  #1
Old 03-19-2017, 07:09 PM
suavecito1177's Avatar
suavecito1177 suavecito1177 is offline
Duranewb
Default ATP tuner
Found an Autocal from ATP for sale locally. He says it's tuned for a Cummins
Do I just need a new vin license and dsp5 tunes from ATP to get it to work on my LMM? He's only asking $175, is that a good deal?
__________________
08 GMC Sierra 1500 CC/SB 5.3L SOLD
Current
08 Chevrolet Silverado 2500HD CC/SB Duramax/Allison LTZ Z71 4x4, 6" Rough Country Lift, 20x12 -44 Moto Metal, 35/12.50/20 Pro Comp Extreme MT2, Resonator Delete, PCV Reroute, S&B Intake, Glow Shift EGT, MBRP 4" Downpipe Back, Airdog II-4g 165, Efi Live(ATP/Idaho Rob)DSP5
Waiting to be installed
Forbidden EGR Delete/Tube, DE 3" Downpipe
  #2
Old 03-19-2017, 07:11 PM
blue09dmaxx's Avatar
blue09dmaxx blue09dmaxx is offline
Too broke for this shit
Default
Call them and ask, but I wouldn't pay more than 100, considering it's basically a code reader right now
__________________
2016 GMC 2500HD LML
Sold: Too many
Owned 2-lb7,1-lbz,6-lmm,1-lml no lly
  #3
Old 03-19-2017, 07:13 PM
Duranewb
Default
Yea gonna give them a call tomorrow before I decide anything
__________________
Current
  #4
Old 03-19-2017, 07:57 PM
Novak's Avatar
Novak Novak is offline
SQUIRREL TRYN TO GET A NUT
Default
Kinda sucks for those who paid several hundred for one in the past.....
__________________
2008 LMM :SOLD 2/18
4" MBRP TB AXLE DUMP, EFI IDAHO ROB, PPE RAIL PLUG, S&B AIR, PPE TRANS COOLER, FLEECE TRANS LINES, AIRDOGG 165, EDGE CTS, KRYPTONITE STEERING RODS AND KRYPTONITE IDLER, COGNITO STEERING BRACES, COGNITO DIFF MOUNT, BARS TURNED DOWN AND DROP SHACKLES ON REAR, ALL OTHER PM (REROUTES AND DELETES) PAINT PAINT PAINT
2004.5 LLY :SOLD 2/15
5" TB EXHAUST, FASS LIFT PUMP, PPE TUNE, PUMP RUB, MOUTHPIECE, PAINT PAINT AND PAINT
  #5
Old 03-19-2017, 08:12 PM
Trotorx2's Avatar
Trotorx2 Trotorx2 is offline
Default
I don't know if this is true because I didn't follow thru to find out. I have an Autocal from my '06 and I was told that for me to be able to use it I would have to send it back to the tuner as it was tied to his V2. Once he released it I would be able to load new tunes.
Again...don't know if this is correct.
__________________
Ed
2011 GMC Sierra 2500HD Denali Crew Cab. Flo Pro 4" full delete exhaust, EGR blocked, S&B Intake, PPEI tuned.
2006 Silverado ECSB LBZ Suncoast Stage 3 w/ ML Converter Allison Deep pan, EFI Live DSP5, Castflow Manifolds, Profab up pipes with Blocker plate, Profab VVT Downpipe, Profab egr delete, MBRP 4 exhaust, Air Dog 100 with shimmed FPRV, S&B intake, Isspro Gauges, Sleeves, All Seasons centerlink brace, Rancho 9000 shocks, Sulastic Shackles, Boulder H2s, BF Goodrich Rugged Trail T/A 265/70-17
Died 12/4/2013 RIP
Semper Fi
  #6
Old 03-19-2017, 08:47 PM
Default
That's if you swap tuners
__________________
2016 GMC 2500HD LML
Sold: Too many
  #7
Old 03-19-2017, 09:38 PM
rfletes79's Avatar
rfletes79 rfletes79 is offline
Default
Autocals no longer have to be sent to unlink. It can be done remotely. The tuner who carries the link can create an unlink code that can be sent to the owner of the ac to do the unlink process. This just started happening a few months ago in a recent software release.
100$ is fair for a used ac. Then purchase a vin then purchase tuning from a tuner.
__________________
j
1970 Chevelle Duramax Hot Rod, '04 LB7/TH400-gear vendor, S475/factory IHI, 65% inj, 10 mil pump, SoCal AF cam, Valve springs, Push Rods, LBZ rods..... 10 sec cruzer :-)
2002 2500HD LLY swap 5-24-15.
  #8
Old 03-19-2017, 09:54 PM
Duranewb
Default
Is there a way to tell if the AC will need to be upgraded? That's another $450 cost. If that's the case then I'll pass on the deal. I guess ATP will answer my questions tomorrow.
__________________
Current
  #9
Old 03-19-2017, 09:57 PM
Duranewb
Default
Well reading it again, the upgrade is for older v2 scanners and not the AC. If I can pick it up for $100 then I think that's the way I'll go.
__________________
Current
  #10
Old 03-20-2017, 04:45 AM
southco southco is offline
Gearhead
Default ATP tuner
As has been stated Autocal can be unlinked remotely. I just unlinked mine remotely last week so I can use ATP. The one your looking at sounds like it's linked to ATP so if you use them for tuning you don't have to unlink.
Any software updates are free. I also updated the software on mine last week.
Lastly you should be able to buy a vin license and tune package from ATP and be good to go. I dealt with Dustin and Mike D. They were very helpful.
__________________
2007 2500HD Sierra Classic Crew Cab SLT LBZ 4WD
  #11
Old 03-20-2017, 08:31 AM
sickdiesel's Avatar
sickdiesel sickdiesel is offline
Default
good speaking with you this morning. hopefully we can get you set up soon once you get that autocal
__________________
Dustin
Current: 2018 Ford Raptor 802A
2017 GMC L5P Denali CC/LB Cognito 4-6" on 22s with 35s SOLD
Blackout :06 GMC lbz 4x4 Built motor, HSP twins, DDP Injectors, Self built trans 11.68@118.5 SOLD
OverBuilt :07 Chevy lbz 4x4 Caged and built to the hilt 10.42@134 SOLD
Special thanks to: Mike L, GTrippin, IdahoRob, SDP, ISSPRO, Yukon, Dmaxstore, Airdog, HSP, Hamilton Cams, and Flexalite
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
  #12
Old 03-20-2017, 12:52 PM
Duranewb
Default
Thanks for taking my call Dustin, I talked to the guy this morning and picking up that Autocal after work for $100. I'll give you a call so we can setup the tuning package I'm looking for as far as the dsp5 goes. Thanks everyone for all the input.
__________________
Current
  #13
Old 03-21-2017, 05:50 PM
Duranewb
Default
So I was able to pick up that Autcal for $100 last night. Called ATP and Mike helped me submit my order for the DSP5 tune and also ordered a Cat Adapter. Gonna also be picking up an Airdog II-4g 165 for this setup. Only need to order the airdog and the exhaust and everything will be ready for installation, then its just getting a weekend off to put it all in and get this puppy roaring. Thanks for all the help guys.
__________________
Current
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
