Old 06-14-2017, 02:43 AM
Leadfoot's Avatar
Leadfoot Leadfoot is offline
Needs Bigger Tires!
Default L5P interchangeability?
I know there are a few internal changes (such as the reluctor being placed in the rear) as well as a few external changes (doing away with the second motor mount bosses), but was under the impression that the basic footprint remained the same. Just curious if an L5P shortblock could be swapped in as a service replacement for a blown LBZ in a daily driver?
I guess the biggest hurdle would be if the reluctor can be made to work (not sure of tooth counts) with an extension or adapter harness, and if everything else will bolt up.
Not that they are available yet, just wondering if it will be possible when they are.
Now that they've been out for a few months and I assume certain shops have at least started to play with them....
2006 GMC CCSB 4WD McRat EFI Live , Kennedy dual lift pumps, Champion Stage IV tranny, Mike L converter, cooler and C3 oiler, Suncoast Brace, Eaton E-Locker, Caltracs, homemade pulling hitch, homemade limit blocks, H2's and cooper STT's, Predator, MBRP Cool Duals (not kitty or muffler), EGR blocker, Finger Stick, and all on headlight mod.
80 K20ish Reg Cab Long Bed, Full Roller 496, Manual TH400, Torque Converter Techniques converter, 3:1 planetary setup, NP205, High Angle driveshafts, 4.56's, 35's, Lockers F&R, Dakota digital dash, and custom interior.
www.matpa.org
Old 06-14-2017, 03:15 AM
02greysixer's Avatar
02greysixer 02greysixer is offline
I feel like the bigger hurdle will be making the denso fuel system work with older trucks electronics or making Bosch parts fit the new engine. Unless blocks are similar enough heads could interchange
Sent from my SM-G930P using Tapatalk
2010 LMM CCSB LT
4" Flo-Pro
FASS 150
Beans Sump
Leveled w/ drop shackles
RidgeRunner Tunes
More to come
Rip zf6 swapped lly
Old 06-14-2017, 07:08 AM
JoshH's Avatar
JoshH JoshH is offline
The taller deck will make it extremely difficult requiring a lot of custom fuel lines and intake pieces. That is assuming the earlier heads will bolt on to the new block.
06 Silverado 4x4 CC/SB
Old 06-14-2017, 08:19 PM
$chultz38 $chultz38 is offline
Don't think anything is interchangeable from LP5 to LML and down engines
Old 06-14-2017, 08:33 PM
Leadfoot's Avatar
Needs Bigger Tires!
I was thinking/hoping the older upper end could be used so there would be no issues with fueling or electronics.
www.matpa.org
Old 06-14-2017, 08:36 PM
Leadfoot's Avatar
Needs Bigger Tires!
We run standard deck intakes on tall deck big block chevy's with spacers all the time. Spacers on the Y bridge or even a custom Y bridge would seem to be the only issue (maybe feed lines to the rails as well if there isn't enough movement in the stockers). It sounds as if there are extra bolt holes as the new heads have more, but I'm assuming if they kept the old pattern old heads should still bolt up.
Y bridge spacer and custom rail lines would be a pretty cheap price to pay for "what is said to be" a MUCH better bottom end especially for someone with a damaged block.
Edit: possibly longer pushrods as well to compensate for deck height, but again a minor issue and if your swapping over the upper end your doing the work anyways (not an extra step).
www.matpa.org
Old 06-14-2017, 11:02 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
What voltage do the denso injectors work at? Maybe they will work with one of the earlier year ecm/fcim
The other item would be the HPFP regulator. How close is it to the Bosch one and would it play nice with the ecm?
I think everything else could probably be made to "work"
I am sure you can plumb in a Bosch compatible pressure sensor, a cam and crank sensors, etc.
2008 Chevrolet 3500HD DRW LTZ
Old 09-12-2017, 12:35 AM
Leadfoot's Avatar
Needs Bigger Tires!
Revisiting this as more time has passed and I think some people didn't read or misinterpretted what I was asking.
I was wondering if someone loses a bottom end on a previous generation light duty DMax (LB7, LLY, LBZ, LMM, or LML) such as a broken crank/rod/piston, if they could take THEIR top end with THEIR ORIGINAL injectors, harness, CP3, fuel lines, rails, etc. etc. and swap it on to an L5P (electronics/injector compatability would be a non-issue). Their original electronics and injectors, etc. etc would work the same as they did before so no need to reinvent the wheel.
From what I've gathered the L5P adds bolt holes for the additional head bolts of the L5P heads, but the original holes still line up, so heads should be bolt on. It is a taller deck though which would require longer pushrods (easy enough and you have the heads off anyways) and a y-bridge spacer or custom bridge (again shouldn't be too tough as we already have vendors making aftermarket bridges).
The thing I'm most interested in and could be the biggest problem would be due to the relocation of the reluctor wheel and tooth counts. Is the count similar to that of any of the previous generations and/or is the sensor compatible or will an older sensor work. Without the reluctor working (whether it be putting the old sensor in and extending the harness), or making the new sensor work with "tuning", it's a moot point.
The reason I ask is that while injectors due go bad and CP3's sometimes fail, overall the top end seems to be pretty good, it's the bottom end (crank and pistons mostly) that seem to be suspect even with high dollar cranks. It seems the L5P may be an alternative for those of us who want more power for daily driving and weekend warrioring without as much fear of a broken crank. If we have to buy a block anyways, might as well get one that "seems" to have fixed several issues that we tend to worry about.
The big question is what type of reluctor wheel do they use (is it similar in size and tooth count to a previous gen) and will an previous sensor work, or is the L5P sensor the same or can one be adapted to work? I'm pretty sure Banks knows the answer, just wondering if any of our board engine builders and tuners have had a chance to see what's going on with the new bottom ends yet?
www.matpa.org
  #9
Old 09-13-2017, 09:52 AM
countrycorey's Avatar
countrycorey countrycorey is offline
Trust Me I'm an Engineer
I don't know if you would be asking for issues with not using the two outer head bolt holes and how that would affect/distort the block once assembled.
If youre going to go through the trouble or effort, why not try to swap in a long block or complete engine?
Sent from my SAMSUNG-SM-G930A using Tapatalk
2007 Chevy Classic CCSB LS 4x4 w/ LBZ & 6 Spd Ally
Graystone Metallic
295/70/17 Nitto Trail Grapplers on Chrome H2s w/ LMM Centers
Custom CamLocker Toolbox
Grizzly Nerf Bars
Pioneer 4100 Head Unit
JL Audio Components
Sportsman Max4 Seat Covers
MPI GT4202/Stock
HSP Coolant Tank
Tinted Windows
MBRP 5"
PCV Rerouted
EGR Blocker & Fingerstick
Nicktane 1 Micron Filter & Adapter
Banks Hot Side Intercooler Tube
ProFab Y-Bridge and 3" Cold Side Boost Tube
AutoMeter Phantom II Boost and EGT on A-Pillar
Hammerhead Armor Replacement Front Bumper
EFILive from IdahoRob
Fleece All On Mod
  #10
Old 09-13-2017, 06:34 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
It's going to be difficult no matter what without the stock file to use as a base tune and I think getting that is going to prove the hurdle. GM invests an obscene amount of money, time and manpower into building the tune file so I doubt any performance company could pull off a tune without it...
  #11
Old 09-13-2017, 09:41 PM
2004LB7's Avatar
I dont think the question was for using the engine along with its ECM but more for using the long block as an upgrade to the older blocks.taking advantage of the new crank, rods, etc
I still think someone needs to test the denso injectors with an LMM ECM to see if the whole engine less its ECM could be swapped into an older truck
  #12
Old 09-14-2017, 12:42 AM
Leadfoot's Avatar
Needs Bigger Tires!
Exactly
That would be nice if possible. How different physically are the injectors? If the LBZ ECM can't control the denso injectors, could the LBZ injectors fit in L5P heads and what about connectors? Also is the reluctor going to be an issue?
www.matpa.org
  #13
Old 09-14-2017, 12:43 AM
Leadfoot's Avatar
Needs Bigger Tires!
Using the LBZ upper end would negate any tuning issues.
www.matpa.org
  #14
Old 09-14-2017, 12:47 AM
Leadfoot's Avatar
Needs Bigger Tires!
The stock LBZ heads with the 2 fewer bolts still hold a butt-load of power especially on a street machine, so a non-issue for what I and many others would be looking for
Because right now the L5P uses a completely different injector setup. If it COULD be controlled by the older ECM's it would be even better as you could bolt in a complete long block, but that doesn't look promising at this point.
One question that might hinder is the fact the reluctor wheel is moved and I'm not sure if the plug for the sensor is the same or what the tooth count/spacing is. That's kinda the information that will dictate what is/isn't possible. I was hoping somebody had some insight.
www.matpa.org
  #15
Old 09-14-2017, 12:48 AM
RPM Motorsports's Avatar
smokinum
I've tried twice to get hold of an L5P from Banks like he has listed for sale, so I can attempt to run one on older electronics. He used to respond to FB messages, but seems he's not even doing that any more. Would be a fun project to play with on the engine stand.
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
