#31
I've rigged a few for customers but they were old Prevost busses converted with full slide outs and every emenity you can squeeze into one. They are pretty neat, you would never know what it was going down the road. Antenna wise KVH, XM weather/audio, wifi booster, etc. They are a challenge to rigg bc of top crowning...
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900, lots of boost, Mayhem tuned, etc... ![]() 2015 Corvette Stingray Z 51 < Stock... ![]() 2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help. ![]() |
#32
4 inch,red select dirt pad,one main beam across and 1/2 rebar. Thought about 5 but didnt do it. Also i paid for the dirt pad out of pocket so it was not in the 60k.
2015 ltz 3500. 97 monaco bus. 2016 2500 gassee. 2001 burb. |
#33
You will be hard pressed to put a lift in a 4" slab, it will spider crack in no-time.
Current Rides: 1) 2005 LLY ECSB, Leather, Sunroof -Built Motor, Billet S476/87, Dual 10mm CP3s, Exergy 60% Overs, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support ![]() Past Rides: 1) 2002 LB7 CCSB, Leather, Loaded -New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap |
#34
Didnt say i was adding a lift. There is a 41 ft monaco bus in there,seems fine.
#35
All of it cracks eventually. Best the thing to do is put expansion joints around the lift.
#36
For the lift, just cut out an appropriate sized square opening in the slab and pour a suitable isolated footing.
Mitch SOLD02 Chevy 2500HD D/A EC SB LS SCIII & X-Case brace by MA, Team Salad tuning ![]() 1983 GMC K30 CC SHORT BED ![]() Awaiting Dmax/Allison Chassis Swap ![]() |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
