Old 04-15-2018, 07:10 PM
ChrisPerry's Avatar
Default Spring measurement 5 leaf (4/1)
02 2500 eclb 2wd.
How much space between the main pack and the overload when unloaded? I have about a half inch. I'm trying to figure out if the reason for my harsh ride is from hitting the overloads.
02 GMC 2500HD, EC/LB, LB7, 2wd, 6" lift, 35" tires. ds LML manifold, PPE 260 hp tune, boost valve, race plug, Airdog 165 lift pump, CAT filter mod, mechanical egt and boost gauges, SB intake, high flow turbo horn, ported turbo exhaust housing, kbd drop in wheel, Banks Bighead wastegate, egr blocked, intake heater delete, PPE downpipe, 5 " exhaust w/ cat delete, Mike L built trans w/ Goerend R converter. Levi's heat blankets
Old 04-15-2018, 07:17 PM
Chevy1925's Avatar
Yes it is. You should have somewhere around 1.5 at the tail end of the overload
James
best time to date: 12.39
Tailgate Crew Member #4
Old 04-15-2018, 07:48 PM
ChrisPerry's Avatar
Thanks, kinda what I thought.
Any idea who makes a good riding spring. I've got airbags and traction bars, so I'm not worried about spring wrap or them being a little too soft.
Old 04-15-2018, 08:07 PM
Chevy1925's Avatar
I think it was Tom or someone that found new springs for cheap that brought the arch back. If you have a local spring shop close by, they can put the arch back in the stock leafs too. Otherwise you are looking at a set of deaver springs
James
Old 04-15-2018, 08:53 PM
TheBac's Avatar
TheBac TheBac is offline
https://www.generalspringkc.com/Leaf...010_s/1831.htm
^^ Just an example.
Cant say I've had the need to find new springs for my truck though.
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
From mufflerguy on yb,
Old 04-15-2018, 09:55 PM
ChrisPerry's Avatar
Thanks James and Tom.
I'll spend the next few days contemplating what springs to go with. Deavers are tempting, I'm just not sure how they will work combined with the bags. Decisions decisions decisions
