  #16
Old 03-15-2018, 10:00 AM
Chevy1925's Avatar
Originally Posted by Burn Down View Post
No way is 65/85 going to be worth a chit on stock fuel.... Compared to a stocker/75, I have ran several versions on stock fuel and hands down the 75 over stock was the most versatile and fun. Now built eng is another story...
depends on how big the pulse width is. my modded ihi/83 ran just fine on a 1.32a/r and stock injectors. i did/do run dual pumps and the tow tune was 3250uS though
im actually about to swap the 83's housing down to a 1.15 though and see how it does. 6th gear doesnt like to light off the 83 at 1800rpm like the 75 would.
James
best time to date: 12.39
Tailgate Crew Member #4
  #17
Old 03-15-2018, 11:26 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Originally Posted by diesel-max View Post
My daily driver has a 65mm vgt in the valley and a 485/96/ T-6 1.10 as the atmosphere, I used the 1.10 as I already had it laying around. I'd use the newer 1.15 if I didn't, its more cost effective and a REALLY nice housing for the same purpose.
It made 1132hp at the tire on my chassis dyno before I quit turning it up. It drives like stock and tows absolutely awesome!
Are you gated around the 65? I thought the 65 was to much of a restriction to get over 950hp.
06 GMC 2500 CCSB SLT LBZ 4X4
  #18
Old 03-15-2018, 11:39 AM
Burn Down's Avatar
Say what you want... The op wants a great towing setup at 600hp and from what I can tell he’s on stock fuel/bottom end. My 82/87 with a 1.1 housing is not better than the 75 I replaced it with. It has more power potential (that was never being debated)... Comparing built engines to stock engines is laughable
  #19
Old 03-15-2018, 12:24 PM
Chevy1925's Avatar
i hope hes not going to try to tow at 600hp without some engine and cooling work
James
  #20
Old 03-15-2018, 12:27 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Say what you want... The op wants a great towing setup at 600hp and from what I can tell heís on stock fuel/bottom end. My 82/87 with a 1.1 housing is not better than the 75 I replaced it with. It has more power potential (that was never being debated)... Comparing built engines to stock engines is laughable
Assuming the cam & head & compression ratio differences are not extreme, most people with 'built' engines could put their air and fuel setup on a stock long block and they wouldn't know the difference. And vise versa.
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #21
Old 03-15-2018, 12:42 PM
Noreaster's Avatar
Noreaster Noreaster is offline
I have a s475 with a 6 blade billet wheel with the standard .63 cover & a 1.10 housing, its the best all around setup Ive run so far
Id like to change the crossover & downpipe someday to run Tial's SS 1.17 v-band housing but I hate the fact that they cost almost $800
02 GMC 2500HD RC/LB "No Shuckin Luck" Totaled 12.26 @ 109
Ridge Runner Diesel Performance, Big Dipper tranny, Profab Performance, Super Diesel, Creatures of the Night, AirDog, BD
02 GMC 2500HD EC/SB WCFab twins
Bay State Diesels
  #22
Old 03-15-2018, 12:58 PM
Burn Down's Avatar
Sure, if you want to waste a ton of money on parts not needed to make 600hp.
  #23
Old 03-15-2018, 12:59 PM
Burn Down's Avatar
Agreed. But some on here would have this guy thinking he could tow at 1100.
  #24
Old 03-15-2018, 01:00 PM
Chevy1925's Avatar
should i try that?
James
  #25
Old 03-15-2018, 01:08 PM
ikeG's Avatar
Oughta Know Better
I was referring to your comparing built engines with stock statement. But thats getting off topic anyhow so nevermind
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #26
Old 03-15-2018, 01:24 PM
Burn Down's Avatar
should i try that?
dont be a chicken shit James turn it up!
So whatís your recommendation for the op. My point was itís tough to beat a 75 stocker setup for towing on a stock engine. Not a 1100hp built setup. Can it make as much power as a big atmo no but it will spool quicker and better suit the opís needs. How are we off topic?
  #27
Old 03-15-2018, 01:33 PM
ikeG's Avatar
Oughta Know Better
I missed your point til now. I thought you were talking specifically about the turbos' driving characteristics with built vs stock engines, not the potential and capabilities. And if we discussed that it would be off topic.
For towing I would definitely try a 87 tw in either a t6 housing or even a 1.25 t4. They are extremely lazy for a t4 in a single setup in my experience. But if you make/buy a kit with a t4 flange you limit yourself severely on turbo changes in the future.
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #28
Old 03-15-2018, 01:53 PM
Burn Down's Avatar
For towing I would definitely try a 87 tw in either a t6 housing or even a 1.25 t4. They are extremely lazy for a t4 in my experience. But if you make/buy a kit with a t4 flange you limit yourself severely on turbo changes in the future.
Ok Iím with you. I think we all misunderstand each other sometimes.
  #29
Old 03-15-2018, 07:07 PM
diesel-max's Avatar
diesel-max diesel-max is offline
Haisley Never heard of her
Gates are required for drive pressure regulating. So sizing on compressors doesnít really have much to do with that need.
But the 65, is what was determined to be a fleece cheetah that was acquired on the original junk yard motor. Itís a 4094 turbine wheel thatís been clipped into a lbz housing that has been bored out to make it fit, They also used a cast 4088 wheel in it, so I had my man Mark send me one of his vane packages and he has a 4088 billet compressor wheel so naturally it was a drop in replacement. Iím not sure how if even possible he would compare it to his line of chargers.
The atmosphere is a SD 5blade 85/96T-6 1.10
At 2250uS and 24* it made 1132hp at the tire on my dyno dynamics dual eddy chassis dyno.
I donít have a switch, nor will I probably ever in any of my trucks and just this past week I hauled a buddies lbz on my gooseneck and it did great.
1996 F-250 LLY Pullin truck....... 3.0 Smoothbore "Dirty Secret"
Huge thanks to: Wagler Competition Products, and Mark B. @Danville performance!
'15.5 Denali HD LML.
Exhaust,Tuned, Ratio Tec, twin Kennedy lift pumps.
'05 Twin turbo LLY.
LBZ Block, LBZ S&S 150% overs, LBZ heads, Callies CompStar, Wagler Street rods, Wagler Comp Stg. 2 Camshaft, Hamilton springs, Smith bro. Pushrods, ARP head/main/rockershafts, Dual CP3's, Michiana Diesel built Allison/ 1074-3D Suncoast converter, twins/DP VGT and StainlessDiesel S485/96/1.10 5Blade
  #30
Old 05-06-2018, 01:15 PM
dordtrecht5's Avatar
dordtrecht5 dordtrecht5 is offline
Regular Cabs Rock
How did you like the 5blade from SD? I've been considering going that route, except with a 480 when the time is right. How do they sound?
Sent from my Moto Z (2) using Tapatalk
'06 LBZ RC/LB 4x4
EFI by TDT
Super High Flow EGR delete kit and Centerlink support by AllSeason
GMAX6 & ML-G HD
BT DieselWorks Lock-up
12.59 @ 105
SOLD
02 CCSB LB7 EFI Big tie rods/PacBrake bags/DVD Pioneer head unit Rockford Fosgate speakers/110-120voltAC inverter/Mastercraft MTR
Thanks go out to 770JOHNNYW and blk smoke lb7
International Association of Bridge, Structural, Reinforcing and Ornamental Ironworkers Local 21 Omaha, NE
United Steel Workers Local 1343 South Milwaukee, WI
