Old 03-19-2017, 09:06 PM
TxAg2012 TxAg2012 is offline
FNG
Default First post, first dmax, first wanna set it on fire feeling
Howdy!
This is my first post in a Duramax forum and I chose this place because it seems to be the best wealth of knowledge.
I'm a former Ford homer and got broke on a 6.0. Learned how to wrench on a modern diesel real well due to that truck. We bought it new in 04 and took great care of it and never modified it at all until 115k miles and it did the trifecta. Needless to say I fixed it all in house and then a year later sold it and took a beating. I went backwards and bought a old tired 7.3 IDI that has more hours than miles and the mileage is near 250k, I still have this truck thankfully.
Okay here's what I came here for:
In December I bought a 2006 LBZ 2500HD LT 4x4 Dmax, Auto with 185k miles on it. I'm the third owner and the first two were college roommates so I know it's history well. It was a well maintained truck but sat a lot of the last two years. I immediately put new fuel filters and ran a few tanks with sea foam just in case. Truck was running great I was converted to a Chevy guy. Then.....the truck started blowing black smoke like crazy and ran like a dog. I tow a little cargo trailer that weighs about 3k for my AC business and the ol IDI could pull it better. My fuel mileage went to hell and the cel came on. I got a whole plethora of Turbo boost codes, P0004, p2563, p2564 Etc. Truck has a Demon? Program in it running 80hp increase and a K&N Air filter otherwise stock. So I dick around cleaning the filter, running it hard, running it slow, etc and no avail. So I bite the bullet and pulled the turbo. Sent it to Majestic Turbo in Waco and had it rebuilt and also had a new solenoid and position sensor installed then. I decided to also put in a MBPR down tube because of the pain it was to get the factory one out with those dumb heat shields. Changed the oil in the truck and fired it up. Did a break in procedure on the turbo then went back to towing my trailer. Immediately after putting the truck back together I cleared the fault codes. On the third start up I got glow plug 2 cel, good deal. I don't need glow plugs anyway, cleared the code every day for a week just to make sure there weren't others. Well damned if I didn't finally replace that glow plug today and code P2564 is here and won't go away. I cleared the code, got the truck to temp, cleared the code again and then cranked the truck with no ac on for it to supposedly do a relearn on its own. No dice. Truck has a stock air filter back on it since before the rebuild. I hate K&Ns.
Where do I go from here? I have a finger stick and egr delete kit on hand and plan on doing them and straight pipe at the same time. It feel beat down. I've dumped a little money but a lot of time (that turbo is a bear to get out!!!, 7hrs for me) and I just want a good running truck. What can I look for to get rid of this code. And if it matters I haven't yet noticed the black smoke or lack of power. Turbo didn't look too bad when we tore it apart but I figured it was cheap insurance and a chance for me to get real personal with the truck. I've also figured out the wifey is more willing (ha, haven't figured that out yet!) on letting me buy truck parts when the truck is tore all to holy hell in the driveway if I tell her I've gotta have "modification xyz" to put it back together! ;-)
Thanks for reading and I hope someone on here has an idea for me.
Caleb
Old 03-20-2017, 12:22 AM
AZlml's Avatar
AZlml AZlml is offline
Try shorter direct questions. I don't think most people will read your novel. But welcome anyways
Bryan
11 CCSB 4x4
Full delete, EFI by Ridgerunner, 5" FloPro, Profab manifolds and up pipes, Wehrli cp3 conversion, 3" downpipe, S&B intake, AD165 4G, DHD tie rod sleeves, 2" rear drop shackles, Rancho RS9000XL
Old 03-20-2017, 12:45 AM
Rancelot211's Avatar
Rancelot211 Rancelot211 is offline
Boyd
Put a blocker plate on it and see what happens. Its 10$.
2007.5 lmm Ccsb: 628hp 1237tq- sold
Old 03-20-2017, 02:17 AM
Blackmax123 Blackmax123 is offline
The P2564 is for vane position sensor voltage low. Check the plugs and wiring for the vane position sensor.
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
Old 03-20-2017, 02:46 AM
Boyd
Didnt read the whole thing lol but could have a stuck unison ring. I know it says it was rebuilt but i have never heard of that company.
Old 03-20-2017, 06:10 AM
TLyons90's Avatar
TLyons90 TLyons90 is offline
Heck of a 1st drawn out post. Also this is not duramax forum
Don't give up yet! Duramax's nevertheless an LBZ is an excellent work horse. Check the connections like said above as well as throwing the blocker plate in and see what happens!
Troy
Current - 15.5 Denali | Exhaust | Tuned | Lowered | Sleeved | Wheels/Tires
Toys - Honda Grom | To Much To List
Sold - 11 CCLB, 08 ECSB, 07 RCLB, 04.5 CCLB, 04 ECSB
Old 03-20-2017, 10:35 AM
bludelux's Avatar
bludelux bludelux is offline
FNG
Did you clean the oil from the k&n filter off of the maf?
