  #1
Old 03-20-2017, 01:05 PM
TexasDiesels TexasDiesels is offline
FNG
Angry Lmm whine..video attached
I posted this on DF originally, bringing it over here for more input. I also want to mention that it is not just turbo whistle I'm hearing - there is a low pitched whine that can be heard in the video, best in the last half of the clip. may need headphones.
https://www.youtube.com/watch?v=2nnb17MNfEM
So my water pump started leaking, changed it and the t stats. Thats when the whining started. I changed the pump again under warranty from MA, and sure enough the bearing was shot in it; made a squeaky noise as I moved it and it really didnt want to spin much, BUT it managed to do its job in the 600 miles i had it on. The new pump fixed the whine for all of 20 minutes, but again temperatures are perfect and I really doubt I got another bad pump. So I changed my belt and all the idler pulleys, including the tensioner - this did not solve the whine. I checked my ps fluid and it was low and was making a really bad noise when it was running with the cap off. I filled it and it did quiet down a little bit. I'm not getting the whining and pulsing really bad when I turn or brake, but I could never bleed all the air out of it the last time it was changed. the Hydroboost unit shit out on me one day and I didnt have time, so I took it to my buddies shop. He threw a cheap reman unit in it, don't think he changed the actual ps pump. Is that my next project? Or should I be taking a peak into my turbo compressor? I'm not having boost or egt issues.
Boost leak can't be ruled out either, I went through and tightened every boot I could but I still haven't hooked it up to a compressor. thoughts?
Extremely displeased with this years game of "guess that noise"
  #2
Old 03-20-2017, 01:14 PM
FNG
Default
Signature isn't showing, 2009 lmm 200k miles, tuned, deleted, majority of bolt on mods
__________________
2009 Lmm CBSB with 200k on the clock
Tuned, deleted, bolted-on fun
  #3
Old 03-20-2017, 02:58 PM
RobsDmax's Avatar
RobsDmax RobsDmax is offline
Default
Is it only at speed? My wheel bearings both made a whining noise.
__________________
2003 Chevy LB7 RC/LB
EFI By Kory
2003 Chevy LB7 CC/SB "Cheap Hooker"
EFI By Kory - S400 HSP Kit - 2.5" Billet Charger - 2.8" Puller
2008 GMC LMM CC/SB
EFI By Kory - Magnaflow Exhaust
  #4
Old 03-20-2017, 03:30 PM
FNG
Default
I feel like I can hear it at idle, in park or gear, but it's most noticeable at low rpm driving
__________________
  #5
Old 03-20-2017, 04:44 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default
Power steering or an idler pulley.
Could be an alternator but most likely one of the first two.
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles-FOR SALE/Waiting on a new motor
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #6
Old 03-20-2017, 05:02 PM
FNG
Default
I'm leaning to PS pump as well, anyone know how to diagnose a bad pump? would be nice to know before I start tossing parts on! thanks
__________________
  #7
Old 03-20-2017, 05:05 PM
WVRigrat05's Avatar
Wound for sound
Default
Stand on the brake and rip on the wheel, it'll start grinding or howling like a banshee.
__________________
Reger
  #8
Old 03-20-2017, 05:40 PM
KyleC4's Avatar
KyleC4 KyleC4 is offline
Default
Use a stethoscope. If it makes noise at idle you should be able to isolate it to a specific component. And if you want to rule out any belt driven component, start the truck with the belt off and see if noise is gone. That'll help eliminate another bad water pump. But I've seen multiple bad aftermarket water pumps. Never had issues with GM ones
__________________
TEAM Chevrolet Cadillac
Mike L and Inglewood transmission
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
