  #1
Old 05-19-2017, 04:54 AM
Sourdough Sourdough is offline
Alaska Wilderness Wanderer
Default Request "HELP" with Engine troubles....thanks
I starts fine, let it warm-up, put it in gear and it stalls. If you don't put it in gear, but very, very, very, very slowly press the accelerator, the engine looks and feels like it is going to break the engine mounts, with vibration. If it is not put in gear and the throttle is press "Quickly" it stalls. It always restarts perfectly, it idles fine.
It will idle fine for as long as I will leave it idle, 15 or 20 minutes and it idles fine, feed in just the slightest power and it stalls. It ran fine right up till this started happening. Never any engine problem till this. I removed the air filter to see if that would make any difference.......it did not make any difference.
Before this it never had any visible exhaust....none. Now there is a blue'ish exhaust, if the power is feed in slowly, till it looks and feels like the engine will jump out.
Engine and Truck has a total of 35,800 original miles
Fuel filter was just changed about 500 miles ago.
Thanks for help.
  #2
Old 05-19-2017, 05:27 AM
Blackmax123 Blackmax123 is offline
Default
What year is it?
__________________
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- all stock for now. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and injectors, ac delete, s400 custom Danville 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
  #3
Old 05-19-2017, 05:42 AM
Default
2005 GMC 5500 4X4 Crew Cab Dully (Currently located near the middle of large wilderness National Forest, in Alaska)
Quote:
Originally Posted by Blackmax123 View Post
What year is it?
  #4
Old 05-19-2017, 05:44 AM
Default
Are their any codes present?
__________________
  #5
Old 05-19-2017, 06:04 AM
Default
I have NO idea what that is.
  #6
Old 05-19-2017, 09:11 AM
Subman's Avatar
Subman Subman is offline
Old Geezer
Default
Does the check engine lignt come on? You need something to read the engine codes, if you are out in the boonies that might be a problem.
__________________
2007 LBZ Classic
Idaho Rob ATP tuning, MPI twin turbos
  #7
Old 05-19-2017, 09:20 AM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Only stalls when in gear, runs fine at all RPMS in neutral? Where exactly in Alaska are you located?
  #8
Old 05-19-2017, 09:25 AM
Default
Negative.....check engine light does not come on. About 100 miles in every direction to town. How much money does a code reader cost....??? Can it be shipped by mail.....???
Quote:
  #9
Old 05-19-2017, 09:30 AM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default
I'm going to guess fuel filter is loose or leaking.
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #10
Old 05-19-2017, 09:32 AM
Default
Quote:
NEGATIVE........not accurate. Runs fine at idle, runs perfectly at idle, but as soon as the RPM's are increased even the smallest amount it stalls if in gear......or if not in gear it shakes and vibrates and rocks the engine as if it will tear the engine off the frame.
Currently located on the Kenai Peninsula.......roughly near "Lower Summit Lake" off the Seward Hwy. (Not very far from the Hope Road cut-off).
  #11
Old 05-19-2017, 09:41 AM
Default
Quote:
Checked that.....filter is tight and is NOT leaking. No fuel leaking any place, even if it is idling for 30 minutes.
  #12
Old 05-19-2017, 09:46 AM
Burn Down's Avatar
Default
^^^ Yep sounds fuel/filter related
What fuel filter are you running on the truck currently? The filter heads can go bad, 12 bucks in seals to rebuild them. The CP3 pump sucks fuel from the tank through the filter, so it normally won't leak any fuel externally but will suck air and cause issues.
  #13
Old 05-19-2017, 11:02 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
I'm going to guess the cam or crank sensor or reluctor wheel. Or the imfamous #2 & #7 injector harness issues. Try ice picking the connectors at each injector
http://www.duramaxforum.com/forum/ho...onnectors.html
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #14
Old 05-20-2017, 09:34 AM
Subman's Avatar
Old Geezer
Default
had the injector harness issue in my 05 dually. It would hardly move. The point of this I'm trying to figure out is the violent engine shake when he tries to increase RPM in neutral. Correct me if I'm wrong, but wouldn't the check engine light come on if there was a cam or crank sensor problem. Thats what it sounds like, if it were a filter problem I don't think he'd get the engine vibration when he add fuel in neutral. Really need something to ck the codes. You are not that far from Anchorage go in and get a code reader. I think you can get something at most any auto parts store. If I were close I'd loan you my Tech II.
__________________
2007 LBZ Classic
  #15
Old 05-20-2017, 09:47 AM
Default
Is the code reader specific to a given type engine......or is a code reader a universal tool that works on any vehicle......??? And thanks for the help.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
