  #1
Old 05-27-2013, 10:21 AM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default Nerd Stuff:
Ghetto Waterworks:
This is homemade water cooling system for a 4 CPU high performance computer. It uses a Honda Del Sol car radiator, and garden fountain pumps.
This is about 47 sq in of radiator per CPU. SWTX Tyan S8812 mobo (4P G34) is in a Rosewill Blackhawk case with a subplate to raise mobo .125". Chinese water blocks are held down with homemade spring clamps. Red vinyl is hot, blue is cold. Radiator flows 700gph, CPU's flow 140gph each.
http://youtu.be/xtSGRYmH2Bs
http://youtu.be/Uu1OnOTJwwU
Running 41C max at full load at 3.0ghz with 64 cores of AMD ES 6200 chips, Mobo using 855w + water and fans (all AC, not 12v).
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #2
Old 05-27-2013, 10:43 AM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
Pro Tuner Wannabe
Default
That is some serious cooling
Sent from my iPhone.
__________________
-Steve- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
  #3
Old 05-27-2013, 02:05 PM
Poltergeist's Avatar
Poltergeist Poltergeist is offline
Ghost in the Machine
Default
__________________
Privately owned since August 2006.
  #4
Old 05-27-2013, 03:01 PM
PACougar's Avatar
PACougar PACougar is offline
Default
You need to get some freon into that setup
__________________
2004 LB7 EC/LB 2WD Dropped 6" in the front on coil overs and 7" in the rear on 18"s, Hellwig front and rear sway bars. Caltracs traction bars.
Socal Diesel built bottom end, FI S480 Billet wheel and race cover, RDL Headers and pipes,
Dual Cp3(1 modded and 1 stock), Exergy 100% over injectors,
Socal Diesel injector clamps, Socal Stage 2 Heads/ARP Head Studs
Suncoast GMAX-5 plus some billet built by my best friend Dave(He's a Badass like that), 1058 converter, MikeL Cooler
Mag-Hytec pans on Tranny(Scraping a little) and Diff
Custom modified MBRP exhaust i.e. it dumps in front of the rear tire(Also by Dave). Never had a cat
Labonte Motorsports water/meth, AirDog II 200
Custom 5" Intake Pipe w/AFE Filter, BD Cool It Intercooler,
EFI Live DSP5
Torsen limited slip(POSI), Gauges
DON'T PURCHASE FROM INDUSTRIAL INJECTION UNLESS YOU ENJOY GETTING SCREWED!
  #5
Old 05-28-2013, 09:41 AM
McRat's Avatar
Diesel Hotrodder
Default
The machine is in a warehouse that gets really hot in the summer. Hence the crazy amount of cooling potential.
__________________
Pat and Kat McSwain
  #6
Old 05-28-2013, 10:21 AM
FC5452's Avatar
FC5452 FC5452 is offline
Default
And hear I thought I ran some insane cooling
__________________
LML- With some Stuff added
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
