  #16
Old 04-26-2015, 02:43 PM
Tjamespaull Tjamespaull is offline
FNG
Default
I've got some play in the rear most gear pack, never had an Allison apart so I'm not sure if there is an allowable spec or not. The e valve was a little tough coming out but I didn't see any burs in the housing. Got it back together and they all slide freely. I think I'm going to wait until tomorrow night after I call the transmission shop to put it back together
  #17
Old 04-26-2015, 03:45 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Quote:
Originally Posted by Huffy67 View Post
With no metal in the pan you prob just need to remove the valve body and split it in half and clean/deburr the E valve and its bore. If they had let the Torrington bearing fall when they replaced the housing you would see lots of metal in the pan.
Not right away in certain cases.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #18
Old 12-12-2017, 08:21 AM
drbird123 drbird123 is offline
Gearhead
Default
Hi there, I have an 08 Duramax and when it is cold it throws a P0751 code Shift Solenoid (SS) 1 Valve Performance - Stuck Off. If it is inside the shop it is fine. Once it warms up it goes away!! Any ideas of what to check?
Thanks
  #19
Old 12-12-2017, 09:02 AM
Mike L.'s Avatar
Default
Try letting it warm up before you put it in gear and see if it still throws the code.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #20
Old 12-12-2017, 11:36 AM
Gearhead
Default
I did that and as soon as its warm it is fine.
  #21
Old 12-13-2017, 12:51 PM
Gearhead
Default
any ideas?
  #22
Old 12-16-2017, 12:21 PM
Bustedknuckles's Avatar
Bustedknuckles Bustedknuckles is offline
Honey Badger
Default
Quote:
Originally Posted by drbird123 View Post
any ideas?
Pressure switch o rings or bad filter neck seal possibly.
Sent from my SM-G955U using Tapatalk
__________________
04 lb7: 06 front clip, EPR s366, 30% over injectors, ARP head studs, Idaho-Rob tunes, airdog, PPE trans, Precision ML converter, etc......
  #23
Old 12-17-2017, 02:14 PM
Gearhead
Default
Ok is the pressure switch located inside the pan?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
