Old 12-16-2017, 08:17 AM
Bbuchanan11's Avatar
Bbuchanan11 Bbuchanan11 is offline
Gearhead
Default Heater hoses at heater core with twins
I picked up a truck with what seems to be a custom set of twins. Previous owner cut the ends of the heat core off I'm guessing because the hot side pipe would not fit.. I'm planning to take dash out and put a new heater core in it so I can obviously have heat in the truck. Can some of you guys with twins post up some pictures of how close/routing of the heater hoses please... thanks
06 Silverado lbz 11.77 @115 sold
17 Silverado L5P ltz custom sport stock
06 gmc built motor/ trans dual fuelers 60 overs 75 over 66, 5600lbs... track times coming soon
Old 12-16-2017, 01:14 PM
Burn Down's Avatar
There are some pics of my MPI kit in my albums.
Old 01-10-2018, 07:11 AM
Ron2145's Avatar
Ron2145 Ron2145 is offline
FNG
I wrapped my heater hoses with a Heat Shield product after the hot pipe burned a hole in one of them.
Old 01-10-2018, 03:00 PM
BlkMax's Avatar
BlkMax BlkMax is offline
I had a custom blanket made by Levi for the triple hot pipes, and put heat shield on the heater hoses.
Black Max....
Black Max, the fun truck:
'03 2500 4x4 CC/LB
Bent Rods, now under construction, its time to put all the saved up parts in....
Special thanks to Pat & Kat McSwain, MikeL, Guy, Trent, and others from here-thank you for the great ideas!
EPR triples
Emma, my DD:
'04 2500 4x4 EC/SB
HTT T4 366 74 .91, 65% SAC's from LDS, Trans Kit from Evan, tunes by Zach at Starlite
Old 01-10-2018, 03:56 PM
SAC owner SAC owner is offline
Gearhead
