  #121
Old 12-23-2015, 09:00 PM
mike diesel's Avatar
mike diesel mike diesel is offline
I'm alright.
Default
Mine have been living comfortably at around 1150whp. I've ran all sorts of different air and fuel setups on these pistons. Been ran at 3000us on 30% injectors, 2750us on 100% injectors and 2600us on 175% injectors. Nozzles have all been from either industrial injection or extrude hone. Have had single 72mm, 72/88 compounds, 75/88 compounds, 75/98 compounds and currently now 75/106 compounds.
Heads will be off here in a few weeks for new gaskets, I'll post some pics of how the pistons look.
__________________
'89 s10 daily driver
  #122
Old 12-23-2015, 10:48 PM
ty_LBZ's Avatar
ty_LBZ ty_LBZ is offline
Camaro killa
Default
Interested to see how Pistons held up
__________________
LBZ CCSB 4x4. deleted. re-routed. shimmed. EFI by Kory 4" MBRP downpipe-back w/Corsa. Alligator trans cooler hoses. 3" Pro-Fab downpipe. Transgo Jr. Banks ram air intake. MA pump rub fix. Rare Parts tie rods. Fumoto Valve. AirDog 150. Nicktane CAT filter adapter. SoCal 3388AF. ProFab charge pipe & Y-bridge. Mahle +0.020 pistons. Keyed cam & crank. ARP head studs, main studs, flywheel. Rotating assembly balanced. Merchant Auto motor mounts.
10/30/14- cracked piston
03/14/15-Back from the dead
  #123
Old 12-23-2015, 11:47 PM
Hot COCOAL Hot COCOAL is offline
May the farce be with you
Default
You have too much time and money...
Glad you're here
__________________
Jason-
Founding member of the "knows enough to be dangerous" club...
Hey, I'm NORWEGIAN... you try having a SQUARE head full of ROUND thoughts...
  #124
Old 12-24-2015, 01:47 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Default
For what it is worth, we are running 5,582psi on Brett's Race Cast Oval bowl pistons with his current setup that he has been running for the past couple years. This pressure was made at the tune of 1447hp 2304ftlbs @88psi boost on 2275us 26*peak.
__________________
06 LBZ "White Lightning" 2wd rclb DP built motor Carillo, 15.25:1 "Finger" Oval Pistons w/reliefs, Socal Titanium upgraded springs on Stock heads w/Socal Billet injector holddowns,ARP, head-main-rocker studs,Soca Billet mains& Dampner, Chromoly pushrds, DP B72mmstg2R1VGT/StainlessDiesel S472/87 1.0SS triples, DHD Cast SuperHighflow intake, Exergy 14mmCP3 & 250%inj,Fass, PPE Race Valve PPE Manifolds, Banks Technicooler, AFE Boost tube, SC GMax6 Goerend "G" Grizzly Locker 3.42 gears, 1198+++hp 2k+ftlbs
Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out TCTStg2 Exergy 12mmcp3 1/8th 9.11@77.51 1/4-14.174@96.8mph
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
  #125
Old 12-24-2015, 04:55 PM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
Hell yea Mark
Are you trying to lower pressure on the new setup?
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
  #126
Old 12-25-2015, 12:19 AM
LBZ's Avatar
LBZ LBZ is offline
Default
Quote:
WOW!!
Nice numbers!!!
  #127
Old 01-02-2016, 04:09 PM
I'm alright.
Default
Had my heads off this weekend. Roughly 6000 miles on the motor. Probably 50+ 1/4 mile passes on it and just about every street mile is very aggresive. Pistons looked great. 1800+ EGT's and 85 psi boost.
__________________
  #128
Old 01-02-2016, 04:37 PM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
Default
Jon, I am looking at getting a block honed in preparation for a set, what bore spec do you recommend for your pistons. Just not sure if I will need to bore it , or spec to shoot for.
__________________
2001 2500HD Red on Black.
ATS Dual CP3, 4 inchIntake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
  #129
Old 01-02-2016, 06:31 PM
ty_LBZ's Avatar
Camaro killa
Default
Looks like most of the fuel stayed in the bowl.
__________________
  #130
Old 01-02-2016, 08:11 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
Quote:
Each sets gonna be different. There is a bore spec sent with them to go off of. But some builders use there own clearences. .
__________________
2006 ccsb Lbz Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
