PM
WVRigrat05's Avatar
Wound for sound
Sounds good, I'm leaving as much together as I can on the motor this time, then I'll swap everything when I decide what route I'm going as far as a motor.
Reger
100k miles-FOR SALE/Waiting on a new motor
  #183
Old 10-11-2017, 12:59 PM
WVRigrat05's Avatar
Wound for sound
James, have you pulled the motor with the harness, EGR, and everything on still? I'm not really wanting to pull any of that off if I can leave it on but looks like it'd be hard to do.
Reger
  #184
Old 10-11-2017, 01:15 PM
Chevy1925's Avatar
yup. use an engine hoist leveler, makes it easier to tilt the engine around as you are pulling it out.
i pull the front end apart, leave the bumper, pull the fan for shits and giggles (it can stay on if you want), undo the fuel lines quick disconnects at the engine and pull the two mouting tabs (one on valve cover, other on bell housing), get the rad hoses out of the way, drop trans lines down at the front of the engine, pull the ground wires and start wire off the block at the bottom, pull the power steering pump off at the bracket and bungy off to the side, yank the intake out of the way and intercooler tubing, undo the bail connectors for the engine harness and pull the truck harness off to the side, pull the starter and flex plate bolts, bell housing bolts, engine mount 3 bolts on the frame, and we have lift off.
might be a couple small things i missed but i generally leave everything on i can. so much easier to undo it all on the engine stand and put it back on. then it just drops in. when i do a drop in, its real issue to do a quick test fire to make sure all is well before a full button up. ill bolt the engine down with a bolt on each side, throw a couple bell housing bolts in, throw the TC bolts in, hook starter and grounds up, bail connectors, jump the trans lines together, hook fuel lines up and light it off for a quick check on leaks, oil pressure and fuel pressure. if all is good, put her together enough to fill with coolant and look for leaks, then finish install. leaks always seem to pop up so i do bare min to check for those first to keep from making a mess to fix it.
James
  #185
Old 10-11-2017, 02:05 PM
WVRigrat05's Avatar
Wound for sound
Good deal, I have the fender, rad support and big dumb bumper off, all the wiring to pass side is off and tied up, motor mounts are loose, fixing to jack up cab and take bell housing bolts out. Gonna lift with my tractor.
Reger
  #186
Old 10-15-2017, 08:52 AM
WVRigrat05's Avatar
Wound for sound
Alright, having a dur hur hur moment, where can I attach a chain to the back of the motor with everything on? I have a bolt for the front cover where the second alternator goes.
Reger
  #187
Old 10-15-2017, 06:21 PM
Chevy1925's Avatar
Old egr bracket works good otherwise I have a tab I bolt back there using two bolt holes off the head
James
