  #1
Old 05-19-2017, 09:34 AM
770JOHNNYW 770JOHNNYW is offline
Default Wtb t4 pedestal.
6" or 7" tall will work
  #2
Old 05-19-2017, 09:50 AM
quinton's Avatar
quinton quinton is offline
Default
I have one, but passenger side, where up pipe bolts, one of the holes is drilled out. I ran a bolt through it and used it that way. I can send pics in a little bit.
__________________
EFIlive dsp5 by me, Built trans by me, 68 danville, stock fuel, lifted. died 6/20/2013 Cracked piston. Best time 12.75 on fuel
Alive 11/15/13: lowered, Built motor, s475, plenty of fuel, plenty of spray. Tune 3 fuel only 11.84 @114, Tune 5 little bit of spray 11.45 @ 121. Both times with melted turbine wheel, loose turbo from pedestal with blown out flange gasket. .
  #3
Old 05-19-2017, 09:56 AM
aashton1206 aashton1206 is offline
Default
Tap it for a larger bolt
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, DSP 5 on v2 by Rick Fletes, 33x12.5 nittos at on 20 inch American Racing wheels, modded factory air box, Profab Intake Horn, Batmo Wheel, Turbo port and polish, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust, 10mm lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Contol arms, Drilled and Slotted Rotors on all four Corners, Custom Y Bridge.
  #4
Old 05-19-2017, 01:05 PM
unionmax481's Avatar
unionmax481 unionmax481 is online now
hot rodder
Default
Heellicoil
__________________
ccsb 20"fuel hostages, Danville s480 over Danville 68 stg 2r twins, exergy 12mm stroker pump, brian crower rods, 16:.5 fingers cast pistons,socal 3388 cam, MA moley push tubes, 150% over exergy squiters, and all studded
Tuned by Mark Broviak @ Danville Performance
IBEW 481
Screw it just money can't take it with you
  #5
Old 05-19-2017, 02:30 PM
Default
If you have it inserts are strongest
  #6
Old 05-23-2017, 01:09 PM
Default
How much??
  #7
Old 05-23-2017, 03:11 PM
quinton's Avatar
Default
$100 shipped
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
