  #1
Old 05-18-2017, 05:43 PM
turbospoolindmax's Avatar
turbospoolindmax turbospoolindmax is offline
FNG
Default suncoast 5spd build specs
fixing to start on this trans and i realised that i didnt get any clearance specs with it its the SUN COAST GMAX-5R-1 RAYBESTOS REBUILD KIT does this kit have certain specs or can i use the atsg manual specs or better yet what clearance do the pros recomend to set these kits at!
  #2
Old 05-18-2017, 05:53 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
Call the place you bought the kit. They should point you in the right direction.
__________________
2006 ccsb Lbz Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples
  #3
Old 05-18-2017, 06:05 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
Quote:
Yep!
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #4
Old 05-18-2017, 06:21 PM
FNG
Default
ok i reckon ill call suncoast in the morning i was hoping somebody had a spec sheet lying around or knew the specs...i also heard of some builders setting certain clutch packs slighty tighter than spec for wear in has any of you builders heard of this? if so is it a good idea?
  #5
Old 05-18-2017, 06:35 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
Not trying to be a d!ck but I don't think your going to get nor can you expect any of these guys to give up their wisdom that they gained by building these things...
__________________
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #6
Old 05-18-2017, 06:42 PM
FNG
Default
Quote:
ya i wasnt expecting much help but figured it couldnt hurt to ask lol
  #7
Old 05-19-2017, 10:32 AM
Bustedknuckles's Avatar
Bustedknuckles Bustedknuckles is offline
Honey Badger
Default
http://cloud.tapatalk.com/s/591f2d66...0Raybestos.pdf
__________________
04 lb7: 06 front clip, EPR s366, 30% over injectors, ARP head studs, Idaho-Rob tunes, airdog, PPE trans, Precision ML converter, etc......
  #8
Old 05-19-2017, 11:53 AM
Default
Quote:
It's always worth a try but I know if I was good at building them I wouldn't give away my secrets...
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
