  #1
Old 06-12-2018, 01:18 PM
RobsDmax's Avatar
RobsDmax RobsDmax is offline
Default LLY Short Block Into 2001 Wiring
Bought a built short block (LLY Reluctor) putting it into my 2001 wired truck. Wondering what sensors I need to change if any. Fuel system will be LB7 still. Going into a pulling truck so not worried about any functions besides motor! Also wondering if anyone has a good link to a writeup on assembling a long block (LB7).
Thanks in advance.
__________________
2003 Chevy LB7 RC/LB
EFI By Kory
2003 Chevy LB7 CC/SB "Cheap Hooker"
EFI By Kory - S400 HSP Kit - 2.5" Billet Charger - 2.8" Puller
2008 GMC LMM CC/SB
EFI By Kory - Magnaflow Exhaust
  #2
Old 06-12-2018, 02:35 PM
rfletes79's Avatar
rfletes79 rfletes79 is online now
Default
Cam & Crank Sensors, EOP sensor and associated harness. You will need this items from the 01 short block.
You can leave the lly eop sensor in the block as the 01 eop sensor goes in a different location. It will just be plugging the hole with no harness plugged into it.
__________________
j
1970 Chevelle Duramax Hot Rod, '04 LB7/TH400-gear vendor, S475/factory IHI, 65% inj, 10 mil pump, SoCal AF cam, Valve springs, Push Rods, LBZ rods..... 10 sec cruzer :-)
2002 2500HD LLY swap 5-24-15.
  #3
Old 06-13-2018, 06:13 AM
RobsDmax's Avatar
Default
Much appreciated! EOP sensor plugs into the 01 harness? Or there is a block harness for it also?
Thanks.
__________________
EFI By Kory
2008 GMC LMM CC/SB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
