  #1
Old 05-01-2018, 12:01 PM
Bdsankey Bdsankey is offline
Default Stock Parts from Engine Build/Laying Around
I have some stock parts I don't plan on using on my engine build. Prices are OBO. All prices are shipped and all parts have 160k miles on them unless otherwise noted.
1) Set of 16 pushrods, 160k miles on them, all straight. $125
2) Set of 32 valve springs with retainers. $75
3) Stock LLY flexplate/ring gear. $125
4) Stock oil cooler/oil filter housing. $75
5) Water pump with cover (was peened with a punch to help resist spinning), no cover damage/no contact made, 15k miles. $125
6) Lower oil pan, some surface rust (no oil level sensor). $40
7) Factory y-bridge (no snout piece), painted chevy orange. $30
8) Oil pressure sensor. $20
9) Cam sensor. $20
10) Crank sensor. $20
11) Factory oil pan, no oil level sensor. $free, You pay the ride
12) Aftermarket metal LLY intake tube (airbox->mouthpiece), unknown mileage. $75
__________________
Current Rides:
1) Toy: 2005 LLY ECSB, Leather, Sunroof
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp 75R", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
  #2
Old 05-07-2018, 12:15 PM
Default
Bump, also have:
13) 16 lifters, oem, $125 shipped (160k miles, no damage)
__________________
Current Rides:
Past Rides:
  #3
Old 05-14-2018, 06:56 AM
Default
bump
14) Set of factory valve springs with retainers. $50
__________________
Current Rides:
Past Rides:
  #4
Old 05-17-2018, 09:34 AM
Default
bump
__________________
Current Rides:
Past Rides:
  #5
Old 05-21-2018, 06:20 AM
Default
TTT, shoot an offer
__________________
Current Rides:
Past Rides:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
