Old 01-12-2018, 08:32 AM
black00chev's Avatar
black00chev black00chev is offline
FNG
Default New wheels and tires ordered!
First off, I'm honestly surprised how quiet this section is!
So when I bought my new to me 04 LLY, it came with factory size Toyo Open Country H/T tires. Not sure if these are original tires or not, but I had one have a belt separate and cause one heck of a vibration and I picked up a screw in another.
So today I ordered 18x9 Ultra Machine whees in all black and 265/70-18 Cooper AT3 tires.
Im hoping these fit with no issues since they are only 1" wider and 1" closer on either side of the tire.
2004 LLY 2500HD CCSB 4x4 - only 32,000 miles and 100% stock..... for now.
2000 5.3L Z71 - 200,000 miles and counting... makes ~340/330.
Old 01-12-2018, 08:47 AM
Rivera.alan's Avatar
Rivera.alan Rivera.alan is offline
Gearhead
Nice! You shouldn't have a problem with fitment
Old 01-12-2018, 11:50 AM
FNG
It looks like it could be close to the front bumper when turning the wheel, but the inner fender will have plenty of room for sure. Guess I'll find out for sure next week haha.
Old 01-16-2018, 03:41 PM
FNG
Well... For anyone who actually cares about info on what does and doesn't work... This combo I ordered doesnt work on a factory height '04 2500HD. 18x9 +12mm wheels with 265/70-18 tires.
Aside from the tires clipping the lower valance, they rub on the inner fender as well. It's not terrible by any means, but trimming along will not fix this issue.
Looks like I'll be ordering a leveling kit and praying that moves things up enough in the front to avoid any trimming of the lower valance and rubbing the inner fender.
Old 01-16-2018, 05:15 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
It's actually Zach
Do your research. Idk how many times people need to be told leveling kits are a bad bad idea and not even necessary because you can crank the torsion bars which is an equally terrible idea
2002 Chevy EC/SB LT 4x4. Built trans. Engine all powder coated. EFI. Twin Kennedy pumps. Lowered 22x12s and 305/40 Proxes ST. SOLD
Now driving a 2011 f150 platinum ecoboost with 288k FOR SALE
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
1992 Yamaha Waverunner 3
Old 01-16-2018, 07:10 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
You do realize guy have fit 35s on truck like yours without a lift?
I run bigger tires then you without cranking, but minor trimming. I have mudflaps that get in the way too.
06 GMC 2500 CCSB SLT LBZ 4X4
Old 01-16-2018, 08:28 PM
zakkb787's Avatar
It's actually Zach
My truck had the bumper trimmed and the big fender mod with flares still in place dropped 2 or 3 inches in the front with 22x12s and 305/40s which is about a 32 or 33 by 12 wide. I don’t see any reason why you’d need a kit. The valence takes less than a minute to trim per side.
Other toys:
2011 Yamaha YFZ450X
Old 01-17-2018, 02:45 PM
FNG
Trust me fellas, I have done research. But for every person I've seen that hasn't had issues fitting the tires, I have seen another that did have issues. And it looks like im one of those people. So maybe my shocks are really tired out? Granted, I only have 32k miles on this truck, it is 14 years old.
What I was thinking of doing, is putting the wheels and tires back on the front, turn the wheel each way and see how bad im rubbing. Then try turning the t-bars up just 1" and re-checking at that point. If I still need to trim some then I may just have to do it. But I really want to avoid trimming anything.
Thoughts/opinions? Thanks!
  #9
Old 01-17-2018, 04:20 PM
RobsDmax's Avatar
RobsDmax RobsDmax is offline
http://rimsntires.com/specspro.jsp
This is what you should use. That combo is very very mild. Im on 17x9 +20 265/70/17 and mine is lower than stock no rub.
2003 Chevy LB7 RC/LB
EFI By Kory
2003 Chevy LB7 CC/SB "Cheap Hooker"
EFI By Kory - S400 HSP Kit - 2.5" Billet Charger - 2.8" Puller
2008 GMC LMM CC/SB
EFI By Kory - Magnaflow Exhaust
  #10
Old 01-17-2018, 04:22 PM
RobsDmax's Avatar
Those tires you have are actually 3" taller than the stock 245/75/16. Almost a 33" tall tire. You should crank the bars the same number of turns a side (4 and 4) see if it rubs and continue until you are happy.
EFI By Kory
2008 GMC LMM CC/SB
  #11
Old 01-17-2018, 04:40 PM
Dozerboy's Avatar
Until he wears the front end out in a year and starts complaining about GMs junk IFS. A little bit ok, but I wouldn’t crank it more then an 1”. And wouldn’t crank it at all race it or use it hard in 4wd. That’s how you break stuff.
You space the bumper out if you don’t want to trim and remold the plastic liner with a heat gun.
  #12
Old 01-17-2018, 06:55 PM
FNG
Again trust me, I used the calculators and everything else I could figure out including rough measuring lol.
Dozer - Don't worry, Im a GM guy and have owned a Silverado ever since I could afford one. I know how junky the IFS fronts can be lol. But honestly, after talking to my buddy at work who has pretty much the same truck, Im going to try turning them up an inch and see how things look there. His truck is up 2" and has zero premature wear, excessive wear, or anything like that. And no ride quality difference.
  #13
Old 01-17-2018, 07:14 PM
joshd472's Avatar
joshd472 joshd472 is online now
Dozer was trying to tell you the IFS is not junk if used correctly. Trimming a little plastic is a lot better than wrecking the front end. I don’t know why this is so hard for people to understand.
  #14
Old 01-17-2018, 08:21 PM
FNG
I know what he meant lol. My half ton 4x4 is lowered 2"-4" and everything still works just fine in the front end with lowering keys.
  #15
Old Yesterday, 06:53 PM
FNG
Well I did what had to be done and got my new wheels and tires mounted on the truck. And so far, I'm happy with the outcome. I'll get some pictures of how it looks sometime tomorrow.
