  #1
Old 12-27-2017, 07:44 AM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
Default What are you guys Running? Powerservice, Howes, Stanadyne
Our first big cold snap hit last night(-8), the truck started and ran fine, just 5 minutes down the road it started to gel up. I limped down back back roads to get to work after dumping in some 911 and still wouldn't build pressure past 10K. I have always run powerservice, and only had a couple issues and that was to due to biodiesel. What are you cold weather guys running for additives or do you guys just recommend going with a fuel pump heater.
__________________
2001 2500HD Red on Black.
ATS Dual CP3, 4 inchIntake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
  #2
Old 12-27-2017, 07:51 AM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
I have never had my truck gel up using howes. Iím not saying itís the end all be all but so far so good.
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #3
Old 12-27-2017, 07:57 AM
Summit_Rider's Avatar
Summit_Rider Summit_Rider is offline
Gearhead
Default
Howe’s here also. I farm and in the cold months use straight #2 and Howe’s in all my equipment as well as my pickup never gelled using it. I live in North Dakota it’s -15 right now, no issues.
  #4
Old 12-27-2017, 08:50 AM
beach_33's Avatar
beach_33 beach_33 is offline
Default
I donít run any additives. I just make sure I get my fuel at the right stations. I avoid biodiesel like the plague
__________________
Sold:efi live. thank you pat and kat.
68mm cheetah
fleece modded regulator
diamond eye down pipe
bd manifold
airdog 150
custom 5in pipe to 6in powdercoated stack
fleece sc stage 4 . thanks again brayden
team borrowed time member #8
cedarfalls raceway- sep/27/09 12.63@107mph
2016 2500HD z71: all stock except rims and tires
2006 Volkswagen Jetta tdi
  #5
Old 12-27-2017, 09:01 AM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
I've ran all three you listed at one time or another, but a couple years ago when it got down to -20 for a week or so I ran Howes at double strength. Been running it since, and it's cheaper than the others.
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
  #6
Old 12-27-2017, 09:25 AM
<<<IT WORKS
Default
Quote:
I stay away from KUM and GO, their diesel is horrible, currently I run QT, GIT N GO, and Casey's. Last year I had no issues, but I guess I need to start taking Diesel samples again.
__________________
  #7
Old 12-27-2017, 09:51 AM
Novak's Avatar
Novak Novak is offline
SQUIRREL TRYN TO GET A NUT
Default
Howes itís cheap and plentiful and does the trick. Havenít jelled up yet on it.
__________________
2008 LMM :SOLD 2/18
4" MBRP TB AXLE DUMP, EFI IDAHO ROB, PPE RAIL PLUG, S&B AIR, PPE TRANS COOLER, FLEECE TRANS LINES, AIRDOGG 165, EDGE CTS, KRYPTONITE STEERING RODS AND KRYPTONITE IDLER, COGNITO STEERING BRACES, COGNITO DIFF MOUNT, BARS TURNED DOWN AND DROP SHACKLES ON REAR, ALL OTHER PM (REROUTES AND DELETES) PAINT PAINT PAINT
2004.5 LLY :SOLD 2/15
5" TB EXHAUST, FASS LIFT PUMP, PPE TUNE, PUMP RUB, MOUTHPIECE, PAINT PAINT AND PAINT
  #8
Old 12-27-2017, 10:16 AM
oscyjack's Avatar
oscyjack oscyjack is offline
Default
Stanadyne here just cuz it's easy to grab and dump in. No issues here past 3 winters.
__________________
'08 LMM CCSB
Limitless trans
EFIlive - PPEI
Built front end
All the bolt ons
33x11.5 on 17x9 -12
HB/brake upgrades
  #9
Old 12-27-2017, 10:21 AM
beach_33's Avatar
Default
Quote:
I try to only get fuel at hyvee or Caseyís. I stay away from everywhere else. My 16 hasnít gelled and neither has my jetta tdi. My 05 only gelled once and thatís when I got fuel at Kum and go
__________________
68mm cheetah
bd manifold
airdog 150
  #10
Old 12-27-2017, 10:25 AM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
Default
I don't run any anti gel
But I do use a cetane booster on every tank full
__________________
Joe
2008 CCLB LT2 DURAMAX LMM
13.44 @ 98.69
  #11
Old 12-27-2017, 05:08 PM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
Default
Quote:
X2
__________________
2007 LBZ EXT CAB S/B 4x4 SLT
4' MBRP SS
  #12
Old 12-27-2017, 05:14 PM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
Default
Howes -4į this morning no problems
__________________
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
10.91 at 129mph, 1.577 60 foot
dynoed 743 hp raceweight 5k with driver
Instagram-636zf6
  #13
Old 12-27-2017, 05:54 PM
zf>allison's Avatar
Default
Can we take a poll on this and maybe stick it in a winter driving thread lol. It would be easier to see who uses what that way.
__________________
best
Instagram-636zf6
  #14
Old 12-29-2017, 05:47 PM
minerigger's Avatar
minerigger minerigger is offline
Default
I used to use lower service and after I put 6 filters in 3 days I dumped 32 oz of howes and let it run all night. Never gelled since in 5 years and that was the first time I had gelled. It a cheap and in every truck stop in America so I use it
Sent from my SM-G930V using Tapatalk
__________________
Brock
06 LBZ ECLB
Gauges, Danville Tunes, 5" Dumped, Trans by Evan, DP Stg2r, Sleeved/Braced and some other odds and ends crap that we all have
  #15
Old 12-29-2017, 06:22 PM
jlawles2 jlawles2 is offline
Default
When in Wisconsin and sub zero temps, I was running Howe's. Truck sat for 3 days at sub zero while I was on leave for a week. When I got back, cycled the key several times and started the truck. Was not slow to turn over and started on about the 3rd rev as normal. Oil filters screamed and pressure was through the roof. It scared the crap out of me and I turned it off thinking it was the Turbo. Opened hood, started truck and climbed all over till I found the noise (in the snow of course). Turned out to be the amsoil dual filter kit bypassing and making the noise. After I got it started that morning, it never did it again.
__________________
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
