Old 10-01-2017, 04:38 PM
KRODMAX/KS's Avatar
KRODMAX/KS KRODMAX/KS is offline
Gearhead
Default Oil level indicator
I was checking the oil and found the end of the dipstick was gone? I am beside myself to say the least and in the middle of nowhere on a Sunday. I am scared to death knowing the possibility of this piece damaging my motor. Any information would be greatly appreciated!
06 CCSB
Carrillo's, Fingers cast w 37mm reliefs 17:1, ARP, SoCal 3388AF cam, flex-plate, dampner & springs, M/A push rods, DHD y-bridge, coupler & lock-up box, Danville Billet 68R1, motor mounts & water pump, Energy 10mm, 45% over inj, Airdog 4G 165, AFE, Banks, Mag-Hytec, ProFab Tow-flows, MBRP, Magnaflow, QA1, Cognito, McGaughys, CalTracs, TruTrac, AC Delco Extreme duty rotors, LML 20" & Nitto 305/50/20 420's
Motor built by Danville/tuned by Mark
Mike L Built Trans w billet shafts, hub and "K" converter
758HP/1441ftlbs
Old 10-01-2017, 04:58 PM
Novak's Avatar
Novak Novak is offline
SQUIRREL TRYN TO GET A NUT
Have you stared it yet? Hopefully it broke when you checked.
2008 LMM :SOLD 2/18
4" MBRP TB AXLE DUMP, EFI IDAHO ROB, PPE RAIL PLUG, S&B AIR, PPE TRANS COOLER, FLEECE TRANS LINES, AIRDOGG 165, EDGE CTS, KRYPTONITE STEERING RODS AND KRYPTONITE IDLER, COGNITO STEERING BRACES, COGNITO DIFF MOUNT, BARS TURNED DOWN AND DROP SHACKLES ON REAR, ALL OTHER PM (REROUTES AND DELETES) PAINT PAINT PAINT
2004.5 LLY :SOLD 2/15
5" TB EXHAUST, FASS LIFT PUMP, PPE TUNE, PUMP RUB, MOUTHPIECE, PAINT PAINT AND PAINT
Old 10-01-2017, 05:04 PM
Novak's Avatar
There are a couple old threads from this happening and it was said to not be an issue. You will have to either pull the tube and send a clean magnet in or you will have to drop the pan.
2008 LMM :SOLD 2/18
Old 10-01-2017, 05:31 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
It will be fine. That piece is way too big to fit thru the pickup tube screen. And the dipstick hole in the upper oil pan is below the rotating assembly, so no big deal.
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Old 10-01-2017, 05:39 PM
KRODMAX/KS's Avatar
Gearhead
Thanks Novak, yes I had already been running the truck. I had checked it at a fuel stop. I have read that it's probably okay, but I am not easy on my ride and whatever damage has occurred is my own fault for not checking on it sooner. My concern is the tip looks as if it's some sort of non-metallic material, so a magnet may not work? I plan on getting it out of there ASAP, just wanted some information before I drop the pan.
06 CCSB
758HP/1441ftlbs
Old 10-01-2017, 05:43 PM
KRODMAX/KS's Avatar
Gearhead
Thanks 04GMC, this is the kind of information I have been looking for. I was pretty sure that the case, but all info is appreciated and personal experience better! I appreciate everyone's input!!
06 CCSB
758HP/1441ftlbs
Old 10-02-2017, 11:01 AM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
Not a real big job to drop the lower pan and get it out. I would just for the piece of mind that it isn't in there
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.56@111 1/8
10.12@138 1/4
Old 10-02-2017, 12:27 PM
Novak's Avatar
Might as well banana pan it while your at it
2008 LMM :SOLD 2/18
  #9
Old 10-02-2017, 05:39 PM
KRODMAX/KS's Avatar
Gearhead
That's where I'm at too.
  #10
Old 10-02-2017, 05:40 PM
KRODMAX/KS's Avatar
Gearhead
The thought had crossed my mind as well...
  #11
Old 10-02-2017, 07:44 PM
JoshH's Avatar
JoshH JoshH is offline
As long as the truck isn't upside down, it should never be a problem. If it is upside down, I think you have bigger problems!
06 Silverado 4x4 CC/SB
