  #16
Old 05-19-2017, 03:07 PM
Slick03Max Slick03Max is offline
FNG
Default
Any tips or info on ideas on anything that i should do to the engine before dropping the body back down???
I was planning on the lml manifold,,,block egr,,,pcv re route and taking the turbo apart and cleaning it up!!!
  #17
Old 05-22-2017, 03:52 AM
036.6turbo 036.6turbo is offline
Default
I removed the EGR and cooler, blocked off that stuff. Used the up pipe from the LB7.
I wish I would have cleaned the vane position sensor on my LBZ, its throwing codes now. I bought a complete replacement turbo, but it would have been much easier to swap over, with the motor out of the truck.
My donor truck ran, it had thrown codes on #8 glow plug being bad, so I replaced all of mine while it was out.
Other than that, the sky's the limit.
__________________
2003 GMC Sierra CCSB.
LBZ / Six speed / EGR Delete / DSP5 with tuning from Idaho Rob @ ATP Trucks / Bilstein 5100s / Air Ride 5000 bags / Merchant Reman Tcase / TNR head unit.
2015.5 Denali. Dmax Allison, under construction.
  #18
Old 09-05-2017, 06:17 PM
FNG
Default Cab Lift points
Hey guys!!!!
Its finally time to drop the cab/front fenders/rad support back onto the frame,,,
I had used 2 forklifts to lift everything up and pull the chassis out from under the cab,,,but now one of the forklifts is out of service!!
I have a friend with a bucket truck with a winch,,its capable of lifting the weight,,,im just now exactly sure how to tackle getting this thing in the air so the chassis can be rolled underneath it again??
Should I open the doors and run a few slings across inside??
Any ideas of thoughts are greatly appreciated!!!
Its an extended cab,,,so it doesnt have the roof ribs like the crew cab for strength,,not sure if that really matters in a lift like this anyhow!!!
Thanks in advance for any guidance!!!!!!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
