  #1
Old 04-12-2017, 05:16 PM
Slick03Max Slick03Max is offline
FNG
Default Steering column swap -- LBZ into LB7
Hey guys!!!
New guy here,,,and not sure if I missed it under the search function or not,,,but couldn't find what I'm looking for!!!
I am in the planning and gathering stages of putting an LBZ in my 03!!!
I;ve read and printed off lots of awesome wiring info off of here!!
I'm not sure exactly about the steering column swap,,,,I have steering wheel controls,,the donor doesn't!!
Do (or can I) swap the clock spring,,,steering wheel and air bag,, etc from my existing column (2003) to the lbz column (2006) to keep my radio controls etc,,,
I haven't torn the column out of mine to check wiring etc and don't have the donor in my possession just yet to check!!!
And also,,,I will have the 2006 cluster,,,does the 2006 cluster support all the DIC info that my 2003 now does??
Any info,,,tips,,links or ideas of things to do before or after the swap are greatly appreciated!!! Chris
  #2
Old 04-13-2017, 05:57 AM
gmc502 gmc502 is offline
Default
I put an 06 steering column into my 02,for me,I had to put the column stuff of the 02 on the 06,all I had to do was drill and tap a boss for the ignition on the 06.
yours should be a direct swap over w/ no issues.
I did it for the steering wheel controls for the pioneer head unit.
__________________
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
  #3
Old 04-13-2017, 07:25 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Is there something wrong with your 03 column? Why go through the trouble of changing it?
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #4
Old 04-13-2017, 05:49 PM
FNG
Default
Quote:
From what I've read,,,to run the 6 speed and have the tap shift I need to swap to the 06 column!!!
  #5
Old 04-13-2017, 06:09 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default
just swap the shifter and a wire. Plenty of people running 01-05 with tapshifters
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles-FOR SALE/Waiting on a new motor
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #6
Old 04-13-2017, 06:14 PM
Default
Quote:
its that easy on an 02.
__________________
  #7
Old 04-14-2017, 06:04 AM
FNG
Default
OK thanks guys!,,
So I just need to swap the shifter pieces over to my column???
  #8
Old 04-14-2017, 07:05 AM
JoshH's Avatar
Default
You can do just the shift lever, but the shifter on a 6 speed column is angled slightly different than a 5 speed. The tap shift lever on a 5 speed column will be positioned lightly lower than it would be on a 6 speed column in the same selected gear. You can either live with that or you can swap the shift mechanism also.
__________________
  #9
Old 04-14-2017, 09:34 AM
oscyjack's Avatar
oscyjack oscyjack is offline
Default
Mind if I semi hijack?
What about swapping in a telescopic wheel/column? My back would be grateful haha*
__________________
'08 LMM CCSB
Limitless trans
EFIlive - PPEI
Built front end
All the bolt ons
33x11.5 on 17x9 -12
HB/brake upgrades
  #10
Old 04-16-2017, 09:00 PM
testdrive testdrive is offline
Gearhead
Default
You need to swap the "rooster comb or detent" along with the shifter if you are install the six speed tap shifter. Two small screws hold it on.
The 06 cluster DIC will display what is needed. You might loose the 2nd driver MPG but overall you will like it better.
__________________
2003 Chevrolet Duramax Suburban K2500
powered by a 2007 LBZ Duramax Diesel
6SP Allison with Transgo JR mod
Duramax Suburban Brotherhood member #7
EFI DSP5 tuned thanks to thefermanator
  #11
Old 05-18-2017, 10:52 AM
FNG
Default
Thanks for all the replies!!!
Ive got the box and cab off,,,,going to sandblast and paint the frame once the engine and trans are pulled! !!
Another question about the wiring,,,,the dude im getting the lbz and 6 speed from says hes giving me the fusebox along with everything wirimg related,,,,,
Do i still have to swap some wires into different positions to make everything jive??
Thanks again!!
  #12
Old 05-19-2017, 03:49 AM
036.6turbo 036.6turbo is offline
Default
Thanks again!!
This;
http://www.duramaxdiesels.com/forum/...ad.php?t=27198
__________________
2003 GMC Sierra CCSB.
LBZ / Six speed / EGR Delete / DSP5 with tuning from Idaho Rob @ ATP Trucks / Bilstein 5100s / Air Ride 5000 bags / Merchant Reman Tcase / TNR head unit.
2015.5 Denali. Dmax Allison, under construction.
  #13
Old 05-19-2017, 03:50 AM
Default
Here's mine;
http://www.duramaxdiesels.com/forum/...ad.php?t=72330
__________________
  #14
Old 05-19-2017, 05:17 AM
FNG
Default
Thanks for the links 03!!!!
Did you notice much difference between the lb7 and the lbz??? Fuel mileage etc???
  #15
Old 05-19-2017, 05:26 AM
Default
I have not checked the fuel milage of the LBZ, but the yes I have noticed a difference.
The LBZ is quieter, smoother and a much better driving experience. The six speed is responsible for much of that.
I have towed very heavy with it a few times it is much more capable, than the LB7.
Idaho Rob at ATP did my tuning, so my truck runs VERY well, depending on who you have tune yours, your results may vary.
Overall very happy with the swap. Thankful for the guys here, that made it possible.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
