  #1
Old 05-17-2017, 09:43 PM
Dennis,max Dennis,max is offline
FNG
Question Truck doesn't go into gear
I have a 2001 Chevy Duramax has the Allison trans. Wouldn't move the indicator on the dash would just flash so changed the nsbu switch and no difference, had the tcm flashed and reprogrammed and still nothing so I changed the ignition switch and the truck then went into gear but took a few seconds before it kicked in then went back to not moving and just flashing on the dash. Also if I unplug the 4 pin wire connector on the nsbu switch the truck will move but only in limp mode. Any help would be awesome this truck has had me spinning for awhile now
  #2
Old 05-18-2017, 07:45 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Pull the codes and quit throwing parts at it hoping it will fix it
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #3
Old 05-18-2017, 07:05 PM
FNG
Default
The truck doesn't set any codes
  #4
Old 05-18-2017, 07:08 PM
Burn Down's Avatar
Burn Down Burn Down is online now
Default
What are you using to ck the codes with? Cheapo scan tools normally won't pull allison codes.
__________________
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #5
Old 05-18-2017, 07:10 PM
FNG
Default
Snap on Ethos, the check engine light doesn't even come on
  #6
Old 05-18-2017, 07:21 PM
FNG
Default
I can get the truck to move but once I do I can't go far and it will just quit moving and the gear selection flashes but truck won't move unless I cycle the key a few times
  #7
Old 05-18-2017, 08:08 PM
Chevy1925's Avatar
Default
You have codes, you just have an electrical issue going on that needs to be address. Start at the Tcm and follow the wiring back looking for frayed or cut wires.
Did you put the nsbu in as the instructions stated?
__________________
James
  #8
Old 05-19-2017, 02:59 AM
FNG
Default
Yes I did and checked all the wiring the dealership I took it to to get tcm flashed look over the wiring as well and didn't see any problems
  #9
Old 05-19-2017, 06:22 AM
Blackmax123 Blackmax123 is offline
Default
Start simple. Have you checked the oil level?
__________________
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
  #10
Old 05-19-2017, 06:46 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
May be plugged sump filter.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #11
Old 05-19-2017, 06:56 PM
FNG
Default
That's the internal filter right?
  #12
Old 05-19-2017, 07:44 PM
KyleC4's Avatar
KyleC4 KyleC4 is offline
Default
Yes. Pull codes or have someone with a tech II actually look at data when problem occurs
__________________
TEAM Chevrolet Cadillac
Mike L and Inglewood transmission
  #13
Old 05-21-2017, 05:08 AM
FNG
Default
I have
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
