Old 05-19-2017, 09:34 AM
770JOHNNYW 770JOHNNYW is offline
Default Wtb t4 pedestal.
6" or 7" tall will work
Old 05-19-2017, 09:50 AM
quinton's Avatar
quinton quinton is offline
I have one, but passenger side, where up pipe bolts, one of the holes is drilled out. I ran a bolt through it and used it that way. I can send pics in a little bit.
EFIlive dsp5 by me, Built trans by me, 68 danville, stock fuel, lifted. died 6/20/2013 Cracked piston. Best time 12.75 on fuel
Alive 11/15/13: lowered, Built motor, s475, plenty of fuel, plenty of spray. Tune 3 fuel only 11.84 @114, Tune 5 little bit of spray 11.45 @ 121. Both times with melted turbine wheel, loose turbo from pedestal with blown out flange gasket. .
Old 05-19-2017, 09:56 AM
aashton1206 aashton1206 is offline
Tap it for a larger bolt
2004 Silverado Cali lb7, Airdog ll 165, fresh sticks at 325k, DSP 5 on v2 by Rick Fletes, 33x12.5 nittos at on 20 inch American Racing wheels, modded factory air box, Profab Intake Horn, Batmo Wheel, Turbo port and polish, Full EGR Removed w/ fed belt, 3.5 inch MBRP Downpipe, Full five inch MBRP Exhaust, 10mm lbz cp3 pump, Dual Yellow Top Optimas, High Output Alternator, Cognito Pittman and idler w/ support kit, Cognito Contol arms, Drilled and Slotted Rotors on all four Corners, Custom Y Bridge.
Old 05-19-2017, 01:05 PM
unionmax481's Avatar
unionmax481 unionmax481 is offline
hot rodder
Heellicoil
ccsb 20"fuel hostages, Danville s480 over Danville 68 stg 2r twins, exergy 12mm stroker pump, brian crower rods, 16:.5 fingers cast pistons,socal 3388 cam, MA moley push tubes, 150% over exergy squiters, and all studded
Tuned by Mark Broviak @ Danville Performance
IBEW 481
Screw it just money can't take it with you
Old 05-19-2017, 02:30 PM
If you have it inserts are strongest
Old 05-23-2017, 01:09 PM
How much??
Old 05-23-2017, 03:11 PM
quinton's Avatar
$100 shipped
