  #1
Old 01-11-2018, 09:21 AM
1sgkarlthomas's Avatar
1sgkarlthomas 1sgkarlthomas is offline
FNG
Default My Monster had a stuck valve HELP okay 2013
I need a little help with my 2013 I'm getting a code for stuck C fairly certain the solenoid self isn't the problem more than likely valve is stuck I've seen several posts I've with this subject but no really answers any help would be greatly appreciated and I understand experience sometimes is Doing It Wrong repeatedly I make the assumption that everyone on here is smarter than me thanks in advance for any assistance FYI it sucks to be stuck in 4th gear
  #2
Old 01-11-2018, 09:57 AM
fast03's Avatar
fast03 fast03 is offline
Default
Its a good thing you finished with this "FYI it sucks to be stuck in 4th gear "
or we would not have known what you are talking about. Built trans? do a search on here for stuck in 4th ... I am sure one of the tranmission guys will chime in with some help.
Good luck.
__________________
2011 LML maybe a little not stock
Previous Dmax: 2003,CCLB,4088r,mikel trans and other goodies
Steve
  #3
Old 01-11-2018, 09:58 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Need a lot more info.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #4
Old 01-11-2018, 11:34 AM
FNG
Default
Thanks
Details 2013 2500 HD. 169000 miles healthy engine no real power adders 6 inch pipe and SG intake delete kit. Allison 1000 12 Bolt pan got stuck in mud dropped pan swapped filters next day drove 50 miles did another fluid and filter change started getting code for C solenoid stuck fluid again drained both filters replaced twice with quality filters shifts OK up to 4th. Inspected pan and filter magnets dirty no chunks about what I expected for that mileage wiring harness looks fine did not check continuity. Fairly certain some form of foreign matter is culprit fluid looks clear I don't expect solenoid C is bad assume more likely the valve. So my real questions are can the valve or valves be freed some way without VB removal other than Devine intervention? If not best practices for VB removal and fixing my issue AND any suggestions or thoughts you deem helpful
  #5
Old 01-11-2018, 12:58 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Quote:
Originally Posted by 1sgkarlthomas View Post
Thanks
Whats a intake delete kit? no tuner on it? how hard were you on it stuck in the mud and what did you do to get it un stuck? What are the actual code numbers that come up and give them ALL in the order they were shown on the scanner. what are "quality filters"?
We are not there to see the truck, we are trying to diag though braille so you have to get in depth with your descriptions.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #6
Old 01-11-2018, 01:54 PM
FNG
Default
Took another truck that dragged me through the muddy water about the 20 feet and 3 foot deep broke 3 serious chains in process. It took 3 hours Sorry should have read as S&G Air intake system, and DEF delete. Quality filters and fluids Wix filters and name brand txsm fluids NOT Walmart brands Codes P0700 Transmission control system( MIL Request) and P0762 Shift Solenoid C stuck on
  #7
Old 01-12-2018, 11:42 AM
FNG
Default
Any advice? Lol good or bad at this point
  #8
Old 01-12-2018, 12:11 PM
FNG
Default
So I'm reaching out to the community of those transmission wizards to see if anyone had ever been able to unstuck a valve without removing the VB from the transmission I realize most likely not but gotta ask
  #9
Old 01-12-2018, 01:22 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
Since no one else has asked....why were you in 3 foot of water?
__________________
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #10
Old 01-12-2018, 02:18 PM
joshd472's Avatar
joshd472 joshd472 is offline
Default
Quote:
Going by his sentence structure (or lack there of). I'm going to say he's not the brightest fella out there.
  #11
Old 01-12-2018, 02:36 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
Easy guys. Not everyone has stellar grammar.
Iím answer to the question, no you arenít gonna be successful un-sticking the valve without removing the valve body.
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #12
Old 01-12-2018, 05:31 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
Removing the valve body isn't that bad from what I have seen. You need to be careful putting it back to torque it EXACTLY with a calibrated wrench, and get a manual before pulling the valve body apart, because little parts can go flying.
__________________
  #13
Old 01-12-2018, 06:07 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
X2
I don't know how different the valve body is from the 2006 models, but it was easy to remove and disassemble. The key is putting it together the right way and keeping everything the meticulously clean.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #14
Old 01-12-2018, 06:24 PM
Awenta's Avatar
Awenta Awenta is offline
Default
Quote:
This. Donít use the ďeh feels snugĒ approach because youíll do more harm than good.
Stick it in the freezer for a few hours and if it moves freely then youíre good to go.
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #15
Old 01-12-2018, 09:41 PM
FNG
Default
Wow thanks for ALL the responses. 1 Zero Gravity
The short answer for getting sunk in mud. The trail I was on collapsed under me and I slid down into a muddy pond. I was amazed that the truck didn't roll over. Had to climb up and out passenger door. 2. IOWA thank you, I have been in hospital brain damage from too many concussions while serving in the US Army. 3. Day and X2 thanks for the input, I will grab a Manuel tomorrow, and clearly understand proper torque. Spent about 30years working on Black Hawks, Cobras, and Hueys. And incase I missed anyone thanks to you all from, a not so stellar fella. LOL but I am a damn good shot at 1000ft
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
